Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
cromtoss wrote: Sun Oct 25, 2026 7:02 pm Severin's 4K UHD Release of What Have You Done to Solange:
Disc type: UHD
Disc ID: DC7FCD4809E5EF97D2F02C51FCA45BF54A4F910E
Disc dump filename: MKB20_v82_SOLANGE_UHD_8C91.tgz
isp1985 wrote: Sun Oct 25, 2026 9:02 pm Disc type : UHD
Disc ID : DC7FCD4809E5EF97D2F02C51FCA45BF54A4F910E
Disc dump filename : MKB20_v82_SOLANGE_UHD_8C91.tgz
Thanks for the submissions. This disc has been added to the public keydb.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
KM4KFG
Post by KM4KFG »
Disc type: UHD
Disc ID: 0x91CFB26B2E3A776A38806ECE7B7397BFB44C5EBE
Disc dump filename: MKB21_v61_Patriot,_The_(2000)_AF85
Drive: HL-DT-ST BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1ut4XZ2 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1tAaoru ... sp=sharing
keydb_helper
KM4KFG wrote: Mon Oct 26, 2026 3:38 am Disc type: UHD
Thanks for the submission KM4KFG but MakeMKV doesn't utilise the public keydb for AACS 2.1 titles and the current version of libaacs does not support AACS 2.1.
KeyDB Priority List
bdsucker
Post by bdsucker »
Disc type: UHD
Disc ID: 0x0DB1D49215CC3283F40D6407454E46B2B97D4E11
Disc dump filename: MKB20_v82_The_Mothman_Prophecies_UHD_1338
Drive: BD-RE BP60NB10
Drive firmware: 1.02
Disc dump link: https://www.mediafire.com/file/oicgb5hk ... 8.tgz/file
MrPenguin
Post by MrPenguin »
The KEYDB.cfg file contains a Volume Key and a Unit Key for this disk, which allow libaacs partially to decrypt it. However, AACSv2.1 disks also need extra "segment keys". Without these extra keys, you will see undecodable frames every few seconds or so using libaacs alone.
You need to ask MakeMKV to decrypt this disk for you properly.
KM4KFG
Post by KM4KFG »
MrPenguin wrote: Mon Oct 26, 2026 11:38 am
Yes understood. Thank you for the extra info as this is first 2.1 disc I’ve encountered.
I’ve already submitted this morning for decryption to svq@makemkv.com
Thanks and awaiting further updates from MakeMKV
turbov6camaro
Post by turbov6camaro »
Thanks again - the last batch of keys came through and those discs (Back to the Future Part III, Home Alone, Ghostbusters: Afterlife and Frozen Empire) are all keyed now. Here are 3 more from this morning. Every dump was packed with the full MKB_RO.inf inside the .tgz.
Disc type: UHD (4K Ultra HD Blu-ray) - Step Brothers, label STEP_BROTHERS
Disc ID: B551E149C31C05D78A3A94EB7B8F4090A64D2831
Disc dump filename: MKB20_v61_Step_Brothers_3697.tgz
Drive: LG BP60NB10
Is your MKB_RO.inf file size at least 2MB? Yes (5 MB)
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1xsaK7b ... K03eL/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1xsaK7b ... K03eL/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - A Christmas Story, label A_CHRISTMAS_STORY
Disc ID: C8B770CC22DFFFA6B4679496F401AEFE71A535E6
Disc dump filename: MKB20_v76_A_Christmas_Story_EB0F.tgz
Drive: LG BP60NB10
Is your MKB_RO.inf file size at least 2MB? Yes (128 MB)
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1eFsz5U ... lte__/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1eFsz5U ... lte__/view (same zip)
Disc type: UHD (4K Ultra HD Blu-ray) - Dr. Seuss' The Grinch (2018), label GRINCH_UPK75
Disc ID: 8B03888AFE62A210EFD670C63F21D732587E6B29
Disc dump filename: MKB20_v66_Dr_Seuss'_The_Grinch_F951.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1_KTAnq ... ESB8S/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/1_KTAnq ... ESB8S/view (same zip)
dracolate
Post by dracolate »
Faces of Death IV
Disc type: UHD
Disc ID: 0xE78FCFE404154B1B09853AF1D39DED11C6BC942C
Disc dump filename: MKB20_v82_VSA067UHD_7833
Drive: BD-RE WH16NS60
MKB_RO.inf link: https://drive.google.com/file/d/1pHcrfb ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1vesTR5 ... sp=sharing
turbov6camaro
One more from today. The keydb already has a record for this disc ID, but it only holds the unit key (no MK, VID or VUK), and MakeMKV reports "The volume key is unknown for this disc". The dump was packed with the full MKB_RO.inf inside the .tgz, so it should let you complete the record.
