I haven't actually tried it with wine yet, but given that my setup is linux-only, I'm curious. I'll see if I can get this working and report back.keydb_helper wrote: Fri Jul 24, 2026 5:07 pm Hey rkjnsn, I believe MrPenguin and a few other Linux users have had success with FindVUK via Wine. I don't have any saved links or notes but you might be able to find some instructions on this forum or possibly Doom9.
Public KeyDB Disc Submissions
loucipher wrote: Sun Jul 26, 2026 5:47 pm I haven't actually tried it with wine yet, but given that my setup is linux-only, I'm curious. I'll see if I can get this working and report back.
$ wineconsole findvuk synchronizeCode: Select all
$ wineconsole findvuk validateDisc drive=eCode: Select all
$HOME/.wine/dosdevices/e:: -> /dev/sr1-
Crappusername
Disc type: UHD
Disc ID: 1737A1BA805E70E7EFC8D80F31CCCD6B3C4E3938
Disc dump filename: MKB20_v82_Stranger_Things-_Season_2_Disc_2_4B72.tgz
Drive: LG BH16NS22
Drive firmware: 1.05
LibreDrive status: Enabled
MKB_RO.inf link: https://download1649.mediafire.com/y2q6 ... MKB_RO.inf
Disc dump link: https://download1582.mediafire.com/b4o6 ... 2_4B72.tgz
First time I've done this so hopefully it's all ok. Bit strange (pun intended) as this is the second disk of season 2. The first and third discs worked ok.
Drive: LG BH16NS22
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following BD and UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB_v82_DAN_DA_DAN-_Season_Two_-_Disc_One_8E30
*MKB_v82_DAN_DA_DAN-_Season_Two_-_Disc_Two_4BCE
*MKB20_v61_JOHN_WICK_-_KAPITEL_2_C455
*MKB20_v61_UHD_YOURNAME_0219
*MKB20_v72_IT_CHAPTER_TWO_5A25
MKB20_v76_Indiana_Jones_and_the_Last_Crusade_92D7
Hey Crappusername, your disc has been in the public keydb for a few weeks. What you've experienced is a MakeMKV issue with processing unencrypted discs. Follow the steps listed by trashraccoon here to backup your disc.Crappusername wrote: Mon Jul 27, 2026 3:48 am Disc type: UHD
Hey logisraelfun, your links are not publicly accessible.
Here is my dump, I hope you can help to decrypt
There are total 3 files, so I made them a zip file
https://drive.google.com/file/d/1sAkiok ... drive_link
Crappusername
I've come across some strange disc authoring issues in my time but that one is a first. Thanks.keydb_helper wrote: Mon Jul 27, 2026 3:52 am Hey Crappusername, your disc has been in the public keydb for a few weeks. What you've experienced is a MakeMKV issue with processing unencrypted discs. Follow the steps listed by trashraccoon here to backup your disc.
keydb_helper
It is a rare occurrence and you'll have two similar discs in your Stranger Things collection.Crappusername wrote: Mon Jul 27, 2026 4:49 am I've come across some strange disc authoring issues in my time but that one is a first. Thanks.
The only other examples which come to mind are The Wicker Man and City on Fire.
keydb_helper
Thanks cjm8026, your three discs have been added to the public keydb.cjm8026 wrote: Mon Jul 27, 2026 4:03 am Here is my dump, I hope you can help to decrypt
logisraelfun
Sorry I updated my links!!!
UDH Troy Directors Cut and Regular
Troy Directors Cut https://drive.google.com/file/d/1pT9fjy ... drive_link
Troy Theatrical https://drive.google.com/file/d/1L91Dui ... drive_link
keydb_helper
Thanks for following up on those links but your discs were added to the public keydb on June 27. Check out these instructions for configuring MakeMKV to utilise the public keydb: Link.logisraelfun wrote: Mon Jul 27, 2026 9:32 pm Sorry I updated my links!!!
Troy Directors Cut ...
Troy Theatrical ...
SoggySunfish
Disc type: UHD
Disc ID: 0xEBF485F8EFF752C926D725695C7AF659665250E3
Disc dump filename: MKB20_v76_ROGER_RABBIT.zip
Drive: BD-RE BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
Manual disc dump link: https://drive.proton.me/urls/840F7JTSNG#5zKIhjfnJz3s
Disc is not in public keydb, but MakeMKV can somehow decrypt the disc so it didn't create a disc dump file to submit. I've had to create a manual dump (with full MKB_RO.inf included), according to the instructions here viewtopic.php?p=193096#p193096
First time doing this. I hope I did everything correctly.
Drive: BD-RE BU40N
keydb_helper
Hey SoggySunfish, thanks for taking the time to manually create a usable disc dump file and welcome to the forum. Your disc has been added to the public keydb.SoggySunfish wrote: Tue Jul 28, 2026 10:56 am Disc type: UHD
MakeMKV will utilise its native hashed key database by default. This is distinct from the public keydb and the two databases support a distinct set of titles.SoggySunfish wrote: Tue Jul 28, 2026 10:56 am Disc is not in public keydb, but MakeMKV can somehow decrypt the disc so it didn't create a disc dump file to submit.
If you find any other discs in your collection which are not in the public keydb feel free to pass along as many manual disc dump files as you can muster.
Disc type: UHD
Disc ID: 84FCD3B16471800D843CA7462D4F5DF6207A3D74
Disc dump filename: MKB20_v82_Once_a_Thief_CC14
Drive: ASUS BW-16D1H-U
Drive firmware: A204
Did you sync the public keydb within the last 15 minutes? YES
MKB_RO.inf link : https://drive.google.com/file/d/17Mtk4m ... I8R1Tt_j5/
Disc dump link: https://drive.google.com/file/d/11LGKOH ... O1gx9LJs4U
SoggySunfish
Thank you so much for your service keydb_helper!
I currently have four more discs that aren't in public keydb:
Disc type: UHD
Disc ID: 0x83E298D2FC8B6B3A7ACB6673691757140A1CC1E8
Disc dump filename: MKB20_v72_APPOLLO_11.zip
Drive: BD-RE BU40N
Manual disc dump link: https://drive.proton.me/urls/HDJ80E63AC#3AUNVVzAMjwi
Disc type: UHD
Disc ID: 0x43E24E6D181ADC006CBBB84231B8AEE0A6BA2BB9
Disc dump filename: MKB20_v70_CASTLE_OF_CAGLIOSTRO.zip
Drive: BD-RE BU40N
Manual disc dump link: https://drive.proton.me/urls/3GXRQZRK08#2hLxxZlbQCfA
Disc type: UHD
Disc ID: 0xF5D1E6F89746D8C7BE953BCA763EC5FBC25CA911
Disc dump filename: MKB20_v61_GHOST_IN_THE_SHELL.zip
Drive: BD-RE BU40N
Manual disc dump link: https://drive.proton.me/urls/R33PTD8WBR#yOzc8cjVfhBu
Disc type: UHD
Disc ID: 0xF895B5FAD7E1E20500DC470EE5048670C69BE9A8
Disc dump filename: MKB20_v61_INNOCENCE.zip
Drive: BD-RE BU40N
Manual disc dump link: https://drive.proton.me/urls/YGGW76PFK0#ZDXta2uK5TAE
Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Disc ID: A95091BABC260947912BE495734A0DE279466C73
Disc dump filename: MKB20_v82_Bullet_In_The_Head_1DF6
Drive: BW-16D1H-U
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link: https://drive.google.com/file/d/1xSOlKM ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1-G5J7R ... sp=sharing
Drive: BW-16D1H-U
