Test for those who are brave, BU40N-N 1.02
Post by mike admin »
Guys, anyone have BU40N-N (classic USA version) with firmware 1.02 (or downgraded)? If you do have such drive and are familiar with flashing, could you please test the attached MK firmware? I do not have the drive...
Re: Test for those who are brave, BU40N-N 1.02
jonghotti wrote: Sat Apr 27, 2019 11:07 pm I sent you a log sire. Now I have to send my BU40N to Billy for flashing :cry:
Why did it disable DOSFlash?
mike admin wrote: Sat Apr 27, 2019 10:23 pm Guys, anyone have BU40N-N (classic USA version) with firmware 1.02 (or downgraded)? If you do have such drive and are familiar with flashing, could you please test the attached MK firmware? I do not have the drive...
i have some BU40Ns i will try it now
Ok for anyone else
it does not currently work with LibreDrive
and disables DOSFlash
Update: downgrading works so if its like LG 1.04 or asus 3.10 the part you changed there to allow downgrades works.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Billycar11 wrote: Sun Apr 28, 2019 1:15 am it does not currently work with LibreDrive
Yes, this is expected behavior. This is a 3.10 clone for BU40, with re-enabled downgrade. All new BU40 drives now come with 1.03 . The LibreDrive support for this fw will be enabled in a few hours...
just information for everyone
MK 1.03 for the BU40N now works with LibreDrive once the latest SDF is downloaded see screenshot below
asmcom
Post by asmcom »
Mike thank you very much for releasing this firmware and supporting the drive I uploaded to you. I most appreciate your efforts and the performance of the drive is amazing. I look forward to supplying my customers with this model.
Note: Never flash a Desktop Drive with a Slim and Vice Versa.
And special thank to Andy in Kaohsiung, for full Tech Manual, you are the Man.
Thank you so much, Looking forward to seeing you. Mr L
Dave77
Post by Dave77 »
What's the advantage of 1.03 over 1.02?
spezi
Re: Test BU40N-N Linux
Post by spezi »
I tested the 1.03 and 1.00 firmwares on my external BU40N via USB but it does not work with UHD on QNAP container (Linux). LibreDrive information and disk information are displayed.
After start of decryption my 4k UHD Planet Earth II get error messages :
DEBUG: Code 2399571968 at Z\M*hflDu).B!6OgK:121263153
DEBUG: Code 0 at Z\M*hflDu).B!6OgK:121262969
DEBUG: Code 1 at Z\M*hflDu).B!6OgK:121262969
DEBUG: Code 2 at Z\M*hflDu).B!6OgK:121262969
DEBUG: Code 3 at Z\M*hflDu).B!6OgK:121262969
DEBUG: Code 4 at Z\M*hflDu).B!6OgK:121262969
DEBUG: Code 5 at Z\M*hflDu).B!6OgK:121262969
DEBUG: Code 0 at Z\M*hflDu).B!6OgK:213131456
DEBUG: Code 0 at UB`Z)HS1-zNT6UNY:213140564
DEBUG: Code 0 at zenxcqm0L'|&\'"':29401014
DEBUG: Code 2147483648 at UB`Z)HS1-zNT6UNY:29397035
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' trat auf während der Übertragung des SCSI-Befehls A30..0020..03F zu Laufwerk 'SG:dev_21:3'
I tested another slim USB case - no success.
But decryption of normal Blurays and DVDs with makemkv 1.14.3 and the BU40N works fine on the QNAP.
Then I tested my external friendly drive BE16NU50 with the same UHD disk and it was decrypted with makemkv on QNAP. That external drive has its own USB controller.
The same BU40N box works on Win 10 as LibreDrive with makemkv 1.14.3! So it is the BU40N official UHD drive that does not work with the Linux container. SCSI error...
Has anyone tested the BU40N on Linux?
Dave77 wrote: Wed May 01, 2019 12:25 pm What's the advantage of 1.03 over 1.02?
Likely - none. The 1.03 MK that we have now thanks to asmcom offers a somewhat cleaner downgrade path. So if you got a drive with 1.03 it might be beneficial to stay on 1.03MK, as it can be flashed without updating the bootloader. But I see zero reasons to switch from 1.02 to 1.03MK.
asmcom
Post by asmcom »
Second Time Around
Thank you Mike, for acknowledging and thanking me for uploading new version of BU40N drive firmware. It feels good when you make a contribution to the community and it is recognised
Maybe the person who said this version of firmware was already available, will be man enough to now, to say this was not the case.
