Public KeyDB Disc Submissions
NotaNumber
Post by NotaNumber »
Disc type: UHD
Disc ID: 68313E7F9048F182EFBF70938EF15271A5856B2A
Disc dump filename: MKB20_v76_Mad_Max_534F
Drive: BD-RW BDR-S12U
Drive firmware: 1.02/ID43
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.proton.me/urls/A03ZCRXKAR#DGMXI00ahqAa
Disc dump link: https://drive.proton.me/urls/0S7V2HC04M#BpcqETCtRI3e
Mad Max 4K UHD Kino Lorber
eNoize
Post by eNoize »
Disc type: 4K UHD
Disc dump filename: MKB20_v82_Click_25F1
Drive: ASUS BW-16D1HT
Drive firmware: 10.0.26100.8328
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
Disc dump link: https://drive.google.com/drive/folders/ ... 3-imorl0Zv
MrPenguin
Post by MrPenguin »
eNoize wrote: Tue Jun 30, 2026 10:07 pm Disc type: 4K UHD
Did you sync the public keydb within the last 15 minutes? NO
This disk was already added to the public KEYDB.cfg file on June 20th.
jack_ripper
Post by jack_ripper »
Disc type: UHD
Disc ID: 99f6bc9102477abefd394b09030e99e2de74e596
Disc dump filename: MKB20_v70_Apocalypse_Now_-_Final_Cut_-_UHD_40B9
Drive: PIONEER BD-RW BDR-S11
Drive firmware: 1.53
LibreDrive status: Enabled, v02.1 id=341479DBE353
MKB_RO.inf: https://drive.proton.me/urls/AV37Z8HBPW#TaQaqqjue8tH
Disc dump link: https://drive.proton.me/urls/09M2TDR600#EAefyJ21Kdmk
keydb_helper
Post by keydb_helper »
NotaNumber wrote: Tue Jun 30, 2026 2:53 pm Disc type: UHD
Thanks for the new disc dump NotaNumber. Your disc has been added to the public keydb.
Support for MKB20_v82_Maurice_D158 was also added to the public keydb.
eNoize wrote: Tue Jun 30, 2026 10:07 pm Drive: ASUS BW-16D1HT
Drive firmware for the BW-16D1HT would be something like "3.02" or "3.10MK". I've seen a few folks now mix-up this up with the Windows driver version.
I might drop the drive firmware field from the submission template as it is no longer relevant for the purposes of the public keydb.
jack_ripper wrote: Wed Jul 01, 2026 2:38 am Disc type: UHD
MKB_RO.inf: ...
Hi Jack, I was very clear in the opening post of this thread that you should provide the full, multi-megabyte MKB_RO.inf file from the disc. What did you think would be achieved by extracting the 56 byte MKB_RO.inf file from the disc dump file and uploading it separately?
Your disc has been added to the public keydb but without the full MKB_RO.inf file this was only possible because the media key of your disc was already known to the public keydb.
