Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v76_SONIC_THE_HEDGEHOG_2_6CFF
*MKB20_v82_ANACONDA_2025_C678
*MKB20_v82_Cutters_Way_7244
*MKB20_v82_IS_THIS_THING_ON_4E28
*MKB20_v82_Satan_der_Rache_67F0
sammyd1108
Post by sammyd1108 »
Hopefully I did this right, it’s been a few months since I’ve tried to do one.
Disc type: UHD
Disc dump filename: MKB20_v82_One_Flew_Over_the_Cuckoo's_Nest_47F8.tgz
Drive:PIONEER BDR-212T
Drive firmware:1.01/ID83
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/15Ed_Xg ... share_link
coffeemilk
Post by coffeemilk »
I am submitting the dump file.
If there are any problems or incorrect parts in the file, please let me know. I would greatly appreciate your guidance.
Thank you for your work.
MKB_v82_「エリオスライジングヒーローズ-SUMMER_FESTIVAL-」DISC2_9E10.tgz
https://drive.google.com/file/d/1Sf45eV ... drive_link
coffeemilk
Disc type: BD
Disc ID: Unknown
Disc dump filename: MKB_v82_「エリオスライジングヒーローズ-SUMMER_FESTIVAL-」DISC2_9E10.tgz
Drive: HL-DT-ST BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Possible (with patched firmware)
MKB_RO.inf link: https://drive.google.com/file/d/1GZBqMu ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Sf45eV ... drive_link
Notes:
The disc uses a newer AACS version and could not be decrypted.
Dump file size is about 107KB.
Here is the dump file for this disc. Please let me know if anything else is needed. Thank you!
jenrashe
Post by jenrashe »
You're Next(Bluray 4K)
Disc type: Bluray 4K
Disc dump filename:MKB20_v82_FACTORIS_1082_YOURENEXT_66_256A
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
MKB_RO.inf link: https://drive.google.com/file/d/1s6iPoq ... sp=sharing
Disc dump link: https://drive.google.com/file/d/131-1Zl ... sp=sharing
jenrashe
Post by jenrashe »
Van WILDERS (Bluray 4K)
Disc dump filename:MKB20_v82_FACTORIS_1104_3701623403540_AMERICANPARTYVANWILDERRELATIONSPUBLIQUES_UHDCMF_BD66_C9F2
Drive: LG BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1zXASO- ... sp=sharing
Disc dump link: https://drive.google.com/file/d/12pH3rB ... sp=sharing
jenrashe
Post by jenrashe »
The Bodyguard From Beijing (Bluray 4K)
Disc dump filename: MKB20_v82_FACTORIS_1038_THEBODYGUARDFROMBEIJING_3F30
Drive: LG BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1n-rdTA ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Lyxqa1 ... sp=sharing
sackoffun
Post by sackoffun »
One Flew Over the Cuckoo's Nest
Disc type: BluRay 4K
Disc ID: b8acdb4721f6023dee3aea3eda9d0ba9
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1rvwL23 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1XBZhra ... sp=sharing
MrPenguin
Post by MrPenguin »
sackoffun wrote: Thu Mar 12, 2026 10:11 pm One Flew Over the Cuckoo's Nest
Doesn't the latest KEYDB.cfg file already contain this disk?
jenrashe
Post by jenrashe »
Sisu : de l'or et du sang (Bluray 4K)
Disc dump filename: MKB20_v82_SISU_DE_L_OR_ET_DU_SANG_4D85
Drive: LG BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1KLFOFn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1sh3kvi ... sp=sharing
Zetph
Post by Zetph »
Disc type: UHD
Disc ID: 0x3107C2E7A9E653308559C7ED8E261D9702F4C5F4
Disc dump filename: MKB20_v82_Wicked-_For_Good_18C4
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/drive/folders/ ... drive_link
Disc dump link: https://drive.google.com/drive/folders/ ... drive_link (in the same drive folder)
keydb_helper
*MKB20_v77_BDROM (悪魔のいけにえ 4Kデジタルリマスター 公開50周年記念版 -4K Ultra HD Blu-ray-)
*MKB20_v82_Brotherbood_of_Justice_BF0C
*MKB20_v82_Bulk_UHD
MKB20_v82_Crying_Freeman_5B3F
*MKB20_v82_DOA-UNCUT-OpenMatte-UHD_EB6E
*MKB20_v82_FACTORIS_1038_THEBODYGUARDFROMBEIJING_3F30
*MKB20_v82_FACTORIS_1082_YOURENEXT_66_256A
*MKB20_v82_FACTORIS_1104_3701623403540_AMERICANPARTYVANWILDERRELATIONSPUBLIQUES_UHDCMF_BD66_C9F2
*MKB20_v82_ShelbyOaks_C028
*MKB20_v82_THE_BREAKFAST_CLUB_3EF6
*mkb20_v82_thegreatalligator_2824
I believe all other valid submissions have been processed and added to the public keydb.
sammyd1108
MrPenguin wrote: Fri Mar 13, 2026 11:13 am
I have the latest downloaded and it’s still saying unknown volume key and it looks like someone else is also having the same issue.
keydb_helper
sammyd1108 wrote: Fri Mar 13, 2026 2:39 pm I have the latest downloaded and it’s still saying unknown volume key and it looks like someone else is also having the same issue.
The 47F8 variant of One Flew Over the Cuckoo's Nest was added to the public keydb over 24 hours ago. Both your submission and the submission by sackoffun have the disc ID 0xA5B59F43F15C6DA231BAF0D83190EBC291B55992 and this is indeed present in the keydb.
Open up your keydb.cfg file and search for 0xA5B59F43F15C6DA231BAF0D83190EBC291B55992. You should see a line like this:
0xA5B59F43F15C6DA231BAF0D83190EBC291B55992 = One Flew Over the Cuckoo's Nest | D | 0000-00-00 | M | 0x59<Redacted> | I | 0xB8<Redacted> | V | 0x9E<Redacted> | U | 1-0xE1<Redacted> ; MKBv82/BEE (UHD)
If you can't find it, you'll need to carefully follow my instructions here
In case you've changed the MakeMKV data directory from the default, just remember that your extracted keydb.cfg file needs to be placed in the same folder where MakeMKV created your MKB20_v82_One_Flew_Over_the_Cuckoo's_Nest_47F8.tgz dump file.
(I'm not sure why the disc ID provided by sackoffun is incorrect for his disc dump file)
sammyd1108
keydb_helper wrote: Fri Mar 13, 2026 3:18 pm
I’ll try it again when I get home I guess. I know I tried it right before posting my data dump and it still wasn’t opening.
