Public KeyDB Disc Submissions
Disc type: Blu-ray
Disc ID: fdceef043d46b030b30e2057c72890aae039fd27
Disc dump filename: MKB_v82_RICK_AND_MORTY_SEASON_8_ECD6.tgz
Drive: Pioneer BDR-212U
Drive firmware: 1.01
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? Y
Have you verified that all submission links are accessible in incognito/private browsing? Y
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):
Disc dump link:
Disc dump link:
Reason: Works now, removing dead links
sunday46ma
My father is a hero UHD
Disc type: UHD
Disc ID: 1DC22A8487A579AEC34515AEDE9BEA1D99B948CB
Disc dump filename: MKB20_v82_My_father_is_a_hero_8340.tgz
Drive: BW-16D1HT
Drive firmware: 3.00
MKB_RO.inf link :https://drive.google.com/file/d/11N8mNl ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1WRM5De ... drive_link
Disc type: UHD
Drive: BW-16D1HT
BaiDuYunPan
keydb_helper wrote: Tue Mar 10, 2026 8:05 amI'm glad to hear you got it working.BaiDuYunPan wrote: Tue Mar 10, 2026 7:28 am Oh my god, I'm going to download the cfg file now. I can actually rip it now. I previously uploaded a lot of tgz files and thought I needed to submit some ID or something. I copied it out and replied to you. I can rip it now without any problem...
In the opening post of this thread (see page 1) I specified a template which I'd like to see users follow when providing disc dump files.BaiDuYunPan wrote: Tue Mar 10, 2026 7:28 am ...what I don't quite understand is this sentence: 'In the future, please follow the submission template outlined in the opening post and include the full MKB_RO.inf file from the AACS folder on your disc.'
This is a recent example of a good submission:The main motivation behind the template was to make sure users were actually trying out the latest keydb file before submitting titles which were already supported. Hence the line:Quarter-Tank wrote: Sat Mar 07, 2026 1:56 pm Disc type:UHD
Disc ID:0x733E7089938D7175CDBEEF90B2BB2E52C2D8943D
Disc dump filename:MKB20_v61_Jason_Bourne_D0AB
Drive:BD-RW BDR-XD06U
Drive firmware:1.11/ID69
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: ...
Disc dump link: ...Several other lines were added in response to common submission issues.Did you sync the public keydb within the last 15 minutes? Yes
Drive information was relevant for the first few years as Pioneer drives were not supported. This is no longer the case as any UHD drive can be utilised but I'm not going to adjust the template just in case a future MakeMKV update changes the status quo.
The disc ID line is not absolutely essential but it allows keydb contributors to quickly check if a disc is already in the keydb without having to download any disc dump files. The disc ID is just the SHA-1 hash of the Unit_Key_RO.inf file and this can be calculated with 7-zip or any other hash utility. organicguy posted a PowerShell command which calculates the disc ID natively on recent versions of Windows here (adapt it as required to match your disc drive letter).
The only essential lines required for adding a title to the public keydb are:Hello, I'm back again. This time I bought this set of discs My_father_is_a_heroMKB_RO.inf link: ...
Disc dump link: ...
Disc type: UHD
Disc ID:1DC22A8487A579AEC34515AEDE9BEA1D99B948CB
Drive: BDR-S13C-X
Drive firmware: 1.03
MKB_RO.inf link: https://drive.google.com/file/d/19lh_Mz ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1cS7e18 ... drive_link
BaiDuYunPan
I don't know if you can receive my message, so I decided to send it again.
Disc type: UHD
Drive: BDR-S13C-X
Disc type: UHD
Drive: BDR-S13C-X
TheGreatMcPain
Got my Wolf Children steelbook from Gruv.
