For the 1000th time that drive does not work with uhd12NightRider34 wrote: Tue Mar 17, 2020 8:53 am I'm considering the "ASUS BW-16D1H-U Pro Extreme 16X USB 3.0 Blu-Ray Writer" https://www.mwave.com.au/product/asus-b ... er-ab84784 for UHD ripping. Does anyone have any experience flashing it? It seems to be a close cousin to the recommended ASUS BW-16D1HT. Do I need any special connections to do firmware updates or is the USB connection fine? Thanks in anticipation.
Recommended drives (2019)
Re: Recommended drives (2019)
jonghotti
He's right for the 1,000th time, it won't work.
If you need a drive in Australia please see Marty!
Cheers!jonghotti wrote: Wed Mar 18, 2020 5:39 pm He's right for the 1,000th time, it won't work.
dp5081
How do I use the libre drive on a mac
by using makemkv and have a compatible drive
dp5081
what folder do i put the bin file in for this to work is what I'm asking
st4evr
That’s not how this works. If you are unsure what Libredrive is and how it works, then it’s time you take time to educate yourself on it.dp5081 wrote: Sun Apr 05, 2020 9:51 pm what folder do i put the bin file in for this to work is what I'm asking
Start here:
https://www.makemkv.com/forum/viewforum.php?f=19
There are plenty of discussions there regarding this including detailed explanations directly from the MakeMKV developer himself. You have to do some reading/research on your end.
dp5081
well thank you, you don't have to be condescending i'm only asking for help.
SnowDog
No offence, but are you on here for any purpose other than to be offensive to anyone who posts?st4evr wrote: Sun Apr 05, 2020 10:25 pmThat’s not how this works. If you are unsure what Libredrive is and how it works, then it’s time you take time to educate yourself on it.dp5081 wrote: Sun Apr 05, 2020 9:51 pm what folder do i put the bin file in for this to work is what I'm asking
Start here:
I mean, this is a HELP forum, and yet 'help' seems to be pretty much bottom of your list of priorities. Top seems to be trying to show everyone how you're the loudest cockerel in the henhouse.
What you're seeing is frustration over people asking the same question over and over and over and over again, thinking their particular variation of the question is completely different from the 47 other variations. Or, the person asking doesn't feel obliged to do a simple search to find out that there are 50 responses to their question, some on the front page of the forum.
This particular topic is redundant, for example, because this one is maintained by people who know the answers to "which is the best for UHD?" because someone wasn't looking for UHD capability; It's mostly the same answers, since the UHD-friendly drives can do non-UHD as well. The older topic keeps current information at the start of the topic, so you don't have to dig through to the end.
asmcom
Please PM or email me. I offer a hand of help.I am not looking anything only to assist you.dp5081 wrote: Sun Apr 05, 2020 11:10 pm well thank you, you don't have to be condescending i'm only asking for help.
You can email me if you want. I will do my best to help you.
Happy to try and solve any issues you have.
Asmcom
viewtopic.php?f=20&t=19387
