(Asmcom:) Pioneer UHD 4K Drives, MakeMKV Discounted Software £39.99, Worldwide Service, Excellent Service!!!
asmcom
#1 Post by asmcom » Tue Apr 23, 2019 12:22 am
https://shop.uhdfriendlydrives.co.uk/
UHD Friendly Drives - Website Reopening later Today, Wednesday 12th August 2026.
We are pleased to confirm that we will be reopening our website later today, as we have now received our new stock of USA, UK and EU power supplies for the Asmcom Stable Power Looms.
We are also expecting our USB-C to USB-A adapters for the Type-C looms to arrive within the next two weeks. These will allow customers with standard USB-A ports to use the Type-C Stable Power Loom.
Thank you, everyone, for your patience and continued support.
Asmcom
UHD Friendly Drives Team
Asmcom’s USB Stable Power 5VDC Connector Loom and Major Stock Update. The lengths of the USB 2.0 and USB 3.1 MicroB looms are 200 cm. The USB Type-C loom is 120 cm in length.
Last updated: 14th July 2026
Hello everyone,
Please use this payment link,
https://www.paypal.com/paypalme/asmcom66
First of all, I would like to thank everyone for your patience and support over the past few months. We know the delays have been frustrating, and we genuinely appreciate everyone who has stuck with us while we worked to get everything right.
I am pleased to confirm that we are now ready to reopen our website earlier than advertised; we will open tonight at 7.00 pm UK time. Saturday, 25th July 2026.
As many of you know, we made the decision to improve our new Asmcom USB Stable Power Looms by increasing the cable length from 100cm to 200cm and using a heavier gauge wire to ensure the best possible performance and power stability. Although this delayed the project, we believe it was the right decision.
The second prototype looms performed brilliantly during testing. We successfully tested 12 BD100 UHD discs using both the Hitachi BP55 cross-flashed to BP60NB10 1-00MK and the Hitachi BU40N running firmware 1-03MK, installed in the Vantec NST-510S3-BK enclosure.
Every disc was read successfully with no read errors whatsoever. Testing was carried out using both a Mac Mini M4 Pro and a Dell Precision M7740.
We are also pleased to confirm that mass production has now been completed, and we have received our full shipment of Asmcom USB Stable Power Looms.
Thanks for sticking with us on this. We have now received all of our looms, and over the last 10 days we have been busy preparing a selection of UK, EU and US parcels. Each parcel will contain a new Hitachi drive, power supply and an Asmcom USB Stable Power Loom, all fully tested and ready for dispatch.
We are excited to begin shipping orders again and look forward to helping both new and existing customers.
Thank you once again for your continued patience, support and encouragement throughout this project. We couldn't have done it without you.
Asmcom
Newly acquired stock includes
Hitachi BP55EB40Revision 4 hardware
Hitachi BU40NRevision 4 hardware with updated internal components
The latest BU40N Revision 4 hardware incorporates refinements to the internal PCB layout, power regulation and drive control sections. These improvements enhance mechanical tolerance control and rotational stability, helping to reduce the likelihood of circular surface marking on certain disc types.
Extensive validation testing
Over the past months we have been carrying out extensive real-world testing of host-powered optical drives across a wide range of systems, including Mac Mini computers, compact PCs, Microsoft Surface devices and other low-power USB platforms.
During testing we deliberately applied heavy load conditions to the USB subsystem while the optical drives were operating. This included simultaneous USB device activity such as external hard drive transfers, phone charging, printing, scanning and other bus-powered devices drawing current from the same host controller.
Under these stress conditions we observed that some systems can experience small but measurable voltage dips on the 5V drive power rail. While these variations are typically within specification, optical drives performing high-speed UHD reading can be sensitive to such fluctuations, which in certain environments may lead to occasional read instability or error recovery events.
To further investigate this behaviour we modified several test units and supplied regulated external 5VDC power directly to the 5V drive power rail. This allowed us to isolate the drive from fluctuations on the host USB bus while maintaining normal USB data communication.
