LG BH16NS40
HSH1979
LG BH16NS40
Post by HSH1979 »
Hi all! I discovered a few days ago my drive cannot read ultraHD k disks, any idea if i can safely flash my drive and allow this?
Or what can i buy?
Re: LG BH16NS40
HSH1979 wrote: Wed Jul 08, 2026 9:49 am Hi all! I discovered a few days ago my drive cannot read ultraHD k disks, any idea if i can safely flash my drive and allow this?
Or what can i buy?
Why bother asking if you aren't going to provide the relevant info??? Try pasting the text from MakeMKV drive info and libredrive info sections.
HSH1979
Re: LG BH16NS40
Post by HSH1979 »
Hello! Im new and i didnt know.
I will check this evening. For the moment i read that my drive was manifactured in 2012, somewhere i red to check also this.
Re: LG BH16NS40
HSH1979 wrote: Thu Jul 09, 2026 7:04 am Hello! Im new and i didnt know.
The label on top of the drive will tell you the manufacturing date.
For UHD compatibility, it must use the MT1959 drive platform and be manufactured from 2016+ (or Oct 2015+ if you want to risk it!) Those manufactured before this date are too old and would have the old, incompatible MT1939 drive platform.
HSH1979
Re: LG BH16NS40
Post by HSH1979 »
ok so mine is not compatible... any suggestion what i can buy? i dont woant to spend too much, approx 90-100€ maximum (PC device, both internal sata or external usb are ok)
Re: LG BH16NS40
HSH1979 wrote: Thu Jul 09, 2026 2:12 pm ok so mine is not compatible... any suggestion what i can buy? i dont woant to spend too much, approx 90-100€ maximum (PC device, both internal sata or external usb are ok)
I don't think any manufacturer is actually producing new optical drives any more. The supply of new drives will dwindle until there is none. If you want a new drive, they can still be found but they won't be cheap. Any cheap ones you find are likely to be fake or too old to rip UHDs.
A seller on this forum, based in Europe, Asmcom, will soon open his store and sell the last batch of new drives he's likely to ever get. It will undoubtedly cost significantly more than 100€ but it'll be flashed and tested to work. A buy-once, cry-once situation.
Otherwise the Ultimate UHD Drives Flashing Guide has a list of drive models that can be flashed to work.
HSH1979
Re: LG BH16NS40
Post by HSH1979 »
T hanks, i found something on amazon for 110€ , but not sure is worth the cost, i have only 2-3 uhd disks, maybe in the future i will buy a ps5 to read them directly, i dont need to rip.
or any suggestion on what to buy (around 100€) thanks!
Sayaka
Re: LG BH16NS40
Post by Sayaka »
PM sent.
HSH1979
Re: LG BH16NS40
Post by HSH1979 »
Drive platform: MT1939
Firmware version: 1.02
BD raw metadata read: Partial
so i think i need a new unit... cheap possibly :) not 150€
Sayaka
Re: LG BH16NS40
Post by Sayaka »
PM sent, but if anyone has any additional advice for HSH1979, by all means feel free to post it here.
