AACS 2.1 support
Mike_Copy_Di
Re: AACS 2.1 support
Post by Mike_Copy_Di » Sat Nov 09, 2024 3:39 pm
I don''t believe that is the issue. This worked fine before I updated the OS on my MacBook. And I do not believe the firmware on my Pioneer has changed since it worked
MrPenguin
Post by MrPenguin » Sat Nov 09, 2024 7:13 pm
Mike_Copy_Di wrote: Sat Nov 09, 2024 3:39 pm This worked fine before I updated the OS on my MacBook. And I do not believe the firmware on my Pioneer has changed since it worked
Do you have any MakeMKV log files from before you updated your MacBook's OS? I am wondering if the update process quietly updated your drive's firmware at the same time :shock:.
asmcom
Post by asmcom » Sun Nov 10, 2024 10:26 am
MrPenguin wrote: Sat Nov 09, 2024 7:13 pm
This is the first time we have heard of this. We are running the latest version of Mac OS, and this upgrade has not happened on any of our drives. Forced updates is something we have not seen.
Clare
UHD Friendly Drive Team
Mike_Copy_Di
Post by Mike_Copy_Di » Sun Nov 10, 2024 3:18 pm
I can look for the log files and check the dates. Where can I find them on my MacBook Pro??
asmcom
Post by asmcom » Tue Nov 12, 2024 4:20 am
Mike_Copy_Di wrote: Sun Nov 10, 2024 3:18 pm I can look for the log files and check the dates. Where can I find them on my MacBook Pro??
Hi Mike_Copy_Di,
Could you post in the MAC OS on MakeMKV as there is some Apple experts in this area.
Please post exactly how you became aware that the drive auto updated the firmware automatically and hopefully someone will workout what is going on. Do you have any third party software installed for updating programs / firmware?
Hayley
viewforum.php?f=4
Mike_Copy_Di
Post by Mike_Copy_Di » Tue Nov 12, 2024 11:49 am
Sorry for the misunderstanding. I have no reason to believe the firmware for the Pioneer was updated.
I do believe that the issue was caused by the MacOS update.
ryley
Post by ryley » Tue Nov 12, 2024 12:02 pm
Mike_Copy_Di wrote: Tue Nov 12, 2024 11:49 am Sorry for the misunderstanding. I have no reason to believe the firmware for the Pioneer was updated.
Earlier you implied that your drive previously supported UHD discs:
Mike_Copy_Di wrote: Tue Oct 29, 2024 3:33 am Since my Mac has updated to Sequoia I have not been able to copy UHD discs.
Blu-Ray and DVD copy fine.
If you were previously able to use your Pioneer drive to backup UHD discs, it must have been with a different firmware version. MakeMKV has never supported UHD titles with the firmware currently installed on your drive. It is possible that MakeMKV will never support your firmware version.
Regardless of whether the drives firmware update was installed automatically or accidentally, there is nothing you can do at this point to restore UHD support. It is not a macOS issue, or some incompatibility with Sequoia. Your drive would have the exact same issue with Linux and Windows.
Mike_Copy_Di
Post by Mike_Copy_Di » Tue Nov 12, 2024 4:17 pm
The drive did and I have movies on my hard drive that I ripped using the Pioneer drive.
Post by Coopervid » Tue Nov 12, 2024 4:39 pm
Mike_Copy_Di wrote: Tue Nov 12, 2024 4:17 pm The drive did and I have movies on my hard drive that I ripped using the Pioneer drive.
If you still want to rip UHDs you should move on and get a new drive. PM me for recommendations. And BTW - this has nothing to do with AACS 2.1 support and should be posted as a separate topic.
zaqqaz6917
Post by zaqqaz6917 » Fri Jan 03, 2025 9:23 pm
Do you perchance have avg anti-virus with driver update feature?
I do and once I saw it recommended update of my pioneer drive fw..quickly disabled it
Mike_Copy_Di
Post by Mike_Copy_Di » Fri Jan 03, 2025 9:43 pm
no av on my MAC
roopdoge
Post by roopdoge » Mon Jan 13, 2025 10:33 pm
Just got a no key available issue with Heretic 4K UHD which was using AACS 2.1.
keydb_helper
Post by keydb_helper » Tue Jan 14, 2025 1:09 am
roopdoge wrote: Mon Jan 13, 2025 10:33 pm Just got a no key available issue with Heretic 4K UHD which was using AACS 2.1.
A new AACS 2.1 disc would be an interesting development. Could you please attach the dump file here or at least post the dump file name?
Public KeyDB Disc Submissions
Post by Billycar11 » Thu Jan 16, 2025 1:55 am
post the disc info also from makemkv
roopdoge
Post by roopdoge » Fri Jan 17, 2025 1:07 am
Here is the dump file.
Sorry, what do you mean by disk info?
