Public KeyDB Disc Submissions
Post by SamuriHL » Fri Jun 12, 2026 3:27 pm
I have that title coming today. I'll take a look. That's....odd though. Never really seen that happen. It only does that if the keys don't match up.
99gagamel
Post by 99gagamel » Fri Jun 12, 2026 5:32 pm
keydb_helper wrote: Fri Jun 12, 2026 2:33 pm
99gagamel wrote: Fri Jun 12, 2026 2:18 pm Disc Type: UHD
Disc ID: ............................
Disc Dump Filename: MKB20_v82_ERASER_3BE8,tgz
KeyDB entry mismatch detected
KeyDB entry updated
KeyDB Status : not found for ........
KeyDB entry updated
The derived details all seem to be correct, so I'm not too sure what might've happened with this disc.
Sync your keydb and try again with the latest updates. I'd also recommend you follow up with SamuriHL just in case there is some quirky edge case here.
BTW Please don't post keys to the forum. The forum moderators and admins have been gracious enough to allow this thread and they really prefer it if keys and key-adjacent material aren't posted here.
Oh, sorry, all right. i have deleted this Since the disc is running now.
Many thanks for the help.
Best greets
JoshBurg17
Post by JoshBurg17 » Fri Jun 12, 2026 10:22 pm
KeyDB Submission for Perfect Blue 4k - first time I'm posting/submitting so I apologize in advance if anything is off. I believe I got it right though!! Thank you to everyone who contributes and all your hard work on this.
Disc type: BD-ROM UHD
Disc ID: 62150ac0c87f701f19c3cb328845bc5ceb65cd31
Disc dump filename: MKB20_v82_Perfect_Blue_400A.tgz
Drive: PIONEER BD-RW BDR-XD08U
Drive firmware: 1.04
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/13V-7br ... share_link
Disc dump link: https://drive.google.com/file/d/1-2sBRX ... share_link
keydb_helper
Post by keydb_helper » Sat Jun 13, 2026 4:54 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_IT_WAS_JUST_AN_ACCIDENT_0F2A
*MKB20_v82_Perfect_Blue_400A
*MKB20_v82_What_Dreams_May_Come_BBB2
JoshBurg17 wrote: Fri Jun 12, 2026 10:22 pm KeyDB Submission for Perfect Blue 4k - first time I'm posting/submitting so I apologize in advance if anything is off. I believe I got it right though!! Thank you to everyone who contributes and all your hard work on this.
Nice work on the submission, you got it right.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Tromta
Post by Tromta » Sat Jun 13, 2026 6:05 am
I hope I did this right. Thanks to everyone who keeps this going!
Disc type: UHD
Disc ID: 0x16B7A25D20F8E93BAC3FA576441F3BAC5D1C540A
Disc dump filename: MKB20_v70_4KDASD770_6FC4.zip
Drive: BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.google.com/file/d/1cd2LR5 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1jXCL8q ... sp=sharing
bdsucker
Post by bdsucker » Sat Jun 13, 2026 3:57 pm
Disc type: UHD
Disc ID: 0x4237CB8A19C6C844814D770E7E4B4038CE77EE49
Disc dump filename: MKB20_v82_WHO_AM_I_DISC_1_1376
Drive: BW-16D1HT
Drive firmware: 3.00
MKB_RO.inf link: https://www.mediafire.com/file/oc8n6m1s ... O.inf/file
Disc dump link: https://www.mediafire.com/file/56h9ah2n ... 6.tgz/file
Viros
Post by Viros » Sun Jun 14, 2026 8:39 pm
Disc type: UHD
Disc ID: Getting volume key is unknown error
Disc dump filename:MKB20_v82_Eraser_B064
Drive:WH16NS60
Drive firmware:1.00
LibreDrive status:Enabled
MKB_RO.inf link:https://drive.google.com/file/d/1dISGfG ... drive_link
Disc dump link:https://drive.google.com/file/d/173VGlJ ... drive_link
ehemmete
Post by ehemmete » Mon Jun 15, 2026 5:07 pm
Disc type: UHD
Disc dump filename:MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_D465.tgz
Drive:BD-RE WH16NS60
Drive firmware:1.02
MKB_RO.inf link:https://www.dropbox.com/scl/fi/nqop0u37 ... 7g8av&dl=0
Disc dump link:https://www.dropbox.com/scl/fi/s7k6vkoy ... 1409y&dl=0
chucky527c
Post by chucky527c » Mon Jun 15, 2026 6:50 pm
The Arrival 4K UHD (Lionsgate Limited)
Disc type: UHD
Disc ID: 3c2f3d9ffa3445f0ef584ca613401b11b1acb923
Disc dump filename: MKB20_v82_The_Arrival_ED84.tgz
Drive: LG WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: N/A
Disc dump link: https://drive.google.com/file/d/1QKuo8w ... p=drivesdk
caseablee
Post by caseablee » Mon Jun 15, 2026 7:55 pm
keydb_helper wrote: Fri Jun 05, 2026 1:38 am
Stryker412 wrote: Fri Jun 05, 2026 1:23 am Dump for Hoppers
Disc Information
Label: HOPPERS
Hey Stryker412, your disc was added to the public keydb on May 25. Please read the first post of this thread for info on how to configure MakeMKV to utilise the public keydb and the actual submission template.
