Man From U.N.C.L.E. Failure
kindredex
Post by kindredex »
MakeMKV v1.9.7 darwin(x86-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-TD03 1.01d" opened in OS access mode.
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00100.mpls was added as title #0
Title #00017.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.m2ts was added as title #1
Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00032.m2ts was added as title #2
Title #00033.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00034.m2ts was added as title #3
Title #00039.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/kindredex/Desktop
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '333447168'
Failed to save title 0 to file /Users/kindredex/Desktop/The_Man_from_U_N_C_L_E_t00.mkv
0 titles saved, 1 failed
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '0'
Saving 1 titles into directory /Volumes/Work HD/Ripping Folder
Failed to save title 0 to file /Volumes/Work HD/Ripping Folder/The_Man_from_U_N_C_L_E_t00.mkv
kindredex
Re: Man From U.N.C.L.E. Failure
Post by kindredex »
I believe I have this error tracked down to El Capitan. I've been having massive issues using MakeMKV and Handbrake since upgrading.
The discs have a tendency to self eject off of the desktop, yielding an error each time.
Will update if I get through this latest rip successfully.
EDIT: DID NOT WORK.
This is VERY weird. This error is consistent with a USB-connected drive being driven to a speed that exceeds its available power supply, but your drive is an internal, according to its model number:
For some reason, it is disconnecting during the rip. After that, it stops responding to commands (USB drives usually reconnect as soon as they slow down).
As an internal drive, it should not have power issues like that. Have you checked its cable connections?
kindredex
Post by kindredex »
Woodstock wrote:This is VERY weird. This error is consistent with a USB-connected drive being driven to a speed that exceeds its available power supply, but your drive is an internal, according to its model number:
It's not internal. I have the latest i7 27" iMac running an external use drive. Like I said, ever since going to El Capitan I have had tons of issues ripping discs.