Mike I appreciate your comments. I am nearly finished my testing. Will be in touch very soon.
Really is amazing what you and other people on this forum can do. There is a great team of people at the MakeMKV community.
I would like to thank Martymcnuts for his contribution in relation to his input and hard work involving the new modified the official ASUS ODD FW Flasher tool which allows people to flash or cross-flash their drive to a "UHD Friendly" firmware. It also makes my life easier too.
Hope everybody has a nice Weekend
asmcom wrote: Fri May 03, 2019 10:46 pm Second Time Around
man enough lol
i never said 1.03 for BU40N was available i said it possible to make that dive work with makemkv by downgrading similar to here: https://www.makemkv.com/forum/viewtopic ... 16&t=19250 i dont think you understand things very well
and the thread where we discussed this disappeared strange
i wish the person who copied my op was man enough to make there own, but while they were at it they should have just reuploaded my youtube video with there voice over it. would seem more legit. wait they already did that but with no voice over, but it got taken down lol
[quote=idk who this is  :lol:  post_id=73484 time=1555978963 user_id=26940]
[size=150][color=#0000BF][b]The new safe method of Changing Firmware "Using Asus Modified Flasher"[/b][/color][/size]
Thanks to mike we now have a alternative method to flashing firmware read more about it here: [url]https://www.makemkv.com/forum/viewtopic.php?f=16&t=18873[/url]
In some cirmsubstances when Cross-Flashing and doing be-spoke firmware changes I would use Dosflash too. MakeMKV now supports official UHD drives such as LG WH16NS60, LG BU40N and others, which is currently being built on. Hopefully Mike will be adding on some new drives shortly :wink:
[size=150][color=#0000BF][b]"The Service I Offer"[/b][/color][/size]
If you Purchased a UHD friendly drive that came with an unfriendly firmware I can flash friendly firmware for you, or you can buy a Pre Flashed one from me. I also sell on ebay, please see links of some items below:
[url]https://www.ebay.co.uk/itm/264292707136[/url]
[url]https://www.ebay.co.uk/itm/264289073268[/url]
[url]https://www.ebay.co.uk/itm/264264227348[/url]
Send me your drive or buy one from me directly. See below for supported models. When I flash your drive I can email your original firmware backup and the new edited firmware with file checksums or include a CD-Rom in return parcel with drive that contains new firmware.  I will keep records of drive serial numbers and firmware changes in my database in the event you want to revert to original firmware for warranty reasons or other. You will have to pay for shipping both ways for flashing firmware service. I am located in the United Kingdom and cover worldwide. I can deal with international shipping no problem.
[size=150][color=#0000BF][b]"Prices For Drive & Firmwares"[/b][/color][/size]
Pre Flashed LG-BS16NS55 Retail Boxed £78.99 /$100.00  (with firmware of your choice) MK Firmware works with MakeMKV & AnydvdHD / V1.01 V.102 Firmware that will work with DeUHD & Dvdfab
Pre Flashed ASUS BW-161DHT Retail Box £74.99 / $97.50 (with firmware of your choice) V3.10MK Firmware works with MakeMKV & AnydvdHD / V3.02 Firmware that will work with DeUHD & Dvdfab
Pre Flashed ASUS BC-12D2HT Retail Box £63.99 / $83.50 (with firmware of your choice) V3.01MK Firmware works with MakeMKV & AnydvdHD / V3.00 Firmware that will work with DeUHD & Dvdfab
Cross-Flashed ASUS BC-12D2HT to BW-16D1HT Retail Box £63.99 / $83.50 (with firmware of your choice) V3.10MK Firmware works with MakeMKV & AnydvdHD / V3.02 Firmware that will work with DeUHD & Dvdfab
Cross-Flashed LG-BS16NS55 to BW-16D1HT Retail Boxed £78.99 / $100.00 (with firmware of your choice) V3.10MK Firmware works with MakeMKV & AnydvdHD / V3.02 Firmware that will work with DeUHD & Dvdfab
[size=150][color=#0000BF][b]"Drives with Enclosures"[/b][/color][/size]
ASUS BW-161DHT Internal Drive fitted with Vantec NST-536S3-BK NexStar DX 5.25”USB 3.0 External Enclosure £109.99 / $142.80
ASUS BC-12D2HT Internal Drive fitted with Vantec NST-536S3-BK NexStar DX 5.25”USB 3.0 External Enclosure £99.99 / $130.00
