Weapons - Dump Files Submitted
scm1031
Dump files emailed for Weapons on 10/8/2025
MrPenguin
Re: Weapons - Dump Files Submitted
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files and restarting MakeMKV?
If this doesn't work, could you upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to KEYDB.
EventDriven
I'm not OP but I posted a link to the dump file in that thread as requested. Here it is to save folks a trip. I've been sync'ing my KEYDB a couple times a day to see if anyone had added it haha. I'd do it myself if I knew how.MrPenguin wrote: Thu Oct 09, 2025 2:25 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files and restarting MakeMKV?
https://drive.google.com/file/d/14tW3-q ... R3acVPLDr/
(edited: original tgz was generated by a Pioneer drive, regenerated with an Asus)
TopDollar86
I just emailed the dump for the UK version of Weapons UHD - don't know if the UK version is different from the US but I get the volume key error whenever I try to rip it.
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory and then restarting MakeMKV?TopDollar86 wrote: Tue Oct 28, 2025 6:21 pm I just emailed the dump for the UK version of Weapons UHD - don't know if the UK version is different from the US but I get the volume key error whenever I try to rip it.![]()
If that doesn't work, could you also upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
