LG WH16NS40 1.04+
LG WH16NS40 1.04+
I've downloaded the MK firmware pack but can't find the 1.04 to sideload. What am I missing?
Re: LG WH16NS40 1.04+
Flash WH16NS60 1.02 mktcoker79 wrote: Wed Mar 11, 2020 1:53 am I've downloaded the MK firmware pack but can't find the 1.04 to sideload. What am I missing?
Locksmythe
For the same drive preloaded with 1.04, is it recommended to leave the drive on this H16NS60 1.02 mk or is that an interim step? I had originally intended to load the H16NS60 1.00 firmware but never got around to installing the drive. Now I am trying to catch up and advice seems to have changed. There is a different conversation going in the main Libredrive MK thread.
If you only use makemkv then leave it on 1.02 if you use other rippers put it on 1.00Locksmythe wrote: Tue Apr 07, 2020 8:30 pm For the same drive preloaded with 1.04, is it recommended to leave the drive on this H16NS60 1.02 mk or is that an interim step? I had originally intended to load the H16NS60 1.00 firmware but never got around to installing the drive. Now I am trying to catch up and advice seems to have changed. There is a different conversation going in the main Libredrive MK thread.
I am currently testing a development 1.04mk version for the WH16NS40 drive.tcoker79 wrote: Wed Mar 11, 2020 1:53 am I've downloaded the MK firmware pack but can't find the 1.04 to sideload. What am I missing?
So far everything is good and the drive is very smooth with good performance.
I will PM you when I finish testing and let you know how I got on with the new firmware.
Asmcom
