ASUS SBW-06D2X-U
zittrig
Re: ASUS SBW-06D2X-U
#376 Post by zittrig » Mon Aug 24, 2026 5:37 pm
rayians wrote: Mon Aug 24, 2026 4:59 pm Hey everyone!
In the past I have successfully flashed a few 5.25" drives. I cannot figure this one out, can someone please help me?
Thank you!
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number: MO8P72G3730
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 82
Flash it to BU40N 1.03MK.
Check this ---> viewtopic.php?t=19634
rayians
#377 Post by rayians » Mon Aug 24, 2026 6:24 pm
I've got to be missing something. I ran the SDFtool Flasher twice and it didn't change the firmware on the drive. I ran it once without checking "encrypted firmware" and once with the box checked. The drive still shows as an Asus SBW-06D2X-U.
JohnHalo
#378 Post by JohnHalo » Mon Aug 24, 2026 8:46 pm
MartyMcNuts wrote: Wed Aug 19, 2026 12:34 am
JohnHalo wrote: Tue Aug 18, 2026 8:53 am "So what happens when you try to rip a UHD disc?"
When I click on the Open Blu-ray disc button in MakeMKV, it starts to open and down in the log it reads:
Using LibreDrive mode (v06.3id=866A98CB9C4E)
Saved AACS dump file as C:/Users/...../.MakeMKV/MKB20 v68 Mortal Engines 8ED3.tgz
At which point it reverts to the previous screen and the drive keep spinning like its trying to fly to the moon... until I eject the disc. When trying to watch in VLC it just fails and tells my the disc is corrupted.
Your issue is not firmware related. Your drive has been flashed successfully. Either the decryption key for that disc is not yet available or something on your PC might be blocking the key downloads.
Ensure MakeMKV has internet access (in preferences) and that your PC is not geo-blocking Russia as that is where the hashed keys database is downloaded from. You may need to run MakeMKV through a VPN.
You can also use the public KeyDB which may contain the key for your disc. For info on how to set up the public KeyDB, go to the first post of the Public KeyDB Submission Thread: viewtopic.php?p=176733#p176733
Thank you very much!
You were absolutely right, I needed to get the Public KeyDB configured, as it's an offline computer.
Much appreciated kind soul, may your discs forever remain fog free and crystal clean 8)
#379 Post by Billycar11 » Mon Aug 24, 2026 10:04 pm
Thank you!
OS device name: F:
Manufacturer: ASUS
Revision: A102
Sure see guide below
Treat it as a bu40n
Or email me or Marty for the automated flasher
See below for email
bdgzuz
#380 Post by bdgzuz » Tue Aug 25, 2026 6:19 am
Billycar11 wrote: Fri Aug 21, 2026 12:36 pm Do you have enc checked of so disable it
I've had no enc checkbox. Flashed 1.0 with recovery, worked flawlessly.
Setch35
#381 Post by Setch35 » Thu Oct 15, 2026 2:17 pm
Hi, I'd like to crossflash my drive to UD04 for UHD discs, please. Drive info below:
Manufacturer: ASUS
Revision: 1.10
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware: PIONEER BDR-US03 1.10/ID22
LibreDrive: Enabled
#382 Post by Coopervid » Thu Oct 15, 2026 4:46 pm
Setch35 wrote: Thu Oct 15, 2026 2:17 pm Hi, I'd like to crossflash my drive to UD04 for UHD discs, please. Drive info below:
Manufacturer: ASUS
Revision: 1.10
LibreDrive: Enabled
Please post which OS you are using.
#383 Post by Billycar11 » Thu Oct 15, 2026 9:10 pm
Manufacturer: ASUS
Revision: 1.10
LibreDrive: Enabled
Just follow guide below i will email you within 5 mins of you sending it
LouLatsch
#384 Post by LouLatsch » Sun Oct 18, 2026 2:34 pm
I can’t get my drive to be flashed so that it recognises 4K films. Could someone help me out?
Windows 11
OS-Gerätename: D:
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: SCDL119328WL
Firmware-Datum: 2017-04-18
Highest AACS version: 35
Firmware version: 1.10/ID22
#385 Post by Billycar11 » Sun Oct 18, 2026 5:26 pm
LouLatsch wrote: Sun Oct 18, 2026 2:34 pm I can’t get my drive to be flashed so that it recognises 4K films. Could someone help me out?
Windows 11
OS-Gerätename: D:
Produzent: ASUS
Revision: 1.10
Sure see guide below and email me
LouLatsch
#386 Post by LouLatsch » Mon Oct 19, 2026 3:36 pm
Billycar11 wrote: Sun Oct 18, 2026 5:26 pm
Windows 11
OS-Gerätename: D:
Produzent: ASUS
Revision: 1.10
I have send you an mail.
axedev
#387 Post by axedev » Wed Oct 21, 2026 9:52 am
I have this drive:
Drive informatie
Naam OS-apparaat: D:
Fabrikant: ASUS
Product: SBC-06D2X-U
Revisie: A101
Serienummer: MOBP2D83434
Firmware datum: 2124-03-27 13:34
Bus encryptie flags: 1E
Can anybody help me to enable UHD and libredrive?
#388 Post by MartyMcNuts » Wed Oct 21, 2026 10:51 pm
axedev wrote: Wed Oct 21, 2026 9:52 am I have this drive:
Drive informatie
Fabrikant: ASUS
Revisie: A101
Your's is a LG. Flash it to BU40N 1.03-MK.
axedev
#389 Post by axedev » Tue Oct 27, 2026 11:28 am
MartyMcNuts wrote: Wed Oct 21, 2026 10:51 pm
Drive informatie
Fabrikant: ASUS
Revisie: A101
Thanks alot! That worked perfectly.
