Public KeyDB Disc Submissions
MKVDUDE
#2641 Post by MKVDUDE » Fri Jun 26, 2026 4:55 pm
Another one please - All files are in the same link - https://we.tl/t-o5Am8KgZZXOegjpH
Disc type: BD
Disc ID: 0aa47d9916e6345bf875e94e99934acd1967b274
Disc dump filename: MKB20_v82_THE_DESCENT_F0C0.tgz
Drive: MT1959
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://we.tl/t-o5Am8KgZZXOegjpH
Disc dump link: https://we.tl/t-o5Am8KgZZXOegjpH
Many thanks!
lomatas680
#2642 Post by lomatas680 » Fri Jun 26, 2026 8:22 pm
Disc type: UHD
Disc ID: a111c698554c6af960c84f55b9d6615f1bbe6327
Disc dump filename: MKB21_v70_Zombieland_0C05
Drive: HL-DT-ST BD-RE BH16NS55
Drive firmware: 1.05
MKB_RO.inf link: https://we.tl/t-p29mGJyN3jDoMFo1
Disc dump link: https://we.tl/t-p29mGJyN3jDoMFo1
#2643 Post by MartyMcNuts » Fri Jun 26, 2026 10:55 pm
Thragg_was_taken wrote: Fri Jun 26, 2026 2:24 am apologies thats a fair point
MakeMKV v1.18.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
The AACS dump file "C:\Users\jhysl/.MakeMKV/MKB20_v77_Terrifier3_53A7.tgz" was successfully sent for analysis
Disc type: UHD
Disc ID: b2b8a698713d002393e2a649b5059b58f562b01e
Disc dump filename: MKB20_v77_Terrifier3_53A7.tgz
Drive: HL-DT-ST BD-RE BU40N (Verbatim External Slimline 4K)
Drive firmware: 1.03 MK (Patched)
Did you sync the public keydb within the last 15 minutes? No
MKB_RO.inf link (Do not just extract from the dump - copy from the disc):[/bMKB20_v77_Terrifier3_53A7.tgz]
Disc dump link:https://mega.nz/file/uGQ0ULDb#Uf91XnnL9 ... Du7Li_9gx8
https://mega.nz/file/vbhglAib#1J1pVZbpZ ... hsTy9EKqUg
You should always sync your KeyDB first then try your disc before proceeding with posting and uploading your dump file for processing as if your disc has been added already, you are just wasting people's time.
Also, did you email the dump file to svq@makemkv.com so that Mike can process it and add the key to MakeMKV's internal hashed keys database? If not, please do so.
keydb_helper
#2644 Post by keydb_helper » Fri Jun 26, 2026 11:53 pm
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_Kiss_of_the_Spider_Woman_3E66
*MKB20_v82_MEMENTO_537A
MKB20_v82_MEMORIES_0A1F
*MKB20_v82_POLICE_STORY_3_SUPER_COP_1A06
*MKB20_v82_POLICE_STORY_ARMAS_INVENCIBLES_67FC
*MKB20_v82_POLICE_STORY_II_SUPER_POLICIA_DCCC
*MKB20_v82_THE_DESCENT_F0C0
lomatas680 wrote: Fri Jun 26, 2026 8:22 pm Disc type: UHD
MakeMKV doesn't utilise the public keydb for AACS 2.1 titles.
MKVDUDE
#2645 Post by MKVDUDE » Sat Jun 27, 2026 2:39 pm
Another few please - All files are in the same link - https://we.tl/t-LOEmpsF2ypwB8Piz
Disc type: BD
Disc ID:b62cd06ba701abbc2efc5b41b4876d48629a3294
Disc dump filename:MKB20_v82_BILL_AND_TED'S_BOGUS_JOURNEY_D138.tgz
Drive: MT1959
MKB_RO.inf link: https://we.tl/t-LOEmpsF2ypwB8Piz
Disc dump link: https://we.tl/t-LOEmpsF2ypwB8Piz
Disc type: BD
Disc ID:b1dd64a7fd8b5115d2a8a19b52afd09dd5b7910a
Disc dump filename: MKB20_v82_TROY_-_THEATRICAL_CUT_CF52.tgz
Drive: MT1959
Disc type: BD
Disc ID:48f59416dfdc4cf28e29a90e2cc3ef84f6d49efb
Disc dump filename: MKB20_v82_TROY_-_DIRECTOR'S_CUT_(UHD)_C6C4.tgz
Drive: MT1959
Disc type: BD
Disc ID:ca78ebcf847344834123c31859b9b5d7a7a2fda6
Disc dump filename: MKB_v82_TROY_-_BONUS_DISC_F8B4.tgz
Drive: MT1959
Many thanks!
keydb_helper
#2646 Post by keydb_helper » Sat Jun 27, 2026 3:22 pm
MKVDUDE wrote: Sat Jun 27, 2026 2:39 pm Another few please - All files are in the same link
Disc ID: 0xCCBDCF756C10132E804EEEC91F9AF0A1FBC8EEFB
Disc ID: 0x30610AB594188B283ABC17628B9E75B673E0BB6F
Disc ID: 0x11694F7A5C66D0D3BFF2C0EE524A8692BC3A46AE
Disc ID: 0xC8E56CB238E7F6D2D9F6E4DB1932EB18FE12BCC8
Thanks for the submission MKVDUDE. All four discs have been added to the public keydb.
For future reference, the libaacs disc ID is the SHA-1 hash of the Unit_Key_RO.inf file. I'm not quite sure how you calculated your ID values, so I've added in bold the correct values for your discs.
MKVDUDE
#2647 Post by MKVDUDE » Sat Jun 27, 2026 5:16 pm
keydb_helper wrote: Sat Jun 27, 2026 3:22 pm
I was using a Hash program selecting SHA-1 - but for some reason as you pointed out they are giving different values. I have check again using Terminal and they match the codes you have provided - so will use that way from now on. Many Thanks
