Hey all you smart people, I've been pretty successful archiving my old DVD collection using my Archgon BD-RE BU40N drive model MD-8107-U3 with the MT1959 platform and 1.00 firmware.
Recently I got to my Looney Tunes Golden Collection sets and man oh man they've been a fickle bunch of discs. I've managed to coax the Archgon and MakeMKV to backup the first 4 volumes and Disc 1 of Volume 5, but the remaining Vol 5 discs just fail at every turn. Even using XReveal, I get all sorts of errors.
The Discs are clean and brand new (I bought them as they were released, not from Ebay). Never played them before now.
The Drive is plugged directly into USB 3.0 ports on PC.
I've ordered a pioneer but I'm wondering if there is something simple I could change to make this work.
Details below.
With no disc, MakeMKV shows this:
OS device name: L:
Product: BD-RE BU40N
Revision: 1.00
Serial number: ...
Firmware date: 2116-12-20 15:28
Highest AACS version: 81
Firmware version: 1.00
When I insert the disc I sometimes get this:
Current profile: DVD-ROM
Revision: 1.00
Serial number: ...
Disc Information
Label: LOONEY_TUNES_GOLDEN_V5_D2
Timestamp: 2007-08-08 14:04:21
Protection: CSS/CPPM
Data capacity: 7.23 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Then I click the big DVD button and let it scan the disc, only to get messages like this over the course of about 10 minutes:
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Calculated BUP offset for VTS #1 does not match one in IFO header.
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO6KCTB5606' at offset '0'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '0'
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Title #1 (1:48:59) was skipped due to navigation error
Title #2 was added (1 cell(s), 0:06:57)
Title #3 was added (1 cell(s), 0:07:06)
Title #4 was added (1 cell(s), 0:09:07)
Title #5 was added (1 cell(s), 0:08:11)
Title #6 was added (1 cell(s), 0:06:24)
Title #7 was added (1 cell(s), 0:07:21)
Title #8 was added (1 cell(s), 0:07:07)
Title #9 was added (1 cell(s), 0:07:43)
Title #10 was added (1 cell(s), 0:06:56)
Title #11 was added (1 cell(s), 0:07:16)
Title #12 was added (1 cell(s), 0:06:58)
Title #13 was added (1 cell(s), 0:08:13)
Title #17 was added (5 cell(s), 0:37:10)
Title #18 was added (5 cell(s), 0:33:58)
Title #20 in broken titleset was skipped
Title #21 in broken titleset was skipped
Title #22 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22/1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 was added (1 cell(s), 0:13:23)
Title #27 was added (2 cell(s), 0:26:47)
Title #28 was added (1 cell(s), 0:09:53)
Title #29 was added (1 cell(s), 0:16:54)
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while issuing SCSI command A40..035CB830..00CC4 to device 'SPTI:\Device\CdRom0'
At this point it sometimes returns to the Open DVD screen but the big DVD button is now disabled and MakeMKV shows no disc in the drive.
Other times it shows me the list of titles it found, I leave all the titles selected, click the button to start creating the MKVs, and it starts creating the files albeit VERY slowly, like 10 hours for a few hundred MBs. One of the earlier discs took 3 days to complete the MKVs.
Saving 18 titles into directory C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2
More often than not it fails after a single file:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1183744'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '1183744'
Failed to save title 1 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t01.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '0'
Failed to save title 2 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t02.mkv
Failed to save title 3 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t03.mkv
Failed to save title 4 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t04.mkv
Failed to save title 5 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t05.mkv
Failed to save title 6 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t06.mkv
Failed to save title 7 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t07.mkv
Failed to save title 8 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t08.mkv
Failed to save title 9 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t09.mkv
Failed to save title 10 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t10.mkv
Failed to save title 11 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t11.mkv
Failed to save title 12 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t12.mkv
Failed to save title 13 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t13.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '0'
Failed to save title 14 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t14.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '0'
Failed to save title 15 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t15.mkv
Failed to save title 16 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t16.mkv
Failed to save title 17 to file C:/Video/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2/LOONEY TUNES GOLDEN COLLECTION VOLUME 5 DISC 2_t17.mkv
1 titles saved, 17 failed
Still other times, with a disc in, it never even offers to scan the DVD and instead gives me messages like this:
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO6KCTB5606' at offset '524288'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT FAILURE' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO6KCTB5606' at offset '524288'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO6KCTB5606' at offset '1048576'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO6KCTB5606' at offset '32768'
Trouble archiving DVDs with Archgon BU40N drive and 1.0 firmware
Re: Trouble archiving DVDs with Archgon BU40N drive and 1.0 firmware
Likely a power issue since it's happening at 0 alot
Use a higher power USB port or get high powered USB hub 35+ watts
Thank you. I will try that!
[edit]
Actually, I'm connected directly to my PC. I did try my Anker USB hub first. It's 60W USB 3.0.
https://www.amazon.com/Upgraded-Anker-S ... B005NGQWL2
That didn't work any better or worse than the usb ports on the PC
[edit]
Just for grins I tried again after moving the Drive to 2 other USB 3.1 ports on my PC.
Still no dice.
Still no dice.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '5974016'
Encountered 2 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Operation successfully completedRe: Trouble archiving DVDs with Archgon BU40N drive and 1.0 firmware
Try deactivating USB selective power saving in your energy options.
Also try carefully washing the discs as you say they're brand new.
You can also test it with the firmware BU40N 1.03MK.
blind-s33r
Sounds like its quite possibly this issue: https://animesuperhero.com/forums/threa ... d.5799025/
It looks like season 4 and 5 are both affected: https://docs.google.com/document/d/1CyL ... it?tab=t.0
Looney Tunes Gold Coll 5 - Disc 2,Disc 4
Looney Tunes Golden Collection Vol. 2: Disc 3
Looney Tunes Golden Collection Vol. 4 - all four discs have rotted
Looney Tunes Golden Collection Vol. 5 - all four discs have rotted
Damn. Wish I'd seen the Disc Rot thing before I paid $200 for a pioneer player. Oh well.
I've inquired with Warner about getting replacements. Not holding out much hope.
