They emailed me and I looked into this furtherbb_2023 wrote: Thu Aug 27, 2026 4:11 am Hi all,
Hoping for some guidance before I flash anything, since my drive's starting state doesn't quite match the cases I've found in other threads.
My drive info (from MakeMKV):
Manufacturer: LG
Product: BP50NB40
Revision: A101
Serial number: M60G7F01205
Firmware date: 2116-02-24 11:44
Bus encryption flags: 1F
Highest AACS version: 43
Firmware version: 0.A101D
What's working: Standard Blu-ray discs read and rip perfectly.
What's not working: UHD 4K discs don't mount at all — no media detected, drive spins briefly then gives up. Tested on two different movies/discs, so it doesn't seem to be a single bad disc.
My question: Since "Product" still shows as BP50NB40 (not BU40N or BP60NB10), I understand from other threads that this firmware platform can't handle UHD regardless of LibreDrive status. Given my drive already shows "Enabled" natively (not the usual starting point of "Possible, not yet enabled" that most guides assume), which is the correct file/process to cross-flash to BP60NB10 or BU40N?
I found DE_LG_BP60NB10_1.00_MK_HBD.bin in Marty's "All You Need Firmware Pack" and was planning to try a straight WRITE (not RECOVER) with that hybrid file via makemkvcon on macOS (Mac Mini, Apple Silicon) — but wanted to confirm this is correct for an A101 revision specifically before proceeding, since I haven't seen this exact starting state discussed elsewhere.
Thanks in advance for any guidance!
This drive was fake as the build date was Oct 2025 with svc nb50
If it were real the build date would have been nb52
