I have exactly the same issue as previous post.
I have BW-16D1HT running 1.01
This will NOT upgrade firmware, says
Your optical drive firmware is up to date.
Can anyone help.
Trevor
clickmanf22
Your drive is too old! Do not flash it. The newer versions start with firmware 3.00. Since your drive is on 1.01, I am certain it is older than 2016.clickmanf22 wrote: Tue May 07, 2019 11:04 am I have exactly the same issue as previous post.
Can anyone help.
Trevor
jonghotti
Where is the most recent modified LG flasher kept please? Also, is there a firmware dump cleaning tool handy?
As in I've dumped the firmware from <a certain drive that did not have support> and wanted to clean the calibration data off of it before passing it out.
Thank you!
Thank you!
Here's the dump cleaner.jonghotti wrote: Tue May 07, 2019 5:24 pm Where is the most recent modified LG flasher kept please? Also, is there a firmware dump cleaning tool handy?
Thank you!
eqman
me too.rabside wrote: Fri May 03, 2019 8:59 pm Hi,
I just bought a BC-12D2HT drive that uses 3.11 fw.
I've tried your tool but it doesn't work, always failure #4. maybe a 3.11 patched fw is needed ?
Can you help me to downgrade the fw?
thanks a lot
Who can help us downgrade the fw?
thanks a lot
Chasetheace
If you don't mind me asking what can a BU40N be cross-flasshed to.
(edit by Mike): Guys, please...
Thank youi= i would appeciate to know please as I now have a BU40N
asmcom
You would be better taking this down Chase as both you and Alex could end up getting banned. Don't say I did not warn you. Just PM Marty and he will answer your Question . He has been okay with me give him try. Tell him about you condition first.
Hope you are keeping good. Any modification on the flasher Marty is the person to speak to.
You shouldn't cross flash a bu40n there are 3 main firmwares for it.Chasetheace wrote: Wed May 08, 2019 2:04 pm If you don't mind me asking what can a BU40N be cross-flasshed to. Th last time I asked a question like this and where I coul;d buy one cheap I got this answer:
1.00de from me or Marty ,works with all rippers that support bu40n
1.03mk from Mike
And bu10de if you want it to be a buffalo drive ,works with all rippers that support bu40n
I recommend 1.00de or 1.03mk
eqman
Where can I download flash asus 3.10 mk ?Billycar11 wrote: Fri May 03, 2019 9:42 pmflash asus 3.10 mk then your desired fw and you should be goodrabside wrote: Fri May 03, 2019 8:59 pm Hi,
thanks a lot
let us know never seen 3.11 before, might want mike to make a dump of it he seems to know how on drives with dosflash disabled
thanks
jonghotti
thank you!MartyMcNuts wrote: Wed May 08, 2019 2:35 amHere's the dump cleaner.jonghotti wrote: Tue May 07, 2019 5:24 pm Where is the most recent modified LG flasher kept please? Also, is there a firmware dump cleaning tool handy?
Thank you!
BH16NS40_Firmware_Dump_Cleaner.zip
eqman
thanks a lot!
jijink
Hi
I'm new to this forum.
I have Asus BW-16D1H-U(USB External) with A203 and it's not frielndly with UHD now.
I'm wondering , if i can use flash asus 3.10 mk to make it UHD friendly?
Is 3.10 MK is compatible with Asus BW-16D1H-U external drive?
BR
JIJI NK
BR
JIJI NK
No. The USB version of the Asus is not the same drive as their internal units with "almost" the same part number.
It is NOT UHD capable, and flashing the firmware will not fix that, and may make the drive unusable. The hardware doesn't support reading UHD disks.
It's a good drive for regular Bluray and DVD disks, just not UHD.
PaperLawyer
I received my 16D1HT this evening and quickly installed it into my newly purchased OWC Mercury Pro enclosure and ran the firmware tool - 20 seconds later firmware 3.03 had been replaced with 3.02 - thank you for making such a user friendly firmware took available!
Nice to be ripping at 7.6x rather than locked to 2x on my UJ265 (sat within my NCase m1 case).
There's just the minor matter of actually purchasing a 4K blu-ray now....
