Public KeyDB Disc Submissions
seaurchin
Post by seaurchin »
keydb_helper wrote: Wed Nov 11, 2026 2:09 am The following UHD discs required new media keys:
MKB20_v82_Her_Private_Hell_23C0
MKB20_v82_Saw_V_EF0E
MKB20_v82_Saw_VI_FFBA
MKB20_v82_Saw_VII_ED20
I'm curious as to what this means? I've loaded the most recent keydb file and I can read Saw V and VI but both discs are giving me AV sync errors before at around 500MB and basically stalling the process. Could this be an issue with the discs, drive, or key?
Tok72
Post by Tok72 »
Disc type: UHD
Disc ID: C3012AAA0CC27EA2376F1AB01E39475FF99E93F5
Disc dump filename: MKB20_v82_The_Lovely_Bones_B241.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled
Is your MKB_RO.inf file size at least 2MB? No
jackycyk0924
Post by jackycyk0924 »
Thanks for maintaining the Public KeyDB!
I'm using MakeMKV on macOS, so unfortunately I can't run KeyDB Assistant or FindVUK natively.
Would you be able to help process this Blu-ray disc? Many thanks for your help. :wink:
Disc type: BD / Blu-ray
Disc ID: 0x8a2997a557e7f45f375dce526980e309294a60b8
Disc dump filename: MKB_v82_BD_ROM_072E
Drive: BD-RE ASUS SBW-06D5H-U
Drive firmware: E101
Is your MKB_RO.inf file size at least 2MB? Yes
MKB_RO.inf link: https://drive.google.com/file/d/1gRpQ2n ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1AZzLrq ... sp=sharing
The_Red_Shoes
Post by The_Red_Shoes »
keydb_helper wrote: Wed Nov 11, 2026 9:29 pm
The_Red_Shoes wrote: Wed Nov 11, 2026 5:06 pm I have rebooted my computer a few times now and the drive was off for a few hours too but is still does not work.
I just realised most, possibly all, of your prior disc submissions were AACS 1.0 (1080p) Blu-ray discs. Have you ever been able to backup AACS 2.0 (UHD) discs with your drive? Is you drive housed in an external USB enclosure?
Some USB enclosures can inadvertently prevent LibreDrive from being properly activated. This causes AACS 2.0 backups to fail as they typically require LibreDrive. AACS 1.0 discs will generally not be affected as they have alternative options even when LibreDrive is unusable.
Yes, I have backed up about 20 UHD Blu-rays and they all worked. This is the first UHD-Bluray that is not working.
And yes, it is an external USB drive.
zaqqaz6917
ODYSSEY 2026 USA
Post by zaqqaz6917 »
Disc type: UHD
Disc ID : 1A79E3B04DB128BFBFF74BADB9B49A608F699647
Disc dump filename: MKB20_v82_The_Odyssey_1F64
Disc dump link: https://www.mediafire.com/file/o10c3znr ... A.rar/file
MKB_RO.inf link: In above folder
Drive INFO
Drive: BD-RE WH16NS60
Firmware version: 1.02
It seems that code is in.....is working now at 1:50pm gmt-5
rumpelstiltskin
Disk Dump for 2CB1 variant of Pale Rider
Post by rumpelstiltskin »
Disc type: 4k UHD
Disc ID:
Disc dump filename: MKB20_v77_Pale_Rider_2CB1.tgz
Drive: PIONEER BDR-XD08U
Drive firmware: 1.0
MKB_RO.inf link: https://drive.google.com/file/d/16ZPlKd ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1bHxJhp ... sp=sharing
keydb_helper
Re: Synthetic dumps for discs needing media keys - Divergent series
Post by keydb_helper »
Warbington wrote: Wed Nov 11, 2026 10:46 pm Disc type: UHD
Disc ID: 0x1926000C24EAD38D8063E648504C1F792D126C4E
Disc dump filename: Divergent.tar (synthetic)
Disc type: UHD
Disc ID: 0x55D929A10C92EBDB77083E449F738CB7818977D0
Disc dump filename: Insurgent.tar (synthetic)
Disc type: UHD
Disc ID: 0x7A3C818B3722DCA0B7C16A4527C475BFE79BFB5A
Disc dump filename: Allegiant.tar (synthetic)
Fantastic work Warbington, those were three of the top priority discs. All three now have complete records in the public keydb. There are at least a further ten discs (6x Divergent, 2x Insurgent and 2x Allegiant) which can now have complete keydb records generated on a self-serve basis.
