Public KeyDB Disc Submissions
badboy
Post by badboy »
Disc type:UHD
Disc ID:B3BCCC71180573C3E75634A78043466957B043A1
Disc dump filename:MKB20_v82_LA_COLLINE_A_DES_YEUX_-_4K_UHD_7CC6
Drive:BW-16D1H-U
Drive firmware:A204
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link :https://drive.google.com/file/d/1fVsk44 ... VMi9CgaawT
Disc dump link:https://drive.google.com/file/d/1Zqx7U7 ... V3ish7Ema8
MrPenguin
Post by MrPenguin »
tomty89 wrote: Wed Jun 24, 2026 9:34 pm And the question is, what should I do? Should I just post the VUK et al. here? Or do I have to run FindVUK anyway? (I'm on Linux but probably it works through wine?)
P.S. AFAIK both the drive and the disc is non-BEE, if that matters. I mounted the filesystem and used rsync -rvc to compare its content with an encrypted backup made with MakeMKV, and as per the result they are identical. However I haven't exactly "validated" the VUK by decrypting it with libaacs (and compare the result with the decrypted backup from MakeMKV).
FindVUK works fine inside a wineconsole on Linux. You would need to add an entry for your disk to your KEYDB.cfg file, and then execute "findvuk validateDisc" to have FindVUK prove that your entry is correct, and then upload it into the database. For example:
$ wineconsole findvuk validateDisc drive=e
where your UHD drive would be identified by letter E.
You calculate the disk's ID like this:
$ sha1sum /path/to/your/disk/AACS/Unit_Key_RO.inf
If your disk did use BEE then either libaacs would need to know the correct RDK to use, or you'd need to use MakeMKV to disable bus encryption before invoking FindVUK. Note also that FindVUK.ini has a "Disable_Bus_Encryption_Cmd" option:
If you know the RDK then you don't need to disable bus encryption:
Disable_Bus_Encryption_Cmd =
Or if you need a "dummy" command for FindVUK to execute so that it knows you have already disabled BE yourself:
Disable_Bus_Encryption_Cmd = hostname.exe
Remember that FindVUK's libaacs will have a totally different KEYDB.cfg file to $HOME/.config/aacs/KEYDB.cfg, and cache to $HOME/.cache/aacs
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_Fast_and_Furious_6_3A77
*MKB20_v82_Beast_-_Legenden_entstehen_im_Käfig_E938
*MKB20_v82_Deathstalker_(1983)_64E4
*MKB20_v82_Deathstalker_(2025)_10DA
*MKB20_v82_Deathstalker_II_9182
*MKB20_v82_LA_COLLINE_A_DES_YEUX_-_4K_UHD_7CC6
*MKB20_v82_Rumble_in_the_Bronx_UHD (Hong Kong version - 0x3C105928B879DE0620420A73B91F2690D7DA3D29)
*MKB20_v82_The_Descent_AE32
*MKB20_v82_THE_DRAMA_771A
*MKB20_v82_THE_ELEPHANT_MAN_F918
*MKB20_v82_The_Money_Pit_3862
Public KeyDB Disc Submissions KeyDB Download
Thragg_was_taken
Post by Thragg_was_taken »
am having trouble ripping my copy of terrifer 3
Giving people some information about errors received would be normal, when sending a message in this thread. The first message in the topic describes what is needed.
Thragg_was_taken
apologies thats a fair point
MakeMKV v1.18.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
The AACS dump file "C:\Users\jhysl/.MakeMKV/MKB20_v77_Terrifier3_53A7.tgz" was successfully sent for analysis
Disc type: UHD
Disc ID: b2b8a698713d002393e2a649b5059b58f562b01e
Disc dump filename: MKB20_v77_Terrifier3_53A7.tgz
Drive: HL-DT-ST BD-RE BU40N (Verbatim External Slimline 4K)
Drive firmware: 1.03 MK (Patched)
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? No
MKB_RO.inf link (Do not just extract from the dump - copy from the disc):[/bMKB20_v77_Terrifier3_53A7.tgz]
Disc dump link:https://mega.nz/file/uGQ0ULDb#Uf91XnnL9 ... Du7Li_9gx8
https://mega.nz/file/vbhglAib#1J1pVZbpZ ... hsTy9EKqUg
Last edited by Thragg_was_taken on Fri Jun 26, 2026 2:29 am, edited 1 time in total.
