LG BH16Ns40 UHD Friendly
WHat do i need to do to make LG BH16Ns40 UHD Friendly and bale to read uhd discs?
Re: LG BH16Ns40 UHD Friendly
Read the pinned guides/info post in the respective forum sections. They are there to help answer these very common questions and help avoid problems/headaches where possible:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Forum search function will also return plenty of discussion on this as well and may help find answers quickly as well. Use it:
https://www.makemkv.com/forum/search.ph ... s=BH16Ns40
just realized my drive is a 2014 model i tried flashing it but now i cant read dvds or blurays
So you missed the part:horrorfiend666 wrote: ↑Fri Nov 20, 2020 5:04 pmjust realized my drive is a 2014 model i tried flashing it but now i cant read dvds or blurays
IMPORTANT Before you flash:
1. Make sure your Drive was built after 2015
2. Drive Platform MT1959<Most important
3. SVC NS50+ LG only
4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
from the stickie st4evr provided a link to?
SO i attempted to recover the drive using the winpe image provided and using dosflash but drive still will not recognize any discs
Try the SDFtool method linked towards the bottom of this post:
https://www.makemkv.com/forum/viewtopic ... 16&t=23644
ok the sdf tool worked but still can not read discs as no discs are recognized in system
Try this FW w/ the SDFTool. And are you rebooting the system after flashing?horrorfiend666 wrote: ↑Fri Nov 20, 2020 8:21 pmok the sdf tool worked but still can not read discs as no discs are recognized in system
getting command produced error code 0x8e0001f5
Hmm. That was the extracted binary for LG BH16NS40 NS40 direct from LG... vintage 2014.
I find no other references to that error code searching the forum. I'm at a loss.
weird right? I even used the 1.03 from lg them selves that official updater worked with out issues but no discs want to be read or the system doesn't recognize there is a disc in the drive .... Going to have to convince the wife to let me purchase a WH16NS60
One of the "pros"... Billycar11, jonghotti, MartyMcNuts, et al... may yet wander by with a suggestion.
Well if they didn't do the win pe dos flash thing right
Like not move the cal data over by using the data mover tool they may have flashed a drive now with blank cal data so it will never read discs again now.
But some people have reported success using someone else's cal data but that is on mt 1959 I have not see anyone say that for mt1939 but there.
But if you did not use the data mover tool and just flashed the unmodified old image it won't hurt to try as you can't hurt it anymore
It may be fully bricked. If in the end not even the SDFTool can’t fix it as advised by Billy, move on and buy a new drive. And as we have advised countless of times by now in this forum, next time pay attention, to avoid going through this all over again.
Glad to hear you are already sorted out.
Asmcom
Asmcom