FWIW, my 1B1A version of Hoppers is also not able to be decrypted. I updated my KEYDB.cfg file right before this post with no luck. On MacOS with Pioneer drive.
MrPenguin
Post by MrPenguin » Mon Jun 15, 2026 8:01 pm
caseablee wrote: Mon Jun 15, 2026 7:55 pm FWIW, my 1B1A version of Hoppers is also not able to be decrypted. I updated my KEYDB.cfg file right before this post with no luck. On MacOS with Pioneer drive.
I'm sure that KEYDB.cfg already has the 1B1A variant of "Hoppers". Have you installed the latest KEYDB.cfg file into the same directory where MakeMKV writes its TGZ dump files? And are you also sure that LibreDrive has managed to disable bus encryption? Either of these could prevent MakeMKV from decrypting your disk.
caseablee
Post by caseablee » Mon Jun 15, 2026 8:22 pm
MrPenguin wrote: Mon Jun 15, 2026 8:01 pm
I'm not sure what changed, but after a restart everything is working fine.
I do have the latest KEYDB.cfg file and am on the latest version of MakeMKV. I appreciate your help.
ehemmete
Post by ehemmete » Tue Jun 16, 2026 7:55 pm
ehemmete wrote: Mon Jun 15, 2026 5:07 pm Disc type: UHD
Drive firmware:1.02
This now works with the keydb.cfg released 6/16/2026. I had the one from 6/15/2026.
kario
Post by kario » Wed Jun 17, 2026 8:11 pm
Disc type: UHD
Disc ID: 1784c468bdac165e0e7eedbd88de391012649175
Disc dump filename: MKB20_v77_JU-ON-_THE_GRUDGE_-_4K_UHD_B4C7
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/0ASA7GRQFC#PQN3loNWRaPj
Disc dump link: https://drive.proton.me/urls/HE96D8C9RR#WIiB2V68GdE9
Disc type: UHD
Disc ID: abb6a84f7fb70e6409d96954f025c7887a209665
Disc dump filename: MKB20_v76_THE_WOLF_OF_WALL_STREET_-_4K_UHD_666D
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/6VHP28ARRC#5LfYH1FlLH5O
Disc dump link: https://drive.proton.me/urls/CZACP92SFG#jCvbUsuCvibh
Disc type: UHD
Disc ID: 0bf641eeae8d03dc710cf5141bf136bf2bef05c2
Disc dump filename: MKB20_v77_WATERWORLD_-_4K_UHD_32E1
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/5NAD0VCHC4#cej3D3yQILg2
Disc dump link: https://drive.proton.me/urls/R9AW77AECR#RKR1ojOB21rY
awshucks
Post by awshucks » Wed Jun 17, 2026 10:57 pm
Disc type: UHD
Disc ID: 914a94732597a494e088cb31479d86dd86addf0d
Disc dump filename: MKB20_v76_Akira_D33B
Drive: BD-RE WH16NS60
MKB_RO.inf: https://drive.proton.me/urls/8BDJYKX92C#Jv2G3F35pTfm
Disc dump link: https://drive.proton.me/urls/TZMX7KDKHG#RsJTXC13MnnS
