I need to downgrade my firmware on my UHD Drive
bmercurio82
Post by bmercurio82 »
Hello I need to know how to downgrade my firmware on my UHD Drive. The UHD Drive I have is the LG WH16NS60 and I need to downgrade the it to its original firmware. However, I purchased a program that can do that for me but my computers Bios does not support the thing I need to change before I can downgrade. However, I do have a laptop that I believe does have what I need to downgrade it but it keeps asking me to connect it to my PC but I can only connect to my laptop through a sata/USB connector. And I don't know where to go after that. Is there a downgrade software that can downgrade my firmware instead of upgrading it. I know LG website has the latest firmware update but it doesn't have the original one as far as I know. Doe anyone know where I can get the original firmware to download.
Re: I need to downgrade my firmware on my UHD Drive
Post by SamuriHL »
asmcom
Post by asmcom »
hope you where able to get your drive upgraded by following the guide on the forum. If you find it to hard I offered a remote service where I can dial into your computer and flash the firmware for you. Or if you prefer you can post me the drive and I will do it for you.
If you want advise and you want to do this your self just contact me and I will talk you through step by step uhdfriendlydrives@gmail.com
https://www.makemkv.com/forum/viewtopic ... com#p73484
how to video i made https://www.youtube.com/watch?v=Yfpf6HoMMis
i made it before marty updated his flasher but its the same idea as the lg flasher
and if you are still unsure i offer remote flashing here: https://www.makemkv.com/forum/viewtopic ... 16&t=17831
asmcom
Post by asmcom »
Fantastic video Billy. Easy to follow
