Star Trek: Section 31 UHD (MKB20_v77_Star_Trek-_Section_31_BB50)
robinpersaud
Post by robinpersaud »
Dump file submitted via e-mail.
I have tried downloading the latest KEYDB.cfg file then copying it to the MakeMKV data directory (where MakeMKV also writes its TGZ dump files) and restarting. No dice.
Google Drive link: https://drive.google.com/file/d/1hoTUdU ... sp=sharing.
MrPenguin
Re: Star Trek: Section 31 UHD (MKB20_v77_Star_Trek-_Section_31_BB50)
Post by MrPenguin »
robinpersaud wrote: Sat Sep 06, 2025 4:25 pm I have tried downloading the latest KEYDB.cfg file then copying it to the MakeMKV data directory (where MakeMKV also writes its TGZ dump files) and restarting. No dice.
Your disk already has a validated entry in KEYDB.cfg. The real reason MakeMKV cannot rip your disk is because your UHD drive has not enabled LibreDrive:
No  SDF v098: HL-DT-ST_BD-RE_BU40N_A102_211712011708_M00IC7E5658
SDF id v098: HL-DT-ST_BD-RE_BU40N_A102_211712011708_M00IC7E5658
DEBUG: Code 2147483648 at 2g`y)1d*msr{}#Bb:121265499
DAFD=PAAAADAAAAEABDQgEHwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Have you flashed your drive's firmware already?
robinpersaud
No, I have not flashed my drive. I will search the forum for how to do this.
robinpersaud
I was able to follow the steps here: viewtopic.php?p=94848#p94848.
I am now able to read the disc and rip -- SUCCESS! :D
Thank you for pointing me in the right direction!