LG-BS16NS55 Internal Drive fitted with Vantec NST-536S3-BK NexStar DX 5.25”USB 3.0 External Enclosure £113.99 / $148.00
LG-BU40N Internal Drive fitted with Vantec NST-510S3-BK USB 3.0 Slim SATA Optical Drive Enclosure £89.99 / $115.00
Vantec NST-536S3-BK NexStar DX 5.25”USB 3.0 External Enclosure [b][u]Only Price[/u][/b] £36.99 / $47.30
Vantec NST-536S3-BK NexStar DX 5.25”USB 3.0 External Enclosure [b][u]Only Price[/u][/b] £21.00 / $26.85
More New Drives will be added when I get some sleep. Also, hopefully new drive models will be added to the forum :wink:
[size=150][color=#0000BF][b]"Shipping Rates"[/b][/color][/size]
UK Royal Mail 2nd Class Signed For (2 to 3 Working Days) £4.96 per Drive
UK Royal Mail 1st Class Signed For (1 to 2 Working Days)  £11.95 Per Drive
World Wide Rates (Flat Rate)
Royal Mail International Tracked £19.50 / $25.00
Royal Mail International Economy £12.60 / $16.00
[size=150][color=#0000BF][b]"Firmware Flashing"[/b][/color][/size]
Remote Flashing £7.50 / $10.00
Any questions or queries on firmware flashing please email me on [url]uhdfriendlydrives@gmail.com[/url]
I do this as a hobby and have priced the drives as keen as possible. I donate profits once a year every Christmas and will post details and amount at this time.
All drives are brand new and tested for 4K compatibility after the firmware has been changed. This drive has been removed from original packaging and then connected to my PC to change the firmware to custom firmware which makes your drive able to read UHD discs. Drives are tested by inserting a 4K disc, and back in the original packaging. Other than that, it is absolutely brand new. I cannot guarantee you will be able to plug this in and play a 4K disc on your PC. It will, however, READ them. Therefore, with additional software (NOT included in this auction), this drive can provide you options to decrypt, rip, burn, copy, etc, giving the potential to change a 4K disc to a playable file format. Also, for 4K playback the PC needs to have a motherboard, monitor and hardware that supports 4K playback as the drive is one part of the jigsaw.
[size=150][color=#0000BF][b]"Questions & Answers"[/b][/color][/size]
[b][color=#FF0000]Q:[/color][/b] What Firmware will you flash my drive with?
[b][color=#00BF40]A:[/color][/b] I will discuss each order or query individually with you and make you aware of what options is available to you.
[b][color=#FF0000]Q:[/color][/b] What if you cant flash my drive?
[b][color=#00BF40]A:[/color][/b] If i can not flash your compatible drive there will be no charge or if payment has been made I will offer a full refund.
[b][color=#FF0000]Q:[/color][/b] If I receive a bricked or faulty drive or Non UHD drives
[b][color=#00BF40]A:[/color][/b] I will contact you and make you aware that the drive is bricked or non UHD and I will return as is.
[size=150][color=#0000BF][b]"Payment"[/b][/color][/size]
All Countries outside the UK, I accept payment by Paypal at my Paypal email address as follows: [url]uhdfriendlydrives@gmail.com[/url]
I can accept cash in the box with drive or Cheque/Check on orders from the United Kingdom
Ebay Username is  "asmcom"
Please see my feedback on Ebay [url]https://feedback.ebay.co.uk/ws/eBayISAPI.dll?ViewFeedback2&userid=asmcom&ftab=AllFeedback&myworld=true&rt=nc&_trksid=p2545226.m2531.l4585[/url]
I can be contacted by Private message or by email at [url]uhdfriendlydrives@gmail.com[/url]
Looking forward to helping and supporting the MakeMKV community
[/quote]
spezi wrote: Wed May 01, 2019 5:35 pm I tested the 1.03 and 1.00 firmwares on my external BU40N via USB but it does not work with UHD on QNAP container (Linux). LibreDrive information and disk information are displayed.
yes https://www.makemkv.com/forum/viewtopic ... 12&t=18896
one of my customers had this problem i helped them trough it
asmcom
Post by asmcom »
PM please? Billycar11
spl147
Post by spl147 »
Ripping Black Hawn Down UHD right now on BU40N 1.03 on a Docker Container in unRAID, works Perfectly!
planet1
Post by planet1 »
This firmware worked nicely on a Buffalo BRXL-PT6U2VB, enabling LibeDrive 8) and UHD :mrgreen: .
THANK YOU, Mike!