Disc type: UHD
Disc ID:
Disc dump filename: MKB20_v82_Wolf_Children_C763.tgz
Drive: BD-RE WH16NS60
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://mega.nz/file/PpdjCDxZ#2q2gwXeMH ... IhihBLzLR0
Disc dump link: https://mega.nz/file/L40UlTLZ#qWPWPBJWm ... MpVWs9_xSI
Disc type: UHD
Disc ID:
Grahamdoh
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
Danger Diabolik blu-ray from Eureka
Adventure Calls Set From Eureka
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v61_LALALAND_C635
*MKB20_v61_UHDBDROM_7779
*MKB20_v82_BECOMING_LED_ZEPPELIN_4694
MKB20_v82_BLUE_MONKEY_UHD_7B2F
*MKB20_v82_EscrocMachoEtGigolo_B53E
*MKB20_v82_HAMNET_EE3E
*MKB20_v82_MeetTheFockers_UPK75_BD10
*MKB20_v82_Mobile_Suit_Gundam_SEED_Freedom_AC28
MKB20_v82_Moneyball_AC43
*MKB20_v82_My_father_is_a_hero_8340
*MKB20_v82_The_Devil's_Backbone_EB0A
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
el_vandragon
Got another one with just the unit keys present so sharing the dump here so the rest can be added
For some reason it has a massive MKB_RO.inf file (128 MiB!), even though it is mostly zeroed out. Both are in the same google drive folder
Disc type: UHD
Disc ID: 0x00327DE2ADE8040345E1A2437804D2098A3F2C37
Disc dump filename: MKB20_v71_THE_GODFATHER_FE45
Drive: BW-16D1HT
Drive firmware: 3.02 DE (OmniDrive)
MKB_RO.inf link: https://drive.google.com/drive/folders/ ... drive_link
Disc dump link: https://drive.google.com/drive/folders/ ... drive_link
Disc type: UHD
Drive: BW-16D1HT
keydb_helper
Hey el_vandragon, as you use Windows you can probably process that disc dump file yourself with SamuriHL's KeyDB Toolel_vandragon wrote: Thu Apr 16, 2026 3:34 am Got another one with just the unit keys present so sharing the dump here so the rest can be addedFor some reason it has a massive MKB_RO.inf file (128 MiB!), even though it is mostly zeroed out. Both are in the same google drive folder
Disc type: UHD
el_vandragon
Oh fascinating, I thought people were mostly just using it to sync KEYDB files, I normally just use FindVUK manually and didn't realize this could be used to get missing information. Looks like it worked and was able to validate! Thanks!keydb_helper wrote: Thu Apr 16, 2026 3:58 am Hey el_vandragon, as you use Windows you can probably process that disc dump file yourself with SamuriHL's KeyDB Tool
keydb_helper
Great to hear that it worked out for you. Discs which don't utilise media keys already known to the keydb (generally newer discs or less popular older titles) will still need to be posted here.el_vandragon wrote: Thu Apr 16, 2026 4:08 am Oh fascinating, I thought people were mostly just using it to sync KEYDB files, I normally just use FindVUK manually and didn't realize this could be used to get missing information. Looks like it worked and was able to validate! Thanks!
MrPenguin
The "validate" functionality needs to have an entry in the KEYDB.cfg file to validate. And when there isn't any such entry for your disk then the helper utility needs to create one first. Whether or not it can create this new entry is unfortunately a matter of luck, but it would always recommend trying to validate your disk anyway, just in case.el_vandragon wrote: Thu Apr 16, 2026 4:08 am Oh fascinating, I thought people were mostly just using it to sync KEYDB files, I normally just use FindVUK manually and didn't realize this could be used to get missing information. Looks like it worked and was able to validate! Thanks!
To be fair, I would consider just upgrading a "NOT VALIDATED" entry to a "VALIDATED" one to be worth it
asdc2004
Disc type: BD
Title: Perfect Blue (Korean release)
Region: Korea
Disc ID: (paste SHA-1 here)
Disc dump filename: MKB20_v82_PERFECT_BLUE_AC51
Drive: BP60NB10
Drive firmware: 1.02
Thanks for your help.
Region: Korea
Drive: BP60NB10
So do I...that's why I added it.MrPenguin wrote: Thu Apr 16, 2026 10:41 am To be fair, I would consider just upgrading a "NOT VALIDATED" entry to a "VALIDATED" one to be worth it.
el_vandragon
Yep! It is cool that it can try similar discs to see if there is a matching key. I validate or aacskeys all my discs but I have never tried media keys from other entries so I will make sure to use this utility whenever I run into discs with just UK and then only post here if it can't find a match. Thanks for the help everyone!keydb_helper wrote: Thu Apr 16, 2026 10:04 amGreat to hear that it worked out for you. Discs which don't utilise media keys already known to the keydb (generally newer discs or less popular older titles) will still need to be posted here.el_vandragon wrote: Thu Apr 16, 2026 4:08 am I normally just use FindVUK manually and didn't realize this could be used to get missing information. Looks like it worked and was able to validate! Thanks!
