I need to downgrade my firmware on my UHD Drive
bmercurio82
Hello I need to know how to downgrade my firmware on my UHD Drive. The UHD Drive I have is the LG WH16NS60 and I need to downgrade the it to its original firmware. However, I purchased a program that can do that for me but my computers Bios does not support the thing I need to change before I can downgrade. However, I do have a laptop that I believe does have what I need to downgrade it but it keeps asking me to connect it to my PC but I can only connect to my laptop through a sata/USB connector. And I don't know where to go after that. Is there a downgrade software that can downgrade my firmware instead of upgrading it. I know LG website has the latest firmware update but it doesn't have the original one as far as I know. Doe anyone know where I can get the original firmware to download.
asmcom
Re: I need to downgrade my firmware on my UHD Drive
hope you where able to get your drive upgraded by following the guide on the forum. If you find it to hard I offered a remote service where I can dial into your computer and flash the firmware for you. Or if you prefer you can post me the drive and I will do it for you.
If you want advise and you want to do this your self just contact me and I will talk you through step by step uhdfriendlydrives@gmail.com
https://www.makemkv.com/forum/viewtopic ... com#p73484
how to video i made https://www.youtube.com/watch?v=Yfpf6HoMMis
i made it before marty updated his flasher but its the same idea as the lg flasher
and if you are still unsure i offer remote flashing here: https://www.makemkv.com/forum/viewtopic ... 16&t=17831
asmcom
Fantastic video Billy. Easy to follow
