Public KeyDB Disc Submissions
chucky527c
#2611 Post by chucky527c » Sun Jun 21, 2026 5:40 am
50 First Dates 4K UHD (US)
Disc type: UHD
Disc ID: 939df1eca338e09144e18ca23e2884dc2b7d79cf
Disc dump filename: MKB20_v82_50_First_Dates_9DD3
Drive: LG WH16NS40
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1MGF5WD ... p=drivesdk
Disc dump link: https://drive.google.com/file/d/1_ob_9o ... p=drivesdk
thenoim
#2612 Post by thenoim » Sun Jun 21, 2026 6:04 pm
Disc type: UHD
Disc ID: 0e5075b6f97e0093f8e764f2b573e6b6502e03ba
Disc dump filename: MKB20_v82_Angel's_Egg_9FEF.tgz
Drive: BW-16D1HT
Drive firmware: 2119-01-04 10:14
Did you sync the public keydb within the last 15 minutes? y
Have you verified that all submission links are accessible in incognito/private browsing? y
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://files.catbox.moe/vuawad.inf
Disc dump link: https://files.catbox.moe/ey7r02.tgz
HutchLee42
#2613 Post by HutchLee42 » Sun Jun 21, 2026 6:53 pm
Disc type: UHD
Disc ID: 0x15329D3AE7911C0C062F420262240D6F5263FE1A
Disc dump filename: MKB20_v82_Macabre_UHD_2A7B
Drive: BD-RW BDR-S12JX
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1Ov3eqN ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1KOan8q ... sp=sharing
mm8718
#2614 Post by mm8718 » Sun Jun 21, 2026 10:07 pm
EPiC: Elvis Presley in Concert (2025) UHD
Disc type:UHD
Disc ID:d66aae87ee51eec72cec9997a30662fd5b6ac227
Disc dump filename:MKB20_v82_UPHE_UPK1-1135760R0_8700
Drive:BD-RW BDR-S12U
Drive firmware:PIONEER BDR-212T
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: https://drive.google.com/file/d/1oianBT ... sp=sharing
Disc dump link:https://drive.google.com/file/d/10NjvPT ... sp=sharing
mm8718
#2615 Post by mm8718 » Sun Jun 21, 2026 10:13 pm
Mother's Pride (2026) UHD
Disc type:UHD
Disc ID:7cae5f3bea125dd90c264a527709afdea7453ff4
Disc dump filename:MKB20_v82_Mother's_Pride_9E40
MKB_RO.inf link: https://drive.google.com/file/d/18PvAA3 ... sp=sharing
Disc dump link:https://drive.google.com/file/d/1Cbr_0d ... sp=sharing
MrPenguin
#2616 Post by MrPenguin » Sun Jun 21, 2026 11:30 pm
mm8718 wrote: Sun Jun 21, 2026 10:07 pm Disc ID:d66aae87ee51eec72cec9997a30662fd5b6ac227
This dump doesn't contain the metadata needed to calculate a full KEYDB entry, because you seem to have copied the files directly to your hard-drive and then used MakeMKV to open them from there. Can you use MakeMKV to create a discatt.dat file for your UHD disk please? Basically, you would need to start an encrypted disk back-up into a temporary directory, wait for the discatt.dat file to appear, copy the file to somewhere safe and then cancel the back-up.
mattmak464
#2617 Post by mattmak464 » Mon Jun 22, 2026 1:11 am
Disc type: UHD
Disc ID: 0x699E789804BB96A3AD1E3ADBEE0C4713C81EB66C
Disc dump filename: MKB20_v82_Scream_7_3B05.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1Fzf7mz ... share_link
Disc dump link: https://drive.google.com/file/d/10ohofB ... share_link
sunday46ma
#2618 Post by sunday46ma » Mon Jun 22, 2026 2:06 am
Disc type:UHD
Disc ID:4634FC617BAFC162C326C105D727105D3BEB9B25
Disc dump filename:MKB20_v82_The_Pornographers_UHD_174E
Drive:BW-16D1HT
Drive firmware:MT1959
MKB_RO.inf link: https://drive.google.com/file/d/11N8mNl ... drive_link
Disc dump link:https://drive.google.com/file/d/1jbQrkz ... drive_link
