LG WH16NS40 1.04+
tcoker79
LG WH16NS40 1.04+
Post by tcoker79 »
I've downloaded the MK firmware pack but can't find the 1.04 to sideload. What am I missing?
Re: LG WH16NS40 1.04+
tcoker79 wrote: Wed Mar 11, 2020 1:53 am I've downloaded the MK firmware pack but can't find the 1.04 to sideload. What am I missing?
Flash WH16NS60 1.02 mk
tcoker79
Post by tcoker79 »
Thank you
Locksmythe
Post by Locksmythe »
For the same drive preloaded with 1.04, is it recommended to leave the drive on this H16NS60 1.02 mk or is that an interim step? I had originally intended to load the H16NS60 1.00 firmware but never got around to installing the drive. Now I am trying to catch up and advice seems to have changed. There is a different conversation going in the main Libredrive MK thread.
Locksmythe wrote: Tue Apr 07, 2020 8:30 pm For the same drive preloaded with 1.04, is it recommended to leave the drive on this H16NS60 1.02 mk or is that an interim step? I had originally intended to load the H16NS60 1.00 firmware but never got around to installing the drive. Now I am trying to catch up and advice seems to have changed. There is a different conversation going in the main Libredrive MK thread.
If you only use makemkv then leave it on 1.02 if you use other rippers put it on 1.00
asmcom
Post by asmcom »
I am currently testing a development 1.04mk version for the WH16NS40 drive.
So far everything is good and the drive is very smooth with good performance.
I will PM you when I finish testing and let you know how I got on with the new firmware.
Asmcom
