thedavidweng
Post
by thedavidweng » Wed Jun 24, 2026 5:45 am
seamus wrote: Sun Jun 21, 2026 5:31 am
This question may have already been answered - but I couldn't find it! Is there a version of the SDF tool that runs on macOS (Sequoia)??
If not - are there any recommendations for a firmware upgrade for my BRXL-16U3 (Buffalo)?
FWIW: This is a fairly recent model, bought new in 2025.
Thanks,
~S
This is my cross-platform app inspired by SDFool Flasher.
It's not tested by anyone else so use it at your own risk, but the app is honestly just a wrapper for sdftool/makemkvcon very simple.
https://github.com/thedavidweng/sdf-flash-gui
subduedcarrot
Post
by subduedcarrot » Thu Jun 25, 2026 8:39 pm
MartyMcNuts wrote: Wed Jun 24, 2026 1:36 am
subduedcarrot wrote: Tue Jun 23, 2026 2:24 am
Thanks for the reply - yes, I've been trying using the original USB-A y-cable. I've tried plugging it into two USB 3.0 ports on my laptop and I even tried plugging both cables into
this powered USB hub and it still wouldn't read.
When I put in the UHD disc, the drive will make a click/honk/skid sound every ~6 seconds or so for about 2 minutes before stopping. During this time in MakeMKV, it will just say "Loading" until it stops and says "No disc inserted". Same thing as when I click on the drive in This PC - it will try for about 2 minutes before ejecting the disc tray.
Most laptop USB ports do not provide enough, consistent, constant power for an optical drive. I also don't think your hub is powerful enough. It's ok for charging and using USB sticks but I doubt it can provide enough juice for an optical drive. It "might" if the USB-C ports can be used for something other than charging. There are only a few compatible AC powered hub models that are recommended in the Ultimate UHD Drive Guide 2026.
I just received
this powered USB hub today based off a recommendation I came across from billycar11 in a Reddit thread and I'm still getting the same result - the drive is still refusing to read my UHD disc.
seamus
Post
by seamus » Fri Jun 26, 2026 3:11 am
thedavidweng wrote: Wed Jun 24, 2026 5:45 am
Thanks,
~S
It looks good! But I'd prefer to be able to do this from the MakeMKV app itself... as some here have said can be done. I've been trying to find some instructions for how to do that, but the replies I've gotten have not helped... it's almost like this is some sort of "insider secret" ?
~S
Post
by dcoke22 » Fri Jun 26, 2026 4:22 am
seamus wrote: Fri Jun 26, 2026 3:11 am
~S
MakeMKV has command line functionality that can be used to flash LG based drives. The SDFtool is a Windows application that provides a Windows GUI interface to that command line functionality. The app thedavidweng pointed to appears to be a Mac application that provides a GUI interface to the command line flashing functionality of MakeMKV just like SDFtool. (I haven't used that app so can't vouch for it.) If you prefer, you can use the command line functions directly. The
Ultimate UHD Drives Flashing Guide has instructions on how to do so.
There is no GUI flashing interface built into MakeMKV directly.
JoaquinBusteloJr
Post
by JoaquinBusteloJr » Fri Jun 26, 2026 6:00 pm
I'm also trying to use this flasher, and it's loading in a bizarre aspect ratio where I can't hardly see the drop down options. Is anyone else having this issue?
Post
by dcoke22 » Fri Jun 26, 2026 10:37 pm
JoaquinBusteloJr wrote: Fri Jun 26, 2026 6:00 pm
Near the top of the
very first post in this thread is this note that might help you:
NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
seamus
Post
by seamus » Sat Jun 27, 2026 3:51 am
dcoke22 wrote: Fri Jun 26, 2026 4:22 am
~S
I have an Asus drive, and a Buffalo drive. They are both connected to my Mac - I do not have a Windows machine. I've ripped DVDs on both drives, BDs on the Asus (and maybe on the Buffalo). I favor the Asus drive because it's faster than the Buffalo. The "specs" on both drives as displayed in MakeMKV are provided below... Note that the Buffalo drive says that Libre drive is
"Possible, not yet enabled". But I do not recall doing anything to enable the Asus drive! I guessed that this happened "automatically"??
