Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin » Sun Jun 21, 2026 11:30 pm
mm8718 wrote: Sun Jun 21, 2026 10:07 pm Disc ID:d66aae87ee51eec72cec9997a30662fd5b6ac227
Disc dump filename:MKB20_v82_UPHE_UPK1-1135760R0_8700
This dump doesn't contain the metadata needed to calculate a full KEYDB entry, because you seem to have copied the files directly to your hard-drive and then used MakeMKV to open them from there. Can you use MakeMKV to create a discatt.dat file for your UHD disk please? Basically, you would need to start an encrypted disk back-up into a temporary directory, wait for the discatt.dat file to appear, copy the file to somewhere safe and then cancel the back-up.
mattmak464
Post by mattmak464 » Mon Jun 22, 2026 1:11 am
Disc type: UHD
Disc ID: 0x699E789804BB96A3AD1E3ADBEE0C4713C81EB66C
Disc dump filename: MKB20_v82_Scream_7_3B05.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1Fzf7mz ... share_link
Disc dump link: https://drive.google.com/file/d/10ohofB ... share_link
sunday46ma
Post by sunday46ma » Mon Jun 22, 2026 2:06 am
Disc type:UHD
Disc ID:4634FC617BAFC162C326C105D727105D3BEB9B25
Disc dump filename:MKB20_v82_The_Pornographers_UHD_174E
Drive:BW-16D1HT
Drive firmware:MT1959
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: https://drive.google.com/file/d/11N8mNl ... drive_link
Disc dump link:https://drive.google.com/file/d/1jbQrkz ... drive_link
mm8718
Post by mm8718 » Mon Jun 22, 2026 11:53 am
MrPenguin wrote: Sun Jun 21, 2026 11:30 pm
Please find updated dump here: https://drive.google.com/file/d/10NjvPT ... sp=sharing
HEHAHE
Post by HEHAHE » Mon Jun 22, 2026 1:07 pm
Disc type: BD
Disc ID: N/A
Disc dump filename: MKB_v82_BD_ROM_622C.tgz
Drive: ASUS SBW-06D2X-U
Drive firmware: A102
LibreDrive status: Possible, not enabled
MKB_RO.inf link:https://drive.google.com/file/d/1N7jpVp ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1UadUNt ... sp=sharing
axelmace
Post by axelmace » Mon Jun 22, 2026 7:56 pm
Ready or Not 2: Here I Come (Noche de bodas 2) Standard Blu-ray - Spain (Divisa Films)
Disc title: Ready or Not 2: Here I Come (Noche de bodas 2)
Country: Spain
Publisher: Divisa Films
Format: Standard Blu-ray
AACS: MKB20 v82
Unknown volume key:
MKB_v82_READY_OR_NOT_2-_HERE_I_COME_624A
The dump file has already been submitted to [svq@makemkv.com](mailto:svq@makemkv.com).
Thanks.
AnBird
Post by AnBird » Tue Jun 23, 2026 1:29 am
Final Countdown 3CC9
Disc type: UHD
Disc ID: 49DFB292B1BCE58D79635F3404320A9CDB338567
Disc dump filename: MKB20_v76_FINAL_COUNTDOWN_3CC9
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://mega.nz/file/8AhAHCpS#U3U4EMOOR ... WbhMn4QMak
Disc dump link: https://mega.nz/file/cdwFkTKY#OQYxdN29D ... KNK74vIhlI
bdsucker
Post by bdsucker » Tue Jun 23, 2026 10:07 am
Disc type: UHD
Disc ID: 0xDBA1138C28A62ABDF5A441C79AB44DB49709E114
Disc dump filename: MKB20_v82_Rocco_and_His_Brothers_UHD_328A
Drive: BW-16D1HT
Drive firmware: 3.00
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.mediafire.com/file/0v8omlzq ... O.inf/file
Disc dump link: https://www.mediafire.com/file/1wt2qjh4 ... A.tgz/file
keydb_helper
Post by keydb_helper » Tue Jun 23, 2026 11:29 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v61_Fast_&_Furious_8_464B
*MKB20_v76_FINAL_COUNTDOWN_3CC9
MKB20_v82_50_First_Dates_9DD3
mkb20_v82_air_borne_b2a9
*MKB20_v82_BLU-RAY_UHD_342E (Marty Supreme)
*MKB20_v82_CHARADE_UHD_41E2
MKB20_v82_Macabre_UHD_2A7B
*MKB20_v82_Mother's_Pride_9E40
*MKB20_v82_Rocco_and_His_Brothers_UHD_328A
*MKB20_v82_The_Pornographers_UHD_174E
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
caseablee
Post by caseablee » Wed Jun 24, 2026 6:32 pm
Disc type: UHD
Disc dump filename: MKB20_v77_The_Fast_and_the_Furious_F685
Drive: BDR-XD07U
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/drive/folders/ ... rAYjP8OKvy
Disc dump link: https://drive.google.com/drive/folders/ ... rAYjP8OKvy
caseablee
Post by caseablee » Wed Jun 24, 2026 7:46 pm
Disc type: UHD
Disc dump filename: MKB20_v77_Fast_and_Furious_6_3A77
Drive: BDR-XD07U
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/drive/u/0/fold ... 8fGY-7r5j_
Disc dump link: https://drive.google.com/drive/u/0/fold ... 8fGY-7r5j_
tomty89
Post by tomty89 » Wed Jun 24, 2026 9:34 pm
Hello. So I have an old title (regular / non-UHD BD) with MKBv37 and this drive that hasn't been inserted with disc with a newer MKB. With the host cert/key provided in KeyDB I've managed to obtain the VUK through libaacs, and I would like to have it added to the KeyDB (if key for such older title are still being accepted).
And the question is, what should I do? Should I just post the VUK et al. here? Or do I have to run FindVUK anyway? (I'm on Linux but probably it works through wine?)
P.S. AFAIK both the drive and the disc is non-BEE, if that matters. I mounted the filesystem and used rsync -rvc to compare its content with an encrypted backup made with MakeMKV, and as per the result they are identical. However I haven't exactly "validated" the VUK by decrypting it with libaacs (and compare the result with the decrypted backup from MakeMKV).
OldCavalier
Post by OldCavalier » Thu Jun 25, 2026 5:05 am
OldCavalier
Post by OldCavalier » Thu Jun 25, 2026 5:07 am
OldCavalier
Post by OldCavalier » Thu Jun 25, 2026 5:08 am
Deathstalker 2025 Arrow Video US Version
https://drive.google.com/drive/folders/ ... yrvdPoJ9rm
