Hi, I have the German 4K Steelbook of Avatar: Fire and Ash. My disc variant is D5BC, which seems to be different from the BB78 variant already posted here. Volume key is still unknown.
TGZ uploaded here: https://drive.google.com/file/d/13w-uIM ... sp=sharing
Hope this helps!
Avatar: Fire and Ash – German Steelbook D5BC variant – volume key unknown
Luca123
MrPenguin
Re: Avatar: Fire and Ash – German Steelbook D5BC variant – volume key unknown
The latest KEYDB.cfg file already has an entry for this disk. Have you also emailed your TGZ dump file to svq@makemkv.com? Or dids MakeMKV 1.18.4 subnit it automatically?Luca123 wrote: Sat Jun 20, 2026 11:24 pm Hi, I have the German 4K Steelbook of Avatar: Fire and Ash. My disc variant is D5BC, which seems to be different from the BB78 variant already posted here. Volume key is still unknown.
Luca123
Hi, thanks for your reply! I have MakeMKV 1.18.4 and downloaded the latest KEYDB.cfg today, but it still doesn't work. I'm still getting "volume key unknown". My variant is D5BC – could it be that this specific variant is not yet in the database?
I already sent the TGZ dump to svq@makemkv.com about 7 days ago, and MakeMKV also submitted it automatically. Still no luck.
TGZ file: https://drive.google.com/file/d/13w-uIM ... sp=sharing
MrPenguin
You need to copy the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restart MakeMKV. Your disk has a fully-validated entry in KEYDB, and so it must work...Luca123 wrote: Sun Jun 21, 2026 10:46 am Hi, thanks for your reply! I have MakeMKV 1.18.4 and downloaded the latest KEYDB.cfg today, but it still doesn't work.
Perhaps try using SamuriHL's KeyDB Assistant utility, to simplify the process?
Luca123
It works now, thank you so much! Really appreciate your help!