The results were extremely positive. With a stable regulated supply connected, the drives demonstrated excellent voltage stability regardless of USB system load, even when the host ports were heavily stressed with multiple devices. Disc reading performance remained consistent and predictable, with improved tolerance to demanding workloads. In our testing, this completely eliminated read instability caused by USB power fluctuations on low-power systems such as Mac Mini and Microsoft Surface devices.
This testing confirmed that stable power delivery can significantly enhance the consistency of host-powered optical drives, particularly when connected to smaller modern computers where USB power regulation may vary depending on system activity.
Introducing Asmcom’s USB Stable Power 5VDC Connector Loom
To our knowledge, this is the first USB cable specifically engineered to stabilise power delivery for UHD optical drives.
Figure 1: Asmcom’s USB Stable Power 5VDC Connector Loom showing the additional 5VDC female barrel connector for optional regulated external power.
Based on these findings we have developed a new accessory designed specifically to enhance the performance of host-powered optical drives.
Asmcom’s USB Stable Power 5VDC Connector Loom provides the ability to optionally supply regulated external 5VDC power directly to the drive cable while maintaining full USB data connectivity.
As shown in Figure 1, the loom incorporates an additional 5VDC 3.5 mm x 1.35 mm female barrel connector which allows a regulated power supply to stabilise the drive’s power rail while the USB connection continues to handle data communication with the host system.
The design incorporates:
USB 3.0 Micro-B connection to the drive
USB-A connection for data and host power
Additional 5VDC 3.5 mm x 1.35 mm female barrel connector for optional regulated external power
An additional USB Type A to Type C adaptor will be available for customers with C connectors on their devices
This configuration allows the drive to operate normally from the USB host while also enabling connection of a regulated 5VDC 2A power supply when maximum stability is required.
The result is extremely stable drive operation, even on systems where USB bus power may fluctuate during heavy device activity.
Because this type of cable does not currently exist commercially, we have commissioned a custom tooling production run and are currently having 2,000 units manufactured specifically for use with our host-powered optical drive solutions.
These looms will initially support USB Micro-B optical drive platforms, and we are also developing additional versions for other host-powered drive interfaces including native USB Type-C configurations.
MakeMKV Licenses Cost £39.99
OWC Mercury Pro 3.2 Full Sized Enclosures on Special. 20% Discount
We have the latest USB 3.2 OWC Enclosures with 20% off the URL below. We are also an OWC Reseller.
https://shop.uhdfriendlydrives.co.uk/ch ... 25fbce9e34
Our website will re-open on Wednesday, 4th February 2026 at 9:00am.
Current Market Situation
The UHD-capable optical drive market has changed significantly. Pioneer has discontinued almost all optical drive production, and remaining stock worldwide is now extremely limited. Once existing inventory is sold, these drives will not be manufactured again, and sourcing new genuine Pioneer UHD-friendly drives will no longer be possible.
Why Pioneer Drives
Pioneer optical drives are widely regarded as the highest-quality Blu-ray drives ever produced, particularly for UHD use. They offer:
• Superior build quality
• More reliable mechanisms
• Far more consistent and stable firmware behaviour
This is why Pioneer drives have become the preferred choice for UHD collectors and archivists worldwide.
Recommended Models
These are the only remaining genuine Pioneer models we will have available. All units are fully tested and confirmed UHD-friendly:
• Pioneer BDR-XS07TS - sold out
• Pioneer BDR-XD08EMB-S - sold out
• Pioneer BDR-XD08/S - sold out
Although these are external slimline drives, they use the same high-quality Pioneer mechanisms and firmware that made the internal models so reliable and highly sought after.
Availability
We strongly recommend purchasing while stock is still available. Once our remaining Pioneer inventory is sold, we will not be able to restock. Customers may then be forced to rely on second-hand or unverified drives, which carry significant compatibility and reliability risks.
Pricing Notice
Due to the extreme scarcity of genuine Pioneer UHD-friendly drives, distributor pricing for the final remaining stock has increased substantially. This is entirely outside of our control. We have absorbed as much of this increase as possible; however, some adjustment in pricing is unavoidable.
While these drives now command a premium, this is very likely the last opportunity to purchase new, fully tested, precision-engineered Pioneer 4K Blu-ray drives of this calibre. Once sold, they will not be available again.
