All 4K Releases Spreadsheet
Cannikin
I took the list from https://thedigitalbits.com/columns/the- ... hd-list-01 and converted it to a spreadsheet so it's easier to sort and compare disc features. Enjoy!
https://docs.google.com/spreadsheets/d/ ... PAH7i3dStM
Procat
Re: All 4K Releases Spreadsheet
Just wanted to say thank you for the list
henkeli
Excellent, thank you.
xmenw
Awesome, thank you!
asmcom
Thank you for the very useful spread sheet.
Asmcom
Asmcom
snafu_
Thank you. This is a very handy reference.
Though I'm not clear on what the "Reference" and "Standout" columns mean?
Cannikin
I copied those over from the site—I think they mean that the audio/video should be considered "reference" quality, or slightly below that at "standout" quality. Otherwise it's just an average 4k presentation.snafu_ wrote: Thu Sep 10, 2020 2:24 pm Thank you. This is a very handy reference.
preserve
Thank you very much for this! This is super helpful for my #1 question as I'm slowly starting a 4K collection of my favorite films - is it Native 4K? This spreadsheet format is perfect, SO much better than the list format over at Digital Bits. I hope DB will continue to update and that you'd consider keeping this updated as well.
Using: ASUS BW-16D1HT 3.00
NiCE77
Dolittle has Dolby Vision track too: https://www.blu-ray.com/movies/Dolittle ... ay/260609/
Cannikin
Just updated the list! I'll track the changes using the tabs you'll see at the bottom of the page. The tab is named with the date the list was created.
Tonight's update added 41 movies (including Lord of the Rings and Hobbit 4k!). I also moved the release date and studio to the far right as it was annoying for me personally—I really just care about the features so I can tag them correctly in Plex.
I don't know that my converter is absolutely perfect (and the list on thedigitalbits.com may not be perfect either) so let me know if you see some features missing or checked on/off when they should/shouldn't be.
Cannikin
Updated the list to include DV on Dolittle!NiCE77 wrote: Sat Sep 26, 2020 6:45 am Dolittle has Dolby Vision track too: https://www.blu-ray.com/movies/Dolittle ... ay/260609/
Cannikin
Made the scraper code available here: https://github.com/cannikin/4klist
Cannikin
I added some Filter Views to get quick access to only those discs that match certain criteria. You can access them from the Data menu:
Cannikin
Just updated the list to move "The" at the start of titles to the end. ie. "The Meg" -> "Meg, The"
preserve