Disc type: UHD (4K Ultra HD Blu-ray) - Teenage Mutant Ninja Turtles, label TEENAGE MUTANT NINJA TURTLES
Disc ID: 34B19A98713A1696190188E79C82337EEAB814E9
Disc dump filename: MKB20_v61_Teenage_Mutant_Ninja_Turtles_DC71.tgz
Drive: LG BP60NB10
MKB_RO.inf link (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/17_g_c- ... IgoaF/view (copied directly from the disc; in the zip with the dump, and also inside the dump .tgz)
Disc dump link: https://drive.google.com/file/d/17_g_c- ... IgoaF/view (same zip)
sashringing
Post by sashringing »
Disc type: UHD
Disc ID: 0x9B8AE1F985ECDB0B33572607178ED80BDB43609D
Disc dump filename: MKB20_v82_Dr_Seuss'_How_the_Grinch_Stole_Christmas_B2FC.tgz
Drive: BUFFALO Optical Drive (BU10)
Drive firmware: BU10 (211705301728)
LibreDrive status: Enabled (v06.3 id=F046CEB2F3AB)
MKB_RO.inf link: https://drive.google.com/file/d/1tolusS ... share_link
Disc dump link: https://drive.google.com/file/d/1dxkmI8 ... share_link
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v61_Step_Brothers_3697
*MKB20_v82_24_Hour_Party_People_CB80
*MKB20_v82_ACCIDENT_747C
*MKB20_v82_Ghost_in_the_cell_D13A
*MKB20_v82_SHADOWS_OF_FORGOTTEN_ANCESTORS_5826
*MKB20_v82_The_Mothman_Prophecies_UHD_1338
*MKB20_v82_WILD_AT_HEART_CBBA
KeyDB Priority List
buffalobossie
Post by buffalobossie »
Killer's Kiss
Disc type: UHD
Disc ID: 0ea39e18c225a0e1ea5df2dd7456ccea4e4ae49a
Disc dump filename: MKB20_v82_KILLER'S_KISS_AND_EARLY_WORKS_3144.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1p2MRxz ... sp=sharing
Disc dump link: https://drive.google.com/file/d/16wNELg ... sp=sharing
ventrue
Post by ventrue »
Star Trek - First Contact 4K UHD
Disc type: UHD
Disc ID: 0F36FF01FF1E1D4777C1721F8E4A5C64F6B13004
Disc dump filename: MKB20_v77_STAR_TREK_FIRST_CONTACT_F69D.tgz
Drive: BD-RE BU40N
Is your MKB_RO.inf file size at least 2MB? Yes (5MB)
MKB_RO.inf link: https://limewire.com/d/742De#A0HXb0WyWp
Disc dump link: Also https://limewire.com/d/742De#A0HXb0WyWp
emanresu
Post by emanresu »
Disc type: UHD
Disc ID: 0x6F0785B5C3AA7DC5DE693EAFBE7AD450FE5F52B2
Disc dump filename: MKB20_v70_THOR_B9AA
Drive: BDR-XD07U
Drive firmware: 1.04
MKB_RO.inf link: https://mega.nz/file/lX0SgbDZ#t0XSkX8jL ... mJS4yEv-uE
Disc dump link: https://mega.nz/file/Ub0jjbZS#GGfEBcFsd ... 2legvyV2I0
keydb_helper
buffalobossie wrote: Tue Oct 27, 2026 10:35 am Killer's Kiss
Disc type: UHD
Thanks buffalobossie, your disc has been added to the public keydb.
KeyDB Priority List
