failed to open disc
jdog1
failed to open disc
Post by jdog1 »
I am trying to use makemkv on Lord of the Rings Extended Edition DVD and I am getting an error. I turned on the debug logging and got the logs below. What can I do to solve this?
001005:0000 MakeMKV v1.10.8 win(x64-release) started
001003:0020 DEBUG: Code 233 at bxwp/UinWbt+Wm2uDStEDye7:0
Application exited at Fri Dec 08 02:26:59 2017
Re: failed to open disc
The most frequent cause of "failed to open disk" start with dirty/scratched disk. When it fails as quickly as this, the problem is generally close to the hub of the disk, where the directory is kept.
