Dump Submitted - Hamilton (2020) UHD Collectors Edition
bplewis24
The .tgz dump file was emailed just now: MKB20_v82_HAMILTON_1604.tgz
MrPenguin
Re: Dump Submitted - Hamilton (2020) UHD Collectors Edition
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?bplewis24 wrote: Sat Jun 20, 2026 12:20 am The .tgz dump file was emailed just now: MKB20_v82_HAMILTON_1604.tgz
If this doesn't work, could you upload your TGZ dump file into a file host such as Google Drive or OneDrive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
bplewis24
I downloaded the keydb file and placed it in the same folder as the dump tgz files, restarted MakeMKV and it appears to work now.MrPenguin wrote: Sat Jun 20, 2026 11:22 amHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?bplewis24 wrote: Sat Jun 20, 2026 12:20 am The .tgz dump file was emailed just now: MKB20_v82_HAMILTON_1604.tgz
Does that mean any time I run into a newly released disc that can't be read, I should re-download the keydb.cfg file from that link and copy that into the data folder again? Then, if that doesn't work, submit the dump files here?
Next time I will also include a google drive link to any submissions. But since it is working for me, I assume I no longer need to do that. Please let me know if you think differently.
Thanks.
MrPenguin
The public KEYDB.cfg file is an optional extra database of keys that MakeMKV can use, if it's available, so "yes" it's always worth a trybplewis24 wrote: Sat Jun 20, 2026 1:33 pm Does that mean any time I run into a newly released disc that can't be read, I should re-download the keydb.cfg file from that link and copy that into the data folder again? Then, if that doesn't work, submit the dump files here?
ubowersg
Just wanted to say thanks! This thread helped me solve the same issue I was having with a different disk.MrPenguin wrote: Sat Jun 20, 2026 11:22 amHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?bplewis24 wrote: Sat Jun 20, 2026 12:20 am The .tgz dump file was emailed just now: MKB20_v82_HAMILTON_1604.tgz
subduedcarrot
Can I ask what drive you're using? I've can't get my flashed BP50NB40 to read this disc. I even bought a brand new BRXL-PT6U2VB and can't get it to read this disc no matter what I try. But it worked in my PS5, so I originally thought it was a drive issue, but now I'm thinking maybe it's a disc issue.