Kind regards,
Asmcom
Special Notice for US Customers & Import Duty:
Important: New $12 International Collect on Delivery (ICOD) Fee for U.S. Customers
UPS has introduced a new $12 USD ICOD (International Collect on Delivery) Fee for shipments to the United States if duties, taxes, or other government-related charges ("Duties") are not paid prior to delivery.
This fee will be collected directly from the recipient at the time of delivery. This will be an additional fee on top of any import duty that is liable for the US. It is impossible for us to know what import duty is for every state in the US, so please check this out.
How to Avoid Paying the Fee on Delivery
To avoid the $12 ICOD fee, recipients can prepay Duties online before delivery using one of the following methods:
• Apple Pay
• Google Pay
• Credit card (Visa, Mastercard, or Discover)
Prepayment can be made through the UPS Import Payment Processing Application (IPPA).
Ensure Accurate Contact Details Are Provided
To receive the prepayment notification and secure payment link, it's essential that the following recipient details are entered correctly when placing your order:
• Full name
• Email address
• Phone number
Please double-check these details to avoid delays or unexpected charges.
Both recipients and shippers are responsible for providing accurate contact information to ensure a smooth delivery process.
A payment link will also be available through the tracking page on UPS.com, enabling recipients to pay in advance and avoid the ICOD Fee.
**Warranty Policy — this policy supersedes any previous posts**
As you may know, Pioneer has unfortunately ceased global manufacturing and official support for optical drives. **UHD Friendly Drives are no longer able to offer direct manufacturer support or warranty for Pioneer Blu-ray drives.**
That said, our commitment to you remains unchanged. Here’s how we’ll continue to assist:
**12-Month Customer Support**
For any Pioneer Blu-ray optical drives purchased from us, we offer 12 months of customer support, which includes troubleshooting assistance, setup guidance, and technical help for any issues that may arise during this period. We're here for you!
**30-Day Money-Back Guarantee**
If you're not completely satisfied with your Pioneer Blu-ray Writer Drive for any reason, we offer a 30-day money-back guarantee. You can return the product within 30 days of receipt for a full refund, provided the product is in its original condition, including all packaging and accessories. While Pioneer's direct warranty support is no longer available, we remain confident in the reliability of these drives, which have earned their reputation as top-tier products.
We understand that this change may be disappointing, and we want to emphasise that Pioneer Blu-ray optical drives are incredibly reliable and of the highest quality. We highly recommend them to anyone who has not yet experienced the exceptional performance of these products. They continue to be one of the best choices in the market for those seeking superior optical drive performance.
Thank you for being so understanding and for continuing to trust us. If you have any questions or concerns, please don't hesitate to reach out. We're here to support you every step of the way!
If you have any questions or concerns, please reach out.
Kind regards,
**Asmcom**
UHD Friendly Drives Team.
Important
Important Usage Recommendation: To preserve the lifespan of your Blu-ray drive, we do not recommend using it for direct playback of movie discs. Continuous playback can lead to premature laser wear. Our drives are ripping-optimised, not for use as regular movie players.
Instead, use trusted third-party software like MakeMKV to convert your 4K discs into a digital file or ISO container, which is a more reliable and drive-friendly solution for playback on your device. Once ripped, your content can be viewed repeatedly without further stressing the drive.
Let’s be smart about it:
Don’t use your drive for playback. The laser will wear out.
These drives are built for ripping, not repeated movie watching.
Use MakeMKV to create a digital copy. Then play it all you want, guilt-free and drive-friendly.
In short: Use your drive like it’s a tool, not a television.
