Public KeyDB Disc Submissions
samlop10
Post by samlop10 » Wed Jun 17, 2026 10:57 pm
Scre4m (Scream 4 French 4K disc).
Disc type: UHD
Disc ID: 9dde462ccef7615b1b3a171131eb28cfafdea6ed
Disc dump filename: MKB20_v82_SCRE4M_1C93.tgz
Drive: WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1rBlw4U ... share_link
Disc dump link: https://drive.google.com/file/d/1A6KkHc ... share_link
Other Info: I got the Disc ID using the 7-Zip method (Right click on 'Unit_Key_RO.inf' -> 7-Zip -> CRC SHA -> SHA1). The Disc dump is smaller than 1MB so I included the zipped MKB_RO.info file as well.
warhorus
Post by warhorus » Thu Jun 18, 2026 2:26 am
Mondo Macabro's 4K release of The Blood Rose (1970)
Disc type: UHD
Disc ID: 9c6d3ae7c99dbdf9cafad12a96e09a15ce629764
Disc dump filename: MKB20_v82_BLOOD_ROSE_B05A.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1VuRB8G ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1W35c1y ... drive_link
MrPenguin
Post by MrPenguin » Thu Jun 18, 2026 9:54 am
awshucks wrote: Wed Jun 17, 2026 10:57 pm Disc ID: 914a94732597a494e088cb31479d86dd86addf0d
Disc dump filename: MKB20_v76_Akira_D33B
You have provided two different MKB_RO.inf files, but no file called MKB20_v76_Akira_D33B.tgz. Does either MKB_RO.inf file even belong to your "Avira" disk?
awshucks
Post by awshucks » Thu Jun 18, 2026 3:25 pm
MrPenguin wrote: Thu Jun 18, 2026 9:54 am
Corrected it in my post, should have a link to the MKB20_v76_Akira_D33B.tgz now.
MrPenguin
Post by MrPenguin » Thu Jun 18, 2026 9:29 pm
awshucks wrote: Thu Jun 18, 2026 3:25 pm Corrected it in my post, should have a link to the MKB20_v76_Akira_D33B.tgz now.
Thanks. BTW which UHD disk was that other MKB_RO.inf file from please? It doesn't correspond to any existing entry in the public KEYDB.cfg file, so maybe we could add that one too?
ng1988
Post by ng1988 » Fri Jun 19, 2026 10:10 pm
I have another 4K UHD disc that is unreadable. MakerMKV displays the following information: "The volume key for the DVD/Blu-ray is unknown - the video cannot be decrypted. Opening the disc failed." Please decrypt it once, or do I need to add another file to the folder?
OS-Gerätename: E:
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.03
Serienummer: MOFP7J83721
Firmware-Datum: 2118-10-24 19:34
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 82
Firmware version: 1.03
Disk-Informationen
Label: UHD_RTSH
Zeitstempel: 2026-04-18 13:47:10
Schutz: AACS2.0/C v82
Datenkapazität: 60.31 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 2
Markierungen der Bus-Verschlüsselung: 80
https://drive.google.com/file/d/1H40Fd_ ... drive_link
MrPenguin
Post by MrPenguin » Sat Jun 20, 2026 10:02 am
ng1988 wrote: Fri Jun 19, 2026 10:10 pm I have another 4K UHD disc that is unreadable. MakerMKV displays the following information: "The volume key for the DVD/Blu-ray is unknown - the video cannot be decrypted. Opening the disc failed." Please decrypt it once, or do I need to add another file to the folder?
I believe this disk was already added to the public KEYDB.cfg file last week.
Iannautilus
Post by Iannautilus » Sat Jun 20, 2026 12:44 pm
Ghost in the Shell 30th anniversary edition UHD
Disc type: UHD
Disc ID: 077f0e487dc8d3e143dc06ce5b7b09421d41e614
Disc dump filename: MKB20_v82_Ghost_in_the_Shell_0D07
Drive: BD-RE BU40N
Drive firmware: 1.00
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.proton.me/urls/BZGP019DVM#u8iOfDLfW00a
Disc dump link: https://drive.proton.me/urls/VED0YN99RC#Cww0gtc82lQY
dcom101
Post by dcom101 » Sat Jun 20, 2026 2:06 pm
Fast_&_Furious_8
urrent profile: BD-ROM
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: SIK99HACH023
Highest AACS version: 61
Firmware version: 1.02
Disc Information
Label: Fast_&_Furious_8
Timestamp: 2017-07-20 15:43:23
Protection: AACS2.0/C v61
Data capacity: 52.31 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
https://gofile.io/d/iedyi5
https://gofile.io/d/WiMGeP
ng1988
Post by ng1988 » Sat Jun 20, 2026 10:04 pm
MrPenguin wrote: Sat Jun 20, 2026 10:02 am
Yes, that's right. I added the new file and it's working perfectly. Thank you.
chucky527c
Post by chucky527c » Sun Jun 21, 2026 5:40 am
50 First Dates 4K UHD (US)
Disc type: UHD
Disc ID: 939df1eca338e09144e18ca23e2884dc2b7d79cf
Disc dump filename: MKB20_v82_50_First_Dates_9DD3
Drive: LG WH16NS40
MKB_RO.inf link: https://drive.google.com/file/d/1MGF5WD ... p=drivesdk
Disc dump link: https://drive.google.com/file/d/1_ob_9o ... p=drivesdk
thenoim
Post by thenoim » Sun Jun 21, 2026 6:04 pm
Disc type: UHD
Disc ID: 0e5075b6f97e0093f8e764f2b573e6b6502e03ba
Disc dump filename: MKB20_v82_Angel's_Egg_9FEF.tgz
Drive: BW-16D1HT
Drive firmware: 2119-01-04 10:14
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://files.catbox.moe/vuawad.inf
Disc dump link: https://files.catbox.moe/ey7r02.tgz
HutchLee42
Post by HutchLee42 » Sun Jun 21, 2026 6:53 pm
Disc type: UHD
Disc ID: 0x15329D3AE7911C0C062F420262240D6F5263FE1A
Disc dump filename: MKB20_v82_Macabre_UHD_2A7B
Drive: BD-RW BDR-S12JX
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1Ov3eqN ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1KOan8q ... sp=sharing
mm8718
Post by mm8718 » Sun Jun 21, 2026 10:07 pm
EPiC: Elvis Presley in Concert (2025) UHD
Disc type:UHD
Disc ID:d66aae87ee51eec72cec9997a30662fd5b6ac227
Disc dump filename:MKB20_v82_UPHE_UPK1-1135760R0_8700
Drive:BD-RW BDR-S12U
Drive firmware:PIONEER BDR-212T
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: https://drive.google.com/file/d/1oianBT ... sp=sharing
Disc dump link:https://drive.google.com/file/d/10NjvPT ... sp=sharing
mm8718
Post by mm8718 » Sun Jun 21, 2026 10:13 pm
Mother's Pride (2026) UHD
Disc type:UHD
Disc ID:7cae5f3bea125dd90c264a527709afdea7453ff4
Disc dump filename:MKB20_v82_Mother's_Pride_9E40
MKB_RO.inf link: https://drive.google.com/file/d/18PvAA3 ... sp=sharing
Disc dump link:https://drive.google.com/file/d/1Cbr_0d ... sp=sharing
