LG BH16Ns40 UHD Friendly
horrorfiend666
#1 Post by horrorfiend666 » Thu Nov 19, 2020 6:05 pm
WHat do i need to do to make LG BH16Ns40 UHD Friendly and bale to read uhd discs?
st4evr
Re: LG BH16Ns40 UHD Friendly
#2 Post by st4evr » Thu Nov 19, 2020 7:46 pm
Read the pinned guides/info post in the respective forum sections. They are there to help answer these very common questions and help avoid problems/headaches where possible:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Forum search function will also return plenty of discussion on this as well and may help find answers quickly as well. Use it:
https://www.makemkv.com/forum/search.ph ... s=BH16Ns40
horrorfiend666
#3 Post by horrorfiend666 » Fri Nov 20, 2020 5:04 pm
just realized my drive is a 2014 model i tried flashing it but now i cant read dvds or blurays
#4 Post by d00zah » Fri Nov 20, 2020 5:40 pm
So you missed the part:
IMPORTANT Before you flash:
1. Make sure your Drive was built after 2015
2. Drive Platform MT1959<Most important
3. SVC NS50+ LG only
4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
from the stickie st4evr provided a link to?
horrorfiend666
#5 Post by horrorfiend666 » Fri Nov 20, 2020 6:35 pm
SO i attempted to recover the drive using the winpe image provided and using dosflash but drive still will not recognize any discs
st4evr
#6 Post by st4evr » Fri Nov 20, 2020 7:39 pm
Try the SDFtool method linked towards the bottom of this post:
https://www.makemkv.com/forum/viewtopic ... 16&t=23644
horrorfiend666
#7 Post by horrorfiend666 » Fri Nov 20, 2020 8:21 pm
ok the sdf tool worked but still can not read discs as no discs are recognized in system
#8 Post by d00zah » Fri Nov 20, 2020 8:49 pm
Try this FW w/ the SDFTool. And are you rebooting the system after flashing?
BH16NS40_1.03-A0_NOBJ_DE.zip
horrorfiend666
#9 Post by horrorfiend666 » Fri Nov 20, 2020 8:53 pm
getting command produced error code 0x8e0001f5
#10 Post by d00zah » Fri Nov 20, 2020 9:21 pm
Hmm. That was the extracted binary for LG BH16NS40 NS40 direct from LG... vintage 2014.
I find no other references to that error code searching the forum. I'm at a loss.
horrorfiend666
#11 Post by horrorfiend666 » Fri Nov 20, 2020 9:29 pm
weird right? I even used the 1.03 from lg them selves that official updater worked with out issues but no discs want to be read or the system doesn't recognize there is a disc in the drive .... Going to have to convince the wife to let me purchase a WH16NS60
#12 Post by d00zah » Fri Nov 20, 2020 9:42 pm
One of the "pros"... Billycar11, jonghotti, MartyMcNuts, et al... may yet wander by with a suggestion.
#13 Post by Billycar11 » Fri Nov 20, 2020 9:51 pm
Well if they didn't do the win pe dos flash thing right
Like not move the cal data over by using the data mover tool they may have flashed a drive now with blank cal data so it will never read discs again now.
But some people have reported success using someone else's cal data but that is on mt 1959 I have not see anyone say that for mt1939 but there.
But if you did not use the data mover tool and just flashed the unmodified old image it won't hurt to try as you can't hurt it anymore
st4evr
#14 Post by st4evr » Fri Nov 20, 2020 10:18 pm
It may be fully bricked. If in the end not even the SDFTool can’t fix it as advised by Billy, move on and buy a new drive. And as we have advised countless of times by now in this forum, next time pay attention, to avoid going through this all over again.
asmcom
#15 Post by asmcom » Fri Nov 20, 2020 10:24 pm
Glad to hear you are already sorted out.
Asmcom :mrgreen:
