Hi everyone,
I have created a windows GUI for the MakeMKV sdftool command line flasher. The appearance (and use) is similar to the modifed ASUS flasher, which should make it a bit easier for those that are unsure about using the command line. The latest version is v1.3.6.
NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
UPDATE -11/02/2025:
Just some minor bug fixes. If you have issues using this release, please use the previous version. Download links for both are at the bottom of this post.
UPDATE -22/12/2022:
This update fixes the string error for the Buffalo drives.
UPDATE -02/07/2022:
This update should fix the encrypted firmware detection for the new ASUS BW-16D1HT 3.11 firmware.
UPDATE - 21/03/2022:
This update fixes the encrypted firmware detection issue with ASUS drives.
UPDATE - 02/03/2022:
This update has some improvements of the encrypted firmware detection.
UPDATE - 08/01/2022:
In the latest update, I have re-enabled the selectable encrypted firmware option for you just in case you need it. On the rare occasion the automatic encryption check is incorrect, simply click the ✔ or ✖ to toggle it.
UPDATE - 21/12/2021:
The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive, although, currently there's really no need to use it.
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
This is a multi-step procedure. Watch the gif below, then watch it again!!
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
After a successful flash to the MK firmware of the drive do the crossflash:
2. Select the RECOVERY option and in the pop up window (as per the window title text), select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed and click OPEN.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal firmware selection drop box (as per the window title text) then click OPEN.
4. Click START
Here's a visual aid for you:
UPDATE - 26/09/2021:
The latest version of the SDFtool Flasher will automatically check for both the MT1959 Drive Platform and Encrypted Firmware. It also removes the requirement for .net framework as .net 6.0 is built in to the executable.
UPDATE - 26/09/2020:
I have made a couple of minor code adjustments. Also, the "RECOVER Drive" option feature is now available. I have used it to recover a BH16NS55 that was flashed with BU40N firmware.
Requirements:
  • Windows 10 64 bit version or Windows 11 64 bit version
  • MakeMKV installed in the default location (from version 1.15.1 up to version 1.18.4) DO NOT use version 2.0.0!
  • Ensure there is no disc in the drive and the tray is closed
  • .NET Framework 4.7.2 **only for SDFtool Flasher v1.2.0**
  • A compatible drive: IE:- MT1959 drive platform and manufactured from 2016+
Usage:
  • Make sure the drive is empty and tray is closed.
  • Select a drive from the first drop down box.
  • Select either WRITE, READ or RECOVER option (write is default).
  • (FYI, the HBD firmware for BP50NB40 is now obsolete as SDFtool Flasher can flash the BP50NB40/WP50NB40 and BP60NB10 drives).
If you selected READ:
You can now press the START button to dump the firmware. The application will create a folder called "Firmware_Dumps" in the same directory as the sdftool flasher, if it does not exist and save the dump file there. It will do a full firmware dump if it is able to otherwise it will only dump the user data.
If you selected WRITE:
  • Click the firmware selection drop down box to select a firmware to flash.
  • If your drive has an encrypted firmware (from 2020+) ensure there is a green tick for "Encrypted firmware" (see list of encrypted firmware below).
You can now press the START button to flash the selected firmware to your drive. Once the firmware has been flashed successfully, the application will refresh the drive list shown in the drop down box.
If you selected RECOVER:
  • A "file browser" will immediately popup so you can select the drive's current (wrong) firmware. This is so the boot ID can be obtained.
  • Click the normal firmware selection drop down box to select the correct firmware to flash.
You can now press the START button to recover the drive and flashing the selected firmware to your drive. Once the firmware has been flashed successfully, the application will refresh the drive list shown in the drop down box.
Encrypted Firmware:
HL-DT-ST-BD-RE_BE16NU50-1.04-N000300-212005081025.bin
HL-DT-ST-BD-RE_BH14NS50-1.03-N000400-212004211008.bin
HL-DT-ST-BD-RE_BH16NS40-NS50-1.05-N000600-212005061331.bin
HL-DT-ST-BD-RE_BH16NS50-1.03-N000400-212004210958.bin
HL-DT-ST-BD-RE_BH16NS55-1.05-N000400-212004211049.bin
HL-DT-ST-BD-RE_BH16NS60-1.02-N000600-212005081014.bin
HL-DT-ST-BD-RE_BP50NB40-NB52-1.03-N000300-212107081603.bin
HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-N000800-212005070917.bin
HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-N000800-212005070924.bin
HL-DT-ST-BD-RE_BP60NB10-1.02-N000800-212005070935.bin
HL-DT-ST-BD-RE_BP60NB10-NB12-1.02-N000300-212107081556.bin
HL-DT-ST-BD-RE_BU40N_1.02_212012011716_MO3L91F0715.bin
HL-DT-ST-BD-RE_BU40N-1.04-N000500-212005061142.bin
HL-DT-ST-BD-RE_BU40N-BN13-0002300-212009251104.bin
HL-DT-ST-BD-RE_BU40N-BN14
HL-DT-ST-BD-RE_BU40N-BU13
HL-DT-ST-BD-RE_BU40N-BU14
HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-N000900-212005061444.bin
HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-N000900-212005061440.bin
HL-DT-ST-BD-RE_WH16NS60-1.03-N000600-212005081010.bin
HL-DT-ST-BD-RE_WP50NB40-NB50-1.03-N000800-212005070929.bin
HL-DT-ST-BDDVDRW_CH12NS40-1.03-N000800-212005080957.bin
HL-DT-ST-BDDVDRW_UH12NS40-1.03-N000800-212005080959.bin
ASUS-BW-16D1HT-3.11
ASUS-BC-12D2HT-3.12
If your desktop drive has encrypted firmware, flash WH16NS60 1.02-MK first, then you can either leave it as is or flash any other desktop drive firmware if you want to.
If your external Buffalo / Archgon / LG BU40N has encrypted firmware, flash BU40N 1.03-MK first, then you can either leave it as is or flash BU40N 1.00 or Buffalo BU / BN firmware if you want to.
IMPORTANT!!! DO NOT flash desktop firmware to a slim drive or vice-versa.
WARNING: Use at your own risk!!
Please be very careful using the recovery option. It should work for:
  • Desktop drive's flashed to slim drive firmware.
  • Slim drives flashed to desktop drive firmware.
  • Old LG/ASUS drives that have been flashed with newer LG NS50+/ASUS 3.xx firmware.
Here is the link for the current version (v1.3.6) of SDFtool Flasher
https://www.mediafire.com/file_premium/ ... 9.zip/file
Here is the link for the previous version (v1.3.5) of SDFtool Flasher
https://www.mediafire.com/file/rak1mk0p ... ).zip/file
Just unzip it in the same directory as your firmware files or anywhere else you like.
Here is the link to my "All You Need Firmware Pack"
https://www.mediafire.com/file/bpl3pz2b ... ).zip/file
As usual, any issues with the GUI, let me know.
PS: For your convenience, you can find the old, original SDFtool Flasher and the firmware files to recover the old LG/ASUS drives here:
viewtopic.php?p=202078#p202078
Enjoy!! 8)
Last edited by MartyMcNuts on Fri Sep 25, 2026 10:55 pm, edited 56 times in total.
Re: SDFtool Flasher
Post by SamuriHL »
Awesome work as always!
Re: SDFtool Flasher
SamuriHL wrote: Tue Aug 18, 2020 3:50 am Awesome work as always!
Thanks SamuriHL! :D
Re: SDFtool Flasher
Fantastic! :D :D
Bluntman
Re: SDFtool Flasher
Post by Bluntman »
MartyMcNuts wrote:Hi everyone,
Usage:
  • Select either READ or WRITE option (write is default)
  • Click the second drop down box to select a firmware to flash
  • Check the "enc?" checkbox only if your drive has an encrypted firmware on it
Here is the SDFtool flasher:
sdftool_flasher.zip
Enjoy!! 8)
Awesome Marty this is great!!! Thanks so much for the good work. I’ll definitely use this for the next drive I sell!
Thank again wow great!
Re: SDFtool Flasher
You're welcome guys! Glad to help. :D
kastaway33
Re: SDFtool Flasher
Post by kastaway33 »
If I accidentally flashed the 1.03MK firmware on my LG WH16NS60 drive can I use "SDFtool Flasher" to Flash the 1.02MK file (see screenshot)? Will I need to choose the ENC button since its 1.03?
Thank You
asmcom
Re: SDFtool Flasher
Post by asmcom »
Great work Marty as always.
Asmcom :mrgreen:
Re: SDFtool Flasher
kastaway33 wrote: Sat Aug 22, 2020 3:18 pm If I accidentally flashed the 1.03MK firmware on my LG WH16NS60 drive can I use "SDFtool Flasher" to Flash the 1.02MK file (see screenshot)? Will I need to choose the ENC button since its 1.03?
Thank You
It is my understanding that no MK firmware is encrypted,so your current firmware is not encrypted, therefore, no. Yes, that highlighted file is 1.02-MK.
Please, someone correct me if I am wrong..
kastaway33
Re: SDFtool Flasher
MartyMcNuts wrote: Sat Aug 22, 2020 11:44 pm
Thank You
Thank you for replying to my question, so if my drive was flashed with 1.03mk, can I use SDFtool to flash to 1.02mk? And basicly no need to mark it "ENC"...
Re: SDFtool Flasher
kastaway33 wrote: Tue Aug 25, 2020 6:26 am
Thank You
Correct.
allomere
Re: SDFtool Flasher
Post by allomere »
Thank you for this helpful tool! Quick question: Can it flash drives via USB, or do they have to be connected via a SATA cable?
Re: SDFtool Flasher
Post by SamuriHL »
It can flash USB drives with the caveat that the case it's in (if it's in a case) supports the flashing commands.
MiKeeVid
Re: SDFtool Flasher
Post by MiKeeVid »
I'm getting this error message and not sure what the issue is. I'm wanting to flash to WH16NS60-1.02 MK to get rid of the sleep bug (I got the same error message when I tried that version of firmware.)
Here's my drive info:
Product: BD-RE WH16NS40
Revision: 1.02
Serial number: SIK9THADA***
Firmware date: 2117-03-10 16:50
Highest AACS version: 72
Firmware version: 1.02
Re: SDFtool Flasher
MiKeeVid wrote: Fri Aug 28, 2020 11:39 pm I'm getting this error message and not sure what the issue is. I'm wanting to flash to WH16NS60-1.02 MK to get rid of the sleep bug (I got the same error message when I tried that version of firmware.)
Revision: 1.02
OK, if you want to flash to WH16NS60 1.02-MK, why are you trying to flash firmware WH16NS40-NS50 1.03 MK????
Your drive is on WH16NS40 1.02 so you should be able to directly flash WH16NS60 1.02-MK firmware and be done!
