50 First Dates 4K UHD (US)
Disc type: UHD
Disc ID: 939df1eca338e09144e18ca23e2884dc2b7d79cf
Disc dump filename: MKB20_v82_50_First_Dates_9DD3
Drive: LG WH16NS40
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1MGF5WD ... p=drivesdk
Disc dump link: https://drive.google.com/file/d/1_ob_9o ... p=drivesdk
Public KeyDB Disc Submissions
Disc type: UHD
Disc ID: 0e5075b6f97e0093f8e764f2b573e6b6502e03ba
Disc dump filename: MKB20_v82_Angel's_Egg_9FEF.tgz
Drive: BW-16D1HT
Drive firmware: 2119-01-04 10:14
Did you sync the public keydb within the last 15 minutes? y
Have you verified that all submission links are accessible in incognito/private browsing? y
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://files.catbox.moe/vuawad.inf
Disc dump link: https://files.catbox.moe/ey7r02.tgz
Drive: BW-16D1HT
HutchLee42
Disc type: UHD
Disc ID: 0x15329D3AE7911C0C062F420262240D6F5263FE1A
Disc dump filename: MKB20_v82_Macabre_UHD_2A7B
Drive: BD-RW BDR-S12JX
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1Ov3eqN ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1KOan8q ... sp=sharing
EPiC: Elvis Presley in Concert (2025) UHD
Disc type:UHD
Disc ID:d66aae87ee51eec72cec9997a30662fd5b6ac227
Disc dump filename:MKB20_v82_UPHE_UPK1-1135760R0_8700
Drive:BD-RW BDR-S12U
Drive firmware:PIONEER BDR-212T
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: https://drive.google.com/file/d/1oianBT ... sp=sharing
Disc dump link:https://drive.google.com/file/d/10NjvPT ... sp=sharing
Disc type:UHD
Mother's Pride (2026) UHD
Disc type:UHD
Disc ID:7cae5f3bea125dd90c264a527709afdea7453ff4
Disc dump filename:MKB20_v82_Mother's_Pride_9E40
MKB_RO.inf link: https://drive.google.com/file/d/18PvAA3 ... sp=sharing
Disc dump link:https://drive.google.com/file/d/1Cbr_0d ... sp=sharing
Disc type:UHD
This dump doesn't contain the metadata needed to calculate a full KEYDB entry, because you seem to have copied the files directly to your hard-drive and then used MakeMKV to open them from there. Can you use MakeMKV to create a discatt.dat file for your UHD disk please? Basically, you would need to start an encrypted disk back-up into a temporary directory, wait for the discatt.dat file to appear, copy the file to somewhere safe and then cancel the back-up.mm8718 wrote: Sun Jun 21, 2026 10:07 pm Disc ID:d66aae87ee51eec72cec9997a30662fd5b6ac227
mattmak464
Disc type: UHD
Disc ID: 0x699E789804BB96A3AD1E3ADBEE0C4713C81EB66C
Disc dump filename: MKB20_v82_Scream_7_3B05.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1Fzf7mz ... share_link
Disc dump link: https://drive.google.com/file/d/10ohofB ... share_link
Drive: BD-RE BU40N
sunday46ma
Disc type:UHD
Disc ID:4634FC617BAFC162C326C105D727105D3BEB9B25
Disc dump filename:MKB20_v82_The_Pornographers_UHD_174E
Drive:BW-16D1HT
Drive firmware:MT1959
MKB_RO.inf link: https://drive.google.com/file/d/11N8mNl ... drive_link
Disc dump link:https://drive.google.com/file/d/1jbQrkz ... drive_link
Drive:BW-16D1HT
MrPenguin wrote: Sun Jun 21, 2026 11:30 pmThis dump doesn't contain the metadata needed to calculate a full KEYDB entry, because you seem to have copied the files directly to your hard-drive and then used MakeMKV to open them from there. Can you use MakeMKV to create a discatt.dat file for your UHD disk please? Basically, you would need to start an encrypted disk back-up into a temporary directory, wait for the discatt.dat file to appear, copy the file to somewhere safe and then cancel the back-up.mm8718 wrote: Sun Jun 21, 2026 10:07 pm Disc ID:d66aae87ee51eec72cec9997a30662fd5b6ac227
Please find updated dump here: https://drive.google.com/file/d/10NjvPT ... sp=sharing
Disc type: BD
Disc ID: N/A
Disc dump filename: MKB_v82_BD_ROM_622C.tgz
Drive: ASUS SBW-06D2X-U
Drive firmware: A102
LibreDrive status: Possible, not enabled
MKB_RO.inf link:https://drive.google.com/file/d/1N7jpVp ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1UadUNt ... sp=sharing
Disc ID: N/A
Ready or Not 2: Here I Come (Noche de bodas 2) Standard Blu-ray - Spain (Divisa Films)
Disc title: Ready or Not 2: Here I Come (Noche de bodas 2)
Country: Spain
Publisher: Divisa Films
Format: Standard Blu-ray
AACS: MKB20 v82
Unknown volume key:
MKB_v82_READY_OR_NOT_2-_HERE_I_COME_624A
The dump file has already been submitted to [svq@makemkv.com](mailto:svq@makemkv.com).
Thanks.
Country: Spain
AACS: MKB20 v82
Unknown volume key:
Thanks.
Final Countdown 3CC9
Disc type: UHD
Disc ID: 49DFB292B1BCE58D79635F3404320A9CDB338567
Disc dump filename: MKB20_v76_FINAL_COUNTDOWN_3CC9
Drive: BD-RE WH16NS60
MKB_RO.inf link: https://mega.nz/file/8AhAHCpS#U3U4EMOOR ... WbhMn4QMak
Disc dump link: https://mega.nz/file/cdwFkTKY#OQYxdN29D ... KNK74vIhlI
Disc type: UHD
Disc type: UHD
Disc ID: 0xDBA1138C28A62ABDF5A441C79AB44DB49709E114
Disc dump filename: MKB20_v82_Rocco_and_His_Brothers_UHD_328A
Drive: BW-16D1HT
Drive firmware: 3.00
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.mediafire.com/file/0v8omlzq ... O.inf/file
Disc dump link: https://www.mediafire.com/file/1wt2qjh4 ... A.tgz/file
Drive: BW-16D1HT