SamuriHL wrote: Wed Nov 11, 2026 11:04 pm My tool would work fine in wine on MacOS, however, it's very likely that FindVUK would not. Which to upload keys to the keydb that is required as my tool doesn't do anything with keys directly. That's all handled by FindVUK under the covers. It'll definitely work with something like Parallels running Windows ARM.
Thanks for the clarification. I'll try to get access to test out a few options on an ARM Mac to see what is currently possible.
Tok72 wrote: Thu Nov 12, 2026 2:51 am Disc type: UHD
Disc dump filename: ...
Your disc has been added to the public keydb but you were fortunate that the media key was already known. In the future, please populate all fields in the submission template. If your answer to any question is 'No' it means your submission is incomplete.
seaurchin wrote: Thu Nov 12, 2026 2:10 am Could this be an issue with the discs, drive, or key?
The keys are correct. AV sync errors, read errors, and hash errors are all indicative of a read error. This will generally be due to a disc issue, a drive issue, or a combination of the two.
jackycyk0924 wrote: Thu Nov 12, 2026 3:18 pm I'm using MakeMKV on macOS, so unfortunately I can't run KeyDB Assistant or FindVUK natively.
Hey jackycyk0924, your disc has been added to the public keydb. My template comment about the self-serve options is purely meant to be informative. Usable disc dump files posted here won't be disregarded or ignored.
The_Red_Shoes wrote: Thu Nov 12, 2026 4:31 pm Yes, I have backed up about 20 UHD Blu-rays and they all worked. This is the first UHD-Bluray that is not working.
Thanks for the clarification. It is an odd issue you are seeing... Would you mind trying to open one of your earlier successful UHD discs in MakeMKV to verify that there has been no regression in functionality? No need to read the entire disc, just progressing to the point of title/track selection would be sufficient. If the drive firmware or USB enclosure were problematic, I'd expect that no UHD discs could be backed up.
  • The MKB_RO.inf file from the original disc is required
KeyDB Download
KeyDB Priority Disc List
KeyDB Lower Priority Disc List
caseablee
Post by caseablee »
One of the easiest/most common issues is a dirty disc. Try wiping them off before ripping as they may have an oil film on them from production.
Post by SamuriHL »
keydb_helper wrote: Thu Nov 12, 2026 8:15 pm Thanks for the clarification. I'll try to get access to test out a few options on an ARM Mac to see what is currently possible.
I have one I just have far too much going on right now to spend time on it. After this weekend I should have a bit more time to look at it if you haven't been able to by then. Mac is going to make it challenging, though.
MrPenguin
Re: ODYSSEY 2026 USA
Post by MrPenguin »
zaqqaz6917 wrote: Thu Nov 12, 2026 6:03 pm Disc ID : 1A79E3B04DB128BFBFF74BADB9B49A608F699647
Already?? This disk isn't due to be released until next week! :shock:
Post by SamuriHL »
MrPenguin wrote: Thu Nov 12, 2026 9:28 pm
Gruv already shipped mine. Should be here tomorrow.
caseablee
Post by caseablee »
Below are some synthetic dumps. Please let me know if this was done incorrectly and I will attempt again.
Space Jam A New Legacy
https://drive.google.com/file/d/16rEXzP ... O9HNZB_YLK
Spiral
https://drive.google.com/file/d/1Mc6l0p ... JENI7NjIOI
The Unbearable Weight of Massive Talent
https://drive.google.com/file/d/1v15x62 ... SSRV4ElPn0
Devotion
https://drive.google.com/file/d/1By62LR ... DDM_K73da7
The Forever Purge
https://drive.google.com/file/d/1vEeB3z ... b_9Bg64eFT
Marvel Studios' Guardians of the Galaxy Vol. 3
https://drive.google.com/file/d/1g0zk2O ... w4JMj5jKb9
MrPenguin
Post by MrPenguin »
SamuriHL wrote: Thu Nov 12, 2026 9:40 pm Gruv already shipped mine. Should be here tomorrow.
Hurrumph! (I should be so lucky... :evil:)
zaqqaz6917
Just hand delivered today from wally world
Post by SamuriHL »
MrPenguin wrote: Fri Nov 13, 2026 12:28 am
It's why I order from GRUV. LOL