tomty89
Post by tomty89 »
MrPenguin wrote: Thu Jun 25, 2026 11:30 am FindVUK works fine inside a wineconsole on Linux. You would need to add an entry for your disk to your KEYDB.cfg file, and then execute "findvuk validateDisc" to have FindVUK prove that your entry is correct, and then upload it into the database. For example:
Actually in my case I simply need to go for the AACSkeys method, since it's a regular BD and the host cert/key in KeyDB hasn't been revoked in drive yet.
Btw I almost gave up because things didn't work at the beginning. The different methods either gave me weird "BRAKEYS_DriveNotFound" error or "AACS folder on disc is not accessible". Only after messing with aacs_info from libaacs (which gives me many "corrupt" lines when I pass the device node as argument, while bd_info from libbluray works just fine) and then I realize not all programs / libraries can deal with the UDF filesystem "directly" like libbluray, and therefore for FindVUK to work through wine, I need to have the filesystem on the disc mounted (even though the "drive letter / dosdevice" is / has to be a symlink to the device node, namely /dev/srN...)
(Although most people that is not like me but uses a DE / prefers "automounting" wouldn't even bump into this problem in the first place I guess...)
mwwtdl
Post by mwwtdl »
Disc type: UHD
Disc ID: 0xA4A210D6257EB714200175EBBF520D7931CD4D1C
Disc dump filename: MKB20_v82_THE_WARNING_6E7A.tgz
Drive firmware: 1.03 (LibreDrive patched)
Have you verified that all submission links are accessible in incognito/private browsing? (verify this before posting — open an incognito window and confirm the Google Drive link works)
MKB_RO.inf link: N/A (dump file is 3.29MB, full dump)
Disc dump link: https://drive.google.com/file/d/1Yh4kTa ... sp=sharing
hover
Post by hover »
hi, please help me with these two, thanks.
Drive: HL-DT-ST BD-RE BU50N
Drive firmware: 1.0
Disc type: UHD
Disc ID: 0x0A110200738B0CB573F232363B525971380170FC
Disc dump filename: MKB20_v76_Spider-Man-_Across_The_Spider-Verse_0D04
MKB_RO.inf link: https://drive.google.com/file/d/17Nl0IM ... drive_link
Disc dump link: https://drive.google.com/file/d/12-64d3 ... drive_link
Disc type: UHD
Disc ID: 0xE8D39774C5708088ADE30E8FED36A3765733CC6E
Disc dump filename: MKB20_v68_SPIDER-MAN_INTO_SPIDER-VERSE_3BF1
MKB_RO.inf link: https://drive.google.com/file/d/1yK1Fum ... drive_link
Disc dump link: https://drive.google.com/file/d/1niFSOf ... drive_link
keydb_helper
*MKB20_v68_SPIDER-MAN_INTO_SPIDER-VERSE_3BF1
*MKB20_v76_Spider-Man-_Across_The_Spider-Verse_0D04
*MKB20_v77_Terrifier3_53A7
*MKB20_v82_The_Super_Mario_Galaxy_Movie_8CD8
By my count the public keydb now has 8,000 UHD entries with full keys (MK, VID, VUK, and UK). Hopefully the gap between the number of UHD entries (12,417) and the number of full key UHD entries continues to drop.
