Disc Playback Issues on Verbatim Pioneer Driver
asmcom
Re: Disc Playback Issues on Verbatim Pioneer Driver
Post by asmcom » Sun Dec 17, 2023 1:06 am
heatvault14 wrote: Fri Dec 15, 2023 9:18 am It took a while, but I was finally able to secure a replacement disc drive from my manufacturer free of charge. Unfortunately on my first test of a UHD disk it froze 40 minutes into playback. This pretty much rules out a hardware fault. I have tried all the troubleshooting steps and solutions that have currently been suggested. I doubt I will find a solution to this problem but just wanted to keep other users having the same issue informed.
Thanks for everyone's help.
This is strange; the problem must be on your computer hardware. The workshop drive we have plays UHD discs perfectly on both our Dell T7910 workstation and our new Dell T7865, AMD Ryzen Threadripper PRO 5975WX and the video card is a AMD Radeon™ Pro W6800, 32 GB. We use VLC 64-bit to test play back.
Normally, we would never play discs directly. The only reason we did this was when we read about your issue. Most of our customers use MakeMKV to make a file that will play on their computer, media play or smart TV.
Anyway, sorry to hear about your hardware issue.
Asmcom
heatvault14
Post by heatvault14 » Sun Dec 17, 2023 1:43 am
asmcom wrote: Sun Dec 17, 2023 1:06 am
Asmcom
Yeah I know it stumps me, thanks for your help and time though. As I said previously, I have tested the drive on both my PC and laptop and same issue occurs on both. The only commonality between the two systems is that they both use intel CPUs (though different models of course) and they both run Windows 11.
zittrig
Post by zittrig » Thu Jan 25, 2024 10:40 pm
Good Morning,
I've the same problem with my 43888 (1.14) all the time I play BD directly. Ripping UHD without the problem, playing DVD directly without the problem.
Some mails between me and the support ..... no solution.
I use licenced POWERDVD 22 Ultra.
The support also adviced to configure some power options, but without solving the issue. I will send it in.
Other USB-Drives oder internal drives with USB-adaptor without any such problem all the time with exactly the same system configuration ...... :roll: Verbatim 43888 seems to be a princess .... :roll:
Post by Billycar11 » Thu Jan 25, 2024 10:48 pm
zittrig wrote: Thu Jan 25, 2024 10:40 pm Good Morning,
Your not going to get direct official playback unless your PC supports sgx.
Just do unofficial playback
zittrig
Post by zittrig » Thu Jan 25, 2024 11:04 pm
Hi Billycar11, I mean with "BD directly" normal Blu-ray-Discs (1080p), not 4K. The Intel SGX is only needed for 4K directly?
Or have I read the other posts wrong? The movies freezes after a time. Somtimes about 30 Minutes, sometimes after about 60 Minutes ....
Post by Billycar11 » Thu Jan 25, 2024 11:08 pm
zittrig wrote: Thu Jan 25, 2024 11:04 pm Hi Billycar11, I mean with "BD directly" normal Blu-ray-Discs (1080p), not 4K. The Intel SGX is only needed for 4K directly?
Oh I see thought you were talking 4K
heatvault14
Post by heatvault14 » Fri Jan 26, 2024 7:13 am
Yes this sounds exactly like the problem I've been having. Never tested PowerDVD though. I bought it but once I found out about the intel sgx requirements I refunded the purchase and have used VLC and MPC-HC ever since. I have only tested 1 regular blu-ray but issue still occurred the first time I tested. The inconsistent times also line up with what I've been experiencing. One time I managed to get almost 2 hours in before it froze, other time only 15 minutes.
Post by Billycar11 » Fri Jan 26, 2024 7:52 am
for one of my customers this worked turning of usb selective suspending
zittrig
Post by zittrig » Sat Jan 27, 2024 5:59 am
I've done this. Without solving the problem. This was one of the idea from the support. But for me without logical background because by playing a disc, the drive isn't inactive.
zittrig
Post by zittrig » Sat Jan 27, 2024 8:28 pm
Oookay, new situation: By watching a BD movie the drive freezed and I thought "ok, let's play the waiting game"...... and after about 10 minutes the drive started by itself, short stuttering and then I watched to the end.
Strange .....
asmcom
Post by asmcom » Sat Jan 27, 2024 11:28 pm
asmcom wrote: Mon Sep 25, 2023 11:58 pm
Coopervid wrote: Mon Sep 25, 2023 10:07 pm On a dektop I suggest to use a powered USB hub that provides sufficient power all the time.
Good idea Coopervid. This will probably solve the issue. Maybe there is system corruption?
For attention of Heatvault14
Try running CMD as administrator and running this command:
SFC /SCANNOW
one space after SFC
If there was system corruption found, I would consider restore keeping apps and personal settings.
My advise would be to backup to output file and play this instead. Playing from disc is not great solution if you keep having problems.
Asmcom :mrgreen:
We want to update you on our recent interactions with Pioneer and share some information concerning developments regarding the Verbatim 43888 drives.
We initially experienced no issues with the first batch of drives received from Verbatim. However, following a hardware revision and interface changes, we have encountered significant reliability issues. Specifically, we have observed freezing during 4K playback and the 43888 drive model will not function properly with DBpoweramp at all. Multiple drive failures have occurred when backing up large volumes of discs and of course we have swapped the drives out for customers.
Due to these critical problems impacting performance and stability, we've made the decision not to purchase or stock the Verbatim 43888 drives once our existing inventory is depleted. We believe this is the prudent course of action to maintain the quality and reliability standards our customers expect.
UHD Friendly Drive Team
MrPenguin
Post by MrPenguin » Wed Jan 31, 2024 11:06 pm
Can you describe how to identify a Verbatim 43888 drive's "hardware revision" please?
Post by Coopervid » Wed Jan 31, 2024 11:22 pm
See this. I don't think you can identify the hardware revision:
viewtopic.php?f=16&t=33094
longjoke
Post by longjoke » Mon Feb 10, 2025 8:28 pm
I'm having the same problem as OP with my Verbatim 43888 / Pioneer BDR-UD04. The direct playback with MPC-HC freezes after a while. Sometimes after a few minutes, sometimes after over an hour. I can not access file explorer after it freezes and can not open the device properties in device manager. Everything un-freezes after i close the makemkvcon64 process in task manager though. But the I have to restart MPC-HC and restart the playback. I never tried the "waiting game" though.
I am now trying to turn off the different windows power saving options to see if that works. I'm using USB-C to connect the drive on a USB4.0 / Thunderbolt 4 port with a cable for max 240W. So power delivery should not be a problem, I think.
I also have the Verbatim 43889 / Pioneer BDR-UD03 that I bought before and before I knew you could flash a different firmware to make it 4k friendly. I could test if it is a windows problem or a problem with the 43888's drive, if I could manage to find the firmware for the 43889. But it doesn't look like it is freely available at the moment and I'm already spend too much buying the two drives and makemkv :/ I wish I knew all of this beforehand. I'm on quite the learning curve here, just to play 4K blu rays on my computer :D
zittrig
Post by zittrig » Mon Feb 10, 2025 8:57 pm
Have you tried to disable USB selective power saving? With this I can run 43888 / 43889 without problems. With activated option, I can't watch BD with, in my case, PowerDVD or even rip 4k discs without freezes.
Or test it with an USB-C y-power cable, there are some with USB-C to double A. So you can get more energy to the drive also.
