External Enclosure UK
Hopest
Post by Hopest » Sun Aug 04, 2019 8:14 am
Just ordered a Asus BW-16D1HT and looking for an external enclosure. Live in the UK and for some reason unless I'm being daft can't find a decent choice?
Most people are referring to https://www.amazon.co.uk/Vantec-externa ... B01MRUN0HQ but not available anymore.
Any advice from people already done this?
Many Thanks in advance,
Tom
Re: External Enclosure UK
Post by MartyMcNuts » Sun Aug 04, 2019 11:41 pm
Tom
Contact user "asmcom". He may be able to help you out!
asmcom
Post by asmcom » Tue Aug 06, 2019 6:42 pm
https://www.makemkv.com/forum/viewtopic ... 20&t=19387
PM me and I should be able to help you out?
Asmcom
gerudosun
Post by gerudosun » Tue Sep 10, 2019 1:48 am
For anyone else looking for something different than the Vantec I just got my first UHD friendly drive and put it in a Mercury Pro from OWC. I was hesitant but ended really liking this enclosure its very solid and looks great.
https://www.amazon.co.uk/OWC-Mercury-Ex ... 282&sr=8-1
Post by MartyMcNuts » Tue Sep 10, 2019 5:08 am
There is also the RaidSonic ICY BOX IB-550StU3S
https://www.ebay.com.au/itm/RaidSonic-I ... 1438.l2649
GazzaC
Post by GazzaC » Mon Sep 23, 2019 9:25 am
I'm between PC's at the moment (rebuilding) and so using my laptop. My excellent UHD friendly Asus 16D1HT (Firmware 3.01) which is normally connected directly via SATA is currently sitting in a box. Am I right in thinking as its already UHD friendly that the USB connection, if I install to an enclosure such as this, works exactly as a SATA connection does, in the sense that I've no 'tweaking' to do - it simply works and MKV sees it if as it's connected via SATA? If so I may well connect via USB when the PC is rebuild rather than reinstall in the PC case itself. But I do not want to buy the (expensive) enclosure if MakeMKV 'sees' the drive differently and I have to faff around to get it to work. Thanks
BlueMac77
Post by BlueMac77 » Mon Sep 23, 2019 3:36 pm
Yes MakeMKV works well with the external enclosure OWC Mercury Pro as USB 3.0 as Plug N Play, no additional tweaking needed. I’m using an Asus 16D1HT drive in an OWC Mercury Pro external enclosure and works perfectly.
GazzaC
Post by GazzaC » Tue Sep 24, 2019 8:58 pm
Excellent, many thanks for confirming, got the enclosure winging its way to me now!
