Hmm, MakeMKV works fine when I deselect audio...
marcusj0015
Post by marcusj0015 »
So, there must be something wrong with my conversion profile, will one of you look it over and tell me what may be wrong? I only kept the main MakeMKV and audio sections, to make it easier to read.
Can I use direct flac command line options in my conversion profile?
<?xml version="1.0" encoding="utf-8"?>
<profile>
    <!-- profile name -->
    <name lang="eng">PERFECT</name>
    <!-- Common MKV flags -->
    <mkvSettings
        ignoreForcedSubtitlesFlag="true"
        useISO639Type2T="false"
    <!-- Settings overridable in preferences -->
    <profileSettings
        app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang),+sel:lossless,-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-10:favlang"
    <!-- Output formats currently supported by MakeMKV -->
    <outputSettings name="copy" outputFormat="directCopy">
        <description lang="eng">Copy track as is</description>
    </outputSettings>
    <outputSettings name="FLAC" outputFormat="FLAC">
        <description lang="eng">Compress track with FLAC</description>
        <extraArgs>-compression_level 12 -lpc_coeff_precision 0 -lpc_passes 4</extraArgs>
    </outputSettings>
    <!-- Lossless Audio -->
    <trackSettings input="TRUEHD-stereo">
        <output outputSettingsName="FLAC"
            defaultSelection="$app_DefaultSelectionString,+sel:true"></output>
    </trackSettings>
    <trackSettings input="TRUEHD-multi">
    </trackSettings>
    <trackSettings input="MLP-stereo">
            defaultSelection="$app_DefaultSelectionString"></output>
    </trackSettings>
    <trackSettings input="MLP-multi">
    </trackSettings>
    <trackSettings input="DTSHD-stereo">
    </trackSettings>
    <trackSettings input="DTSHD-multi">
    </trackSettings>
    <trackSettings input="DTSHDLBR-stereo">
    </trackSettings>
    <trackSettings input="DTSHDLBR-multi">
    </trackSettings>
    <trackSettings input="DTSHDMA-stereo">
    </trackSettings>
    <trackSettings input="DTSHDMA-multi">
    </trackSettings>
    <trackSettings input="FLAC-stereo">
    </trackSettings>
    <trackSettings input="FLAC-multi">
    </trackSettings>
    <trackSettings input="LPCM-stereo">
    </trackSettings>
    <trackSettings input="LPCM-multi">
    </trackSettings>
    <!-- Lossy Audio -->
    <trackSettings input="MP2">
    <output outputSettingsName="copy"
    </trackSettings>
    <trackSettings input="MP3">
    </trackSettings>
    <trackSettings input="DTS-stereo">
    </trackSettings>
    <trackSettings input="DTS-multi">
    </trackSettings>
    <trackSettings input="AC3-stereo">
    </trackSettings>
    <trackSettings input="AC3-multi">
    </trackSettings>
    <trackSettings input="EAC3-stereo">
    </trackSettings>
    <trackSettings input="EAC3-multi">
    </trackSettings>
</profile>
Re: Hmm, MakeMKV works fine when I deselect audio...
Does it work if you select the default profile, instead of FLAC?
marcusj0015
Woodstock wrote:Does it work if you select the default profile, instead of FLAC?
I'm using a custom profile, which I pasted above, and yes it works fine when I don't use my profile, so there must be something wrong with my profile.
I remember Mike mentioning a confirmed bug in 1.8.0 that involves using FLAC audio encoding. In one case reported, it would simply stop at 99% done. The work around was to not use FLAC until 1.8.1 comes out.
marcusj0015
Woodstock wrote:I remember Mike mentioning a confirmed bug in 1.8.0 that involves using FLAC audio encoding. In one case reported, it would simply stop at 99% done. The work around was to not use FLAC until 1.8.1 comes out.
Oh, that's interesting, thanks for the tip. In the mean time I'll work on my conversion profile. Thanks.