[/color]BP55EB40WBU40NCC1-00DE - Drive with Carry Case Option. Hitachi BP55 Super Slim External Blu-ray Drive with Hitachi BP60-NB10 firmware BU40N 1-00DE, " 1-00DE Supports: DVDfab, MakeMKV, Xreveal Pro & AnyDVDHD, Drive with Carry Case Option". External Super-Slim USB 2.0 / 3.0 Compatible, Firmware 1-00mk, Reads 4K UHD Discs, Libre-Drive Friendly Drive with Carry Case Option. Costs £129.99 Plus Postage
[/b] - [/color]BP55EB40WBU40ND1-00DE - Drive Only Option. Hitachi BP55 Super Slim External Blu-ray Drive with Hitachi BP60-NB10 firmware BU40N 1-00DE, " 1-00DE Supports: DVDfab, MakeMKV, Xreveal Pro & AnyDVDHD, Drive Only Option". External Super-Slim USB 2.0 / 3.0 Compatible, Firmware 1-00mk, Reads 4K UHD Discs, Libre-Drive Friendly Drive Only. Costs £119.99 Plus Postage
[/color]BP55EB40WBU40NCC1-00MK - Drive with Carry Case Option. Hitachi BP55 Super Slim External Blu-ray Drive with Hitachi BP60-NB10 firmware 1-00MK, " 1-00MK Supports: MakeMKV, Xreveal Pro & AnyDVDHD, Drive with Carry Case Option". External Super-Slim USB 2.0 / 3.0 Compatible, Firmware 1-00mk, Reads 4K UHD Discs, Libre-Drive Friendly Drive with Carry Case Option. Costs £129.99 Plus Postage
[/color]BP55EB40WBU40ND1-00MK - Drive Only Option. Hitachi BP55 Super Slim External Blu-ray Drive with Hitachi BP60-NB10 firmware 1-00MK, " 1-00MK Supports: MakeMKV, Xreveal Pro & AnyDVDHD, Drive Only Option". External Super-Slim USB 2.0 / 3.0 Compatible, Firmware 1-00mk, Reads 4K UHD Discs, Libre-Drive Friendly Drive Only. Costs £119.99 Plus Postage
asmcom
ASMCom Pictures of Vantec with BW-161DHT
#2 Post by asmcom » Sat Apr 27, 2019 3:36 pm
Edited Out
Ironhand
Re: Supplier of UltraHD Friendly+Official Drives, External USB Enclosures, Firmware Flashing Remote or by Post
#3 Post by Ironhand » Sat Apr 27, 2019 5:19 pm
I was looking at the ASUS BC-12D2HT that you were selling on Ebay for £59.99. Wish I had bought one. They are not advertised on Ebay any more. I would like it Cross-Flashed to BW-16D1HT v3.10MK. When will you have in stock again and if I order here will I get 10% discount. Kind of cheeky but I joined MakeMKV to get my 10% discount. I would also like to order Vantec External too :D . Thanks Harry
asmcom
#4 Post by asmcom » Sat Apr 27, 2019 8:28 pm
Thank you Ironhand you are the first person to reply to my new advert of supplying UHD Friendly drives. You are in for suprise :D
Being the first customer to reply I will send you a Vantec Enclosure with Asus BW-16D1HT free of charge as I made a promise to myself that I would do this for first customer.
As for ASUS BC-2D2HT I am expecting a new batch of 25 on Monday. The price as went slightly up, I will have to wait and see what shipping costs etc.. before I put new price on.
However, I have a test drive connected to my computer which I use for testing it is 3 months old. I will offer you this drive for £35.00 plus postage to UK I presume as you are talking in sterling. Please contact me on uhdfriendlydrives.com to firm up details and payment if you want BC-2D2HT. There will be no charge on Vantec as you are my 1st customer on MakeMKV :D
Also a big thank you to Mike for supporting me on MakeMKV and working with me on new drives.
Ironhand
#5 Post by Ironhand » Sat Apr 27, 2019 8:33 pm
Oh Man thank you so much, I can't believe it, this is so amazing, you are awesome. Yes I will take other drive :D :D
Will email you now.
asmcom
Got my first Customer on MakeMKV
#6 Post by asmcom » Sat Apr 27, 2019 8:44 pm
And he was one lucky customer. :D
RibShark
Re: Supplier of UltraHD Friendly+Official Drives, External USB Enclosures, Firmware Flashing (World Wide Service)
#7 Post by RibShark » Mon Apr 29, 2019 6:29 pm
I'm looking to buy either a LG BH16NS55 or an ASUS BW-16D1HT. Do you have any recommendations on which one is better, or are the drives basically identical?
asmcom
Re: UltraHD Friendly+Official Drives, External USB Enclosures, Flashing (World Wide Service) Unbelievable Cheap Prices!!