Thragg_was_taken wrote: Fri Jun 26, 2026 2:12 am am having trouble ripping my copy of terrifer 3
Thragg_was_taken wrote: Fri Jun 26, 2026 2:24 am apologies thats a fair point
Nice save.
mwwtdl wrote: Fri Jun 26, 2026 7:40 am Disc type: UHD
Hey mwwtdl, your disc was added to the keydb on June 2. This was fortunate as your disc dump is incomplete due to your drive encountering a transient fault. Whenever you see output like this in your log it means the disc dump file is not going to be usable by either the MakeMKV team or the keydb community:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at (FS[Bh5JS4pc>jdxo:213130306
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at <;%3f(R'*M-9Mw'L}6:121264395
DEBUG: Code 4 at <;%3f(R'*M-9Mw'L}6:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
You don't need to reflash your drive firmware or make any configuration changes. Powering down your drive completely should sort it out.
MKVDUDE
Post by MKVDUDE »
Another one please - All files are in the same link - https://we.tl/t-o5Am8KgZZXOegjpH
Disc type: BD
Disc ID: 0aa47d9916e6345bf875e94e99934acd1967b274
Disc dump filename: MKB20_v82_THE_DESCENT_F0C0.tgz
Drive: MT1959
MKB_RO.inf link: https://we.tl/t-o5Am8KgZZXOegjpH
Disc dump link: https://we.tl/t-o5Am8KgZZXOegjpH
Many thanks!
lomatas680
Post by lomatas680 »
Disc type: UHD
Disc ID: a111c698554c6af960c84f55b9d6615f1bbe6327
Disc dump filename: MKB21_v70_Zombieland_0C05
Drive: HL-DT-ST BD-RE BH16NS55
Drive firmware: 1.05
MKB_RO.inf link: https://we.tl/t-p29mGJyN3jDoMFo1
Disc dump link: https://we.tl/t-p29mGJyN3jDoMFo1
Disc type: UHD
You should always sync your KeyDB first then try your disc before proceeding with posting and uploading your dump file for processing as if your disc has been added already, you are just wasting people's time.
Also, did you email the dump file to svq@makemkv.com so that Mike can process it and add the key to MakeMKV's internal hashed keys database? If not, please do so.
keydb_helper
*MKB20_v82_Kiss_of_the_Spider_Woman_3E66
*MKB20_v82_MEMENTO_537A
MKB20_v82_MEMORIES_0A1F
*MKB20_v82_POLICE_STORY_3_SUPER_COP_1A06
*MKB20_v82_POLICE_STORY_ARMAS_INVENCIBLES_67FC
*MKB20_v82_POLICE_STORY_II_SUPER_POLICIA_DCCC
*MKB20_v82_THE_DESCENT_F0C0
lomatas680 wrote: Fri Jun 26, 2026 8:22 pm Disc type: UHD
MakeMKV doesn't utilise the public keydb for AACS 2.1 titles.
MKVDUDE
Post by MKVDUDE »
Another few please - All files are in the same link - https://we.tl/t-LOEmpsF2ypwB8Piz
Disc type: BD
Disc ID:b62cd06ba701abbc2efc5b41b4876d48629a3294
Disc dump filename:MKB20_v82_BILL_AND_TED'S_BOGUS_JOURNEY_D138.tgz
Drive: MT1959
MKB_RO.inf link: https://we.tl/t-LOEmpsF2ypwB8Piz
Disc dump link: https://we.tl/t-LOEmpsF2ypwB8Piz
Disc type: BD
Disc ID:b1dd64a7fd8b5115d2a8a19b52afd09dd5b7910a
Disc dump filename: MKB20_v82_TROY_-_THEATRICAL_CUT_CF52.tgz
Drive: MT1959
Disc type: BD
Disc ID:48f59416dfdc4cf28e29a90e2cc3ef84f6d49efb
Disc dump filename: MKB20_v82_TROY_-_DIRECTOR'S_CUT_(UHD)_C6C4.tgz
Drive: MT1959
Disc type: BD
Disc ID:ca78ebcf847344834123c31859b9b5d7a7a2fda6
Disc dump filename: MKB_v82_TROY_-_BONUS_DISC_F8B4.tgz
Drive: MT1959
Many thanks!
