Married With Children
sn0wleo
Post by sn0wleo »
Hi
I am trying to rip my Married with Children DVD's but after I got to season 8 It doesn't work anymore and after it fails the drive disconnects and I have to unplug it and plug it back in.
This is what the log shows me :
MakeMKV v1.16.4 darwin(x64-release) started
Optical drive "BD-RE ASMedia ASM105x 1.01d" opened in OS access mode.
IFO file for VTS #25 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 was added (5 cell(s), 0:22:52)
Cells 2-end were skipped due to cell commands (structure protection?)
Cells 39-end were skipped due to cell commands (structure protection?)
Title #2/0/1 was added (4 cell(s), 0:21:38)
Cells 1-10 were removed from title start
Cells 38-49 were removed from title end
Title #3/0/1 was added (27 cell(s), 0:22:53)
Cells 44-end were skipped due to cell commands (structure protection?)
Title #4/0/1 was added (4 cell(s), 0:21:38)
Cells 1-11 were removed from title start
Title #5/0/1 was added (26 cell(s), 0:22:51)
Cells 39-50 were removed from title end
Title #6/0/1 was added (28 cell(s), 0:22:38)
Cells 43-54 were removed from title end
Title #7/0/1 was added (31 cell(s), 0:22:53)
Cells 37-48 were removed from title end
Title #8/0/1 was added (26 cell(s), 0:22:52)
Cells 40-end were skipped due to cell commands (structure protection?)
Title #9/0/1 was added (4 cell(s), 0:21:09)
Title #10 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 40960, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 43008, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 45056, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 47104, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 51200, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 53248, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 55296, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 57344, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 18432, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 20480, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 22528, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 24576, attempting to work around
The source file 'BD-RE ASMedia ASM105x 1.01' is corrupt or invalid at offset 26624, attempting to work around
Saving 1 titles into directory /Volumes/Filme/Serien/Married With Children/Season 8
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE ASMedia ASM105x 1.01' at offset '12189696'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk5' at offset '12189696'
Failed to save title 2 to file /Volumes/Filme/Serien/Married With Children/Season 8/title_t02.mkv
Encountered 17 errors of type 'OS X IPC Error' - see http://www.makemkv.com/errors/ipc/
0 titles saved, 1 failed
What can I do to successfully rip the rest of the dvd's ? I have tried 3 different dvd sets now and its the same every time. Other dvd and blu ray work.
Re: Married With Children
It looks like the disc might be dirty or otherwise hard to read and the drive seems to try really hard to read it. Eventually the OS decides the drive doesn't exist anymore.
That's usually what messages like the above mean.
I assume your drive is connected via USB? Sometimes, if the drive is powered by USB (meaning it doesn't have a separate power supply), the drive can try to use more power than the USB port can supply. When this happens, the USB drive shuts down (briefly) and the OS reports the drive has disappeared. The most often happens with either the drive is trying to read data too fast or when the drive is trying very hard to read a dirty spot on the disc.
Is the drive powered by USB? If so, is it connected via a single USB cable? Lots of times there's a 'Y' cable so the drive can be connected via two USB ports with the second plug providing extra power. Is it connected to an unpowered USB hub, a powered USB hub or directly to your computer?
Finally, I've learned that some discs just don't like some drives for reasons I can't explain. I've amassed a collection of 3 different optical drives and almost always if a disc gives me trouble in my 'main' drive, I find it works in one of the other drives. (Not always, of course, but often enough).
sjd101
Post by sjd101 »
See this thread. I can only get a few episodes from Season 8 and 9. 1 to 7 were fine as were 10 and 11. Tried a few different drives but it seems something to so with the discs themselves
viewtopic.php?f=7&t=24918&p=108056&hili ... en#p108056
FirDerrig33
Post by FirDerrig33 »
sjd101 wrote: Tue Sep 21, 2021 10:12 am See this thread. I can only get a few episodes from Season 8 and 9. 1 to 7 were fine as were 10 and 11. Tried a few different drives but it seems something to so with the discs themselves
Which edition of the complete series did you get? I know from recent experience that the edition can make the difference. The Mill Creek version (and the least expensive) is most likely cheaper due to most likely known issue with manufacture.
I have experienced something similar when it came to buying newer editions of TV series with companies attempting to capitalize on nostalgia. This happened to me with Battlestar Galactica, He-Man, and The Pretender. I ended up returning the He-man that I purchased from Best Buy due to bad manufacture and finding one of the first releases of the entire collection of Battlestar Galactica as well.
