IT Chapter 2
perrycho
IT Chapter 2
Post by perrycho » Mon Dec 09, 2019 1:29 am
IT chapter two dump file sent
perrycho
Re: IT Chapter 2
Post by perrycho » Mon Dec 09, 2019 11:09 pm
Thanks so much Mike, works perfectly now.
vercetti757
Re: IT Chapter 2
Post by vercetti757 » Wed Dec 11, 2019 10:21 pm
I just tried and was not able to decrypt my copy. I sent in my dump files for the Best Buy USA Steelbook variant. Thank you as always to the developers!
vercetti757
Re: IT Chapter 2
Post by vercetti757 » Mon Dec 16, 2019 5:19 am
Wanted to say thank you! i was able to rip my copy successfully tonight.
MRX_BD_07
Re: IT Chapter 2
Post by MRX_BD_07 » Mon Sep 04, 2023 12:26 pm
I thought I will just post it here, not opening a new thread for this...
Has anyone noticed the broken HDR metadata on that disc? Or is this specific to my german copy of that movie?
The first second or so has the following metadata:
mastering display minLum: 0.005 nit and maxLum 4000 nit, no maxCLL or maxFALL
The rest of the movie...
mastering display minLum: 0.0001 nit and maxLum 1000 nit, maxCLL 1052 nit and maxFALL 400 nit
My BluRay player just sends 0.005/4000 to the TV when playing the disc, madVR and mpv the 0.0001/1000 + maxCLL/maxFLL to the TV...
When playing back a sample mkv of that movie (first second cut off) the BD player also sends the correct (?) 0.0001/1000 metadata to the TV.
I checked this with my hdfury device and also mpv with vo=gpu-next. The newest version will show the metadata in the info overlay (opened by hitting i)
Can someone confirm this with a different rip? Thanks!
Badboyztn
Re: IT Chapter 2
Post by Badboyztn » Mon Jun 01, 2026 4:35 pm
perrycho wrote: Mon Dec 09, 2019 1:29 am IT chapter two dump file sent
I'm having the same issue. How do you do a file dump?
Re: IT Chapter 2
Post by dcoke22 » Mon Jun 01, 2026 7:55 pm
Badboyztn wrote: Mon Jun 01, 2026 4:35 pm
MakeMKV will create a .tgz file automatically when it does not have the necessary key to decrypt a disc. It puts the file in the MakeMKV data directory as defined on the General tab of MakeMKV's preferences.
Badboyztn
Re: IT Chapter 2
Post by Badboyztn » Mon Jun 01, 2026 10:31 pm
Right, but do I need to submit anything here in order for that to happen. It's the second copy I have bought and neither would rip.
MrPenguin
Re: IT Chapter 2
Post by MrPenguin » Mon Jun 01, 2026 11:26 pm
Badboyztn wrote: Mon Jun 01, 2026 10:31 pm Right, but do I need to submit anything here in order for that to happen. It's the second copy I have bought and neither would rip.
You need to email that TGZ dump file to svq@makemkv.com. And if you would like to add your disk to the public KEYDB.cfg file as well, you could also upload that TGZ file into a file host such as Google Drive or OneDrive, and then reply here with a public download link.
Badboyztn
Re: IT Chapter 2
Post by Badboyztn » Tue Jun 02, 2026 1:38 pm
Below is what I get in the log window. I have searched for the .tgz file and I can't find it. I went to finder, Show hidden files: Press Command + Shift + . (the period/full stop key) on your keyboard. This will reveal hidden folders (their names will appear slightly grayed out).Locate the folder: Look for the folder named .MakeMKV.Find your file: Open the .MakeMKV folder to find your .tgz dump file. I don't have a folder named .MakeMKV.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '25211762688'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '25211762688'
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '25211762688'
Failed to save title 0 to file /Users/Chaunceybland/Desktop/4K Movies/IT Chapter Two_t00.mkv
Encountered 6 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
MrPenguin
Re: IT Chapter 2
Post by MrPenguin » Tue Jun 02, 2026 1:49 pm
Badboyztn wrote: Tue Jun 02, 2026 1:38 pm Below is what I get in the log window. I have searched for the .tgz file and I can't find it. I went to finder, Show hidden files: Press Command + Shift + . (the period/full stop key) on your keyboard. This will reveal hidden folders (their names will appear slightly grayed out).Locate the folder: Look for the folder named .MakeMKV.Find your file: Open the .MakeMKV folder to find your .tgz dump file. I don't have a folder named .MakeMKV.
These errors suggest that MakeMKV can already decrypt your disk, and so it will not have created a TGZ dump file. It actually looks like your UHD drive cannot read a section of the file '/BDMV/STREAM/00006.m2ts' correctly, which means the first thing to try would be cleaning the disk. And perhaps try using a second UHD drive, if you have one.
Badboyztn
Re: IT Chapter 2
Post by Badboyztn » Tue Jun 02, 2026 2:51 pm
Great, thanks for the update.