#8 Post by asmcom » Mon Apr 29, 2019 11:06 pm
I prefer the Asus BW-16D1HT on firmware 3.10Mk firmware amazing achievement by mike. The hardware is Media Tek and drive are very similar please see PDF I have attached explaining the firmware and hardware etc.
https://drive.google.com/open?id=1WGC9e ... WtZ5ElSE5G A special thank you to Blackened & Czary2mary for producing this list
I would recommend for you to Purchase the ASUS BC-2D2HT as it is on offer and I can Cross-Flash to BW-16D1HT 3.10MK
https://www.ebay.co.uk/itm/264301962019
RibShark
#9 Post by RibShark » Tue Apr 30, 2019 2:03 pm
asmcom wrote: Mon Apr 29, 2019 11:06 pm I prefer the Asus BW-16D1HT on firmware 3.10Mk firmware amazing achievement by mike. The hardware is Media Tek and drive are very similar please see PDF I have attached explaining the firmware and hardware etc.
Thanks for the reply. Can you confirm that the ASUS BC-12D2HT has the same specifications as the BW-16D1HT when crossflashed? Specifically, being able to read/burn all types of media is important to me.
asmcom
Re: UltraHD Friendly+Official Drives, Special Promotion BU40 $116.00 Dollars See Inside
#10 Post by asmcom » Wed May 01, 2019 4:21 pm
Just confirming your options of firmware, as you said reading all types of media was important to you?
Cross-Flashing BC-12D2HT cross-Flashed to ASUS BW-16D1HT v3.02
I would advise that if you flash your drive to ASUS BW-16D1HT firmware v3.02 it would support 4 Programs (DeUHD, AnyDVDHD, DVDfab, and MakeMKV). However you will not be able to burn BD discs.
If you flash the drive with Firmware 3.10MK LibreDrive then your drive will only support 2 programs (MakeMKV & AnyDVDHD). But saying this if you only use MakeMKV 3.10MK is best option.
I am here to help and support you. If you have any questions or queries please do not hesitate to contact me by ebay or at uhdfriendlydrives@gmail.com I will offer you 12 Months Warranty on the BC-1D2HT CF to BW-16D1HT. These ASUS Drive are very reliable.
Kind Regards
Asmcom
Dave77
Re: UltraHD Friendly+Official Drives, Special Promotion BU40 10 Drives sold out 1 Day
#11 Post by Dave77 » Thu May 02, 2019 1:26 pm
Great price for the BU40N, especially in the UK! I had to get mine from US eBay.
asmcom
#12 Post by asmcom » Fri May 03, 2019 2:40 pm
Glad you got sorted out and drive is going good. :D
PaperLawyer
Re: UltraHD Friendly+Official Drives, External USB Enclosures, Firmware Flashing (Worldwide Service) Cheap Prices Inside
#13 Post by PaperLawyer » Sat May 04, 2019 6:33 pm
Oh no, I was just about the order a BU40N, got my daughters ready for bed, logged back in and the price has gone up in the last 30 minutes!
asmcom
#14 Post by asmcom » Sat May 04, 2019 7:47 pm
Sorry about that. The first ten were promotional prices as stated. Ten sold out in 48 hours.
But do not worry I will have another promotion coming up in the future.
New batch of drive and shipping costs have went up.
I got amazing deal on first ten drives which I passed on to customers and clearly advertised this sale.
Sorry you missed the opportunity.
Please pm me anything else
jduerr69
#15 Post by jduerr69 » Sun May 05, 2019 1:51 pm
Thank you for the amazing service. I'm in the US so I wasn't sure I wanted to deal with overseas sales but I'm sure glad I did. Your quick response and level of care is astounding. Within minutes of placing my order on eBay you contacted me to ensure I got the right product. Just a few hours after placing my order you had already sent me a reply with a picture of the drive boxed up and with a shipping label waiting to got to the post office the next day. Shipping took less than a week. I ordered it on Sunday and received it on Friday. Within minutes of receiving it I was already backing up my first UHD. Just plugged it in, fired up MakeMKV and it was ready to go. Fantastic!! Could be happier! I highly recommend you to anyone looking into moving to UHD's.
