Re: Ultimate UHD Drives Flashing Guide Updated 2024
Darkbird wrote: Tue Nov 26, 2024 5:37 pm Hey,
I just got a Hitachi LG BU40N on Firmware Version 1.05 which was encrypted.
I followed the guide and flashed the 1.03MK Firmware from the all you need firmware bundle as recommended in the guide, which seems to have worked fine. I have the following information in MakeMKV:
Laufwerksinformation
OS-Gerätename: F:
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.03
Serienummer: redacted
Firmware-Datum: 2118-10-24 19:34
Markierungen der Bus-Verschlüsselung: 17
Firmware version: 1.03
However, it seems the drive does not read any disks. I've tried DVD, CD, BluRay and 4K BluRay Disks but MakeMKV only says "No Disk Inserted".
It does recognize that I've opened/closed the drive and I can open it from within MakeMKV. Any ideas?
The drive itself does make noise as if reading the disk, however it stops and starts again every now and then.
Did you try it before flashing?
Does the OS see discs without makemkv open?
Have you unplugged it for 5 mins?
Darkbird
Post by Darkbird »
Hi - I had tried it with one disc before flashing, but MakeMKV was open and it wouldn't read, but I discounted that as "must be a firmware issue".
I have tried unplugging it for 5 minutes, that hasn't changed anything.
It also does not read discs when MakeMKV is closed.
I feel like I may have just gotten a defective drive.
Darkbird wrote: Tue Nov 26, 2024 11:23 pm Hi - I had tried it with one disc before flashing, but MakeMKV was open and it wouldn't read, but I discounted that as "must be a firmware issue".
it should have read a regular Bluray without flash all flashing does is enable UHD.
this is one of the many reasons i recommend pioneers they are much better drives see below if your in the usa.
marty and asmcom also have pioneers available for other country's.
Darkbird
Post by Darkbird »
Yeah, I'll see if I can't flash/recover the 1.05 Firmware and get a refund from Amazon on the drive, enclosure and SATA adapter (the enclosure wouldn't let me flash).
Thanks for the help!
source22
Post by source22 »
hello all,
HeLp...help.. please
where can I find the firmware for a BDR-XS07UHDv to enable Libra ?
trying to rip mkv files...
Info: Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: [redacted]
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 47
Firmware version: ID05
Thanks in advance..... :)
source22 wrote: Thu Nov 28, 2024 1:45 am hello all,
Revision: 1.03
sorry man cant that fw is to new cant be flashed.
return it if you can
i have some pioneers with old fw if you want one
source22
Post by source22 »
What the fast drive I can buy that works or firmware that will make it work ?
Caus5150
Post by Caus5150 »
Can the LG BH30N Be Flashed? I just found one at the goodwill
source22 wrote: Thu Nov 28, 2024 3:10 am What the fast drive I can buy that works or firmware that will make it work ?
Fast, dying early and skipping sectors of hard to read discs: LG, Safe, durable: Pioneer with old firmware. Your choice.
Caus5150 wrote: Thu Nov 28, 2024 6:39 pm Can the LG BH30N Be Flashed? I just found one at the goodwill
No. BD only drive. No UHD option.
Deterous
Post by Deterous »
Sleep bug on UHD friendly drives is fixed when flashing WH16NS60 1.02MK, but the Asus BW-16D1HT is recommended to be flashed with Asus BW-16D1HT 3.10MK.
Does this mean the 16D1HT isn't compatible with WH16NS60 1.02MK, and that the Asus is stuck with the sleep bug?
Also, does WH16NS60 1.02MK firmware have any known quirks as a result of the firmware expecting the AACS decoder subsystem on the drive?
Deterous wrote: Fri Nov 29, 2024 2:35 pm Sleep bug on UHD friendly drives is fixed when flashing WH16NS60 1.02MK, but the Asus BW-16D1HT is recommended to be flashed with Asus BW-16D1HT 3.10MK.
1. The Asus firmware is only recommended for the Asus drive if you still want to write discs. If you don't care about writing discs, use WH16NS60 1.02-MK.
2. No quirks.
In addition:
1) The ASUS firmware has the sleep bug but it hasn't "jamless play" when the LG firmware skips sectors of hard to read discs.
2) To get around all these issues get a Pioneer drive from a seller or PM me. Retail drives don't work anymore.
source22
Post by source22 »
Billycar11 wrote: Thu Nov 28, 2024 2:33 am
Revision: 1.03
will they work for 4k UHD ? I just got the wp50nb40 and it seem it doesnt read 4kUDH .....?
what is the solution ?
Thank you in advance
source22 wrote: Sat Nov 30, 2024 12:48 am
read the guide... right here or see below and email me for a flasher
