New user trying to decrypt a number of 4K UHD blurays, all give "unknown volume key"
lonnym
Post by lonnym »
I have reported all of these to "svq@makemkv.com". However, it's suspicious that none of these worked. They're a cross-section of mainstream and more "boutique" titles across a variety of vendors:
  • 88 Films "Hell of the Living Dead" 4K UHD
    Scream Factory "John Carpenter's Vampires" 4K UHD
    Kino Lorber "Stephen King's Graveyard Shift" 4K UHD
    Criterion Collection "Godzilla vs. Biollante" 4K UHD
    Severin's "Rats Night of Terror" 4K UHD
    Vinegar Syndrome's "Brimstone & Treacle" 4K UHD
    Universal's "Nosferatu (2024)" 4K UHD
    Blue Underground's "Venom" 4K UHD
    Paramount's "Smile 2" 4K UHD
I believe I have the firmware flashed properly for my LG BP50NB40 (firmware is BP60NB10 1.00). Everything looks like it's working correctly, but I didn't expect to encounter "unknown volume key" for _every_ disc I tried.
lonnym
Re: New user trying to decrypt a number of 4K UHD blurays, all give "unknown volume key"
Post by lonnym »
Update: I finally found a UHD disc that worked. I was able to successfully rip Sony/Columbia Picture's "2012" UHD blu-ray. So I guess it must be pretty commonplace that movies' keys are not yet available. Hopefully in a few days the titles below will work as well?
MrPenguin
Post by MrPenguin »
lonnym wrote: Sun May 18, 2025 8:26 pm Update: I finally found a UHD disc that worked. I was able to successfully rip Sony/Columbia Picture's "2012" UHD blu-ray. So I guess it must be pretty commonplace that movies' keys are not yet available. Hopefully in a few days the titles below will work as well?
Yes, but all you need to do is email the TGZ dump file that MakeMKV creates to svq@makemkv.com and then wait for its key to be generated. While you're waiting, you can also try posting those same TGZ dump files here so that The Powers That KEYDB can examine them too.
You can download the KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV. This will allow MakeMKV to use your KEYDB.cfg file as a "fallback" database.
lonnym
Post by lonnym »
OK, here are the first 3 TGZ files...
MKB20_v77_Graveyard_Shift_C6A3.tgz
MKB20_v77_GODZILLA_VS_BIOLLANTE_AB01.tgz
MKB20_v76_Hell_Of_The_Living_Dead_EE81.tgz
lonnym
Post by lonnym »
...here are the next batch of 3...
MKB20_v77_RATS_NIGHT_OF_TERROR_UHD_0EE3.tgz
MKB20_v77_Nosferatu_EF45.tgz
MKB20_v77_John_Carpenter's_Vampires_95DB.tgz
lonnym
Post by lonnym »
...and here's the final batch of 3...
MKB20_v77_VS497UHD_882B.tgz
MKB20_v77_VENOM_D16B.tgz
MKB20_v77_Smile_2_129B.tgz
keydb_helper
Post by keydb_helper »
lonnym wrote: Sun May 18, 2025 4:26 pm I have reported all of these to "svq@makemkv.com". However, it's suspicious that none of these worked. They're a cross-section of mainstream and more "boutique" titles across a variety of vendors:
7 of your 9 titles are already supported by the public keydb. Until MakeMKV supports your discs natively you can backup your discs by following my instructions here or using SamuriHL's utility for Windows (Link)
Your two problematic titles are MKB20_v77_VENOM_D16B and MKB20_v77_RATS_NIGHT_OF_TERROR_UHD_0EE3. Could you please zip and attach the MKB_RO.inf files from these two discs to the forum? You'll find this file in the AACS folder on each disc and it is a distinct file for each title.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
MGoBlueNYC
Unknown Volume Key for new 4K UHDs
Post by MGoBlueNYC »
MKB20_v82_Scream_7_1185.tgz
dcxtrm
Post by dcxtrm »
Hello
Tring to rip Avatar Fire and Ash 4K version of the movie. Guess is to new.
dcxtrm wrote: Fri Jul 31, 2026 7:29 pm Hello
What does your MakeMKV log say?
If MakeMKV is having trouble downloading keys, that's one thing.
If the necessary key for your specific disc isn't available, that's a different thing. If that's the case, attach the .tgz dump file MakeMKV created to an email and send it to svq@makemkv.com. Read more in the UHD FAQ.
You can also try the Public KeyDB.