I have read the "Ultimate UHD Drives Flashing Guide" at least 3 times now, and I must be dumb or blind b/c I can see no explicit instructions for "enabling" Libre drive. I have also failed to find explicit instructions re what must be done to enable (one or both) of my drives to copy 4K (UHD?) discs. If you could take a moment to point out what I have missed, I would really appreciate it. Hopefully - I can enable one or both drives to copy 4K/UHD without having to use "external" software - but if that's necessary, I think I can manage it - once I know what it is I am supposed to do.
Many, many thanks!
~S
Asus:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL123365WL
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
Buffalo:
Product: BD-RE BH16NS58
Revision: 1.03
Serial number: KX1OA8I3438
Firmware date: 2120-05-08 09:33
Bus encryption flags: 1F
Post
by Billycar11 » Sat Jun 27, 2026 6:39 am
seamus wrote: Sat Jun 27, 2026 3:51 am
Many, many thanks!
~S
Asus:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Buffalo:
Revision: 1.03
the asus you need external help see email below for that as its a pioneer
the buffalo is a LG and can be done by following the guide flow chart and sdf tool for wh16ns40/60
or you can email me or marty for an auto flasher for the lg too
seamus
Post
by seamus » Sun Jun 28, 2026 12:44 am
Billycar11 wrote: Sat Jun 27, 2026 6:39 am
Many, many thanks!
~S
Asus:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Buffalo:
Revision: 1.03
[/quote]
Billy,
That is some pretty messy quoting
I appreciate your trying to help, but frankly I don't think it's working. FWIW, it seems to me you're not interested in giving "readable" instructions, but prefer to sell me something... and I cannot for the life of me understand whether or not I need it. Maybe take a break? I was hoping to get an answer to my question from 'dcoke22', but maybe that's not going to happen now.
~S
Post
by MartyMcNuts » Sun Jun 28, 2026 2:41 am
seamus wrote: Sun Jun 28, 2026 12:44 am
Many, many thanks!
~S
Asus:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Buffalo:
Revision: 1.03
Billy,
~S
[/quote]
Your ASUS actually contains a Pioneer BDR-212 drive inside. There is no publicly available flasher for Pioneer drives. Billy can sell you a flasher for this drive if you want to be able to rip UHD discs with it. If not, you can leave it as is.
Your Buffalo contains a LG drive inside which can be flashed using SDFtool Flasher on windows or via the command line on Linux/Mac. The Ultimate UHD Drive Guide 2026 (first post) contains CLI instructions. The recommended firmware for this drive is WH16NS60 1.02-MK.
Post
by Billycar11 » Sun Jun 28, 2026 12:35 pm
Billy,
~S
take a break from belittling the people trying to help you
the guide has clear readable instructions with flow charts of what fw to flash and cli examples for people on linux
im not going to post the whole guide here for you will just complain its messy anyway i pointed you to it from my sig
seamus
Post
by seamus » Mon Jun 29, 2026 8:30 am
Billycar11 wrote: Sun Jun 28, 2026 12:35 pm
Billy,
~S
No one is "belittling" you, but again, frankly... you are not helping! If you want to be offended, OK, go ahead - but I see no point in mincing words. I'm only trying to be clear. And I don't feel there's any point debating how "readable" the guide is... I can only say again that when I read it - I do not get it!
Post
by Billycar11 » Mon Jun 29, 2026 8:38 am
seamus wrote: Mon Jun 29, 2026 8:30 am
hundreds of thousands of people have flashed their drives and been helped with the guide its fine.
if you can do it better make one
seamus
Post
by seamus » Mon Jun 29, 2026 9:14 am
@thedavidweng:
I've been to your GitHub site & read through that - a couple of questions:
1. IIUC, I do not actually need "Homebrew" to install your tool - I can go to the "Releases" page, and download the .dmg file for my "architecture" (ARM or Intel) - is that correct?
2. Does the .dmg file contain
*everything* that's needed to flash a drive? IOW, does it include the optical drive firmware, and the software app to apply it? Does it require that any other software/firmware be installed to use it - in other words, MakeMKV or SDFtool or firmware blobs, or ...??
Anything?
seamus
Post
by seamus » Mon Jun 29, 2026 9:17 am
Billycar11 wrote: Mon Jun 29, 2026 8:38 am
If I could "do it better", do you actually believe I'd be here asking these questions?
