Public KeyDB Disc Submissions
keydb_helper
#2581 Post by keydb_helper » Thu Jun 11, 2026 2:47 am
FootFungus07 wrote: Thu Jun 11, 2026 12:26 am Dump File: MKB20_v82_Slither_14F4.tgz
Thanks for the new disc dump, your disc has been added to the public keydb.
Don't stress about including all of those fields like "Timestamp", "Disc capacity" from MakeMKV. I left them out of the actual submission template intentionally.
Ideally your submission would've looked like this:
Disc type: UHD
Disc ID: 0x18199A7D43F3C72AB8D254305538047ECBE1F160
Disc dump filename: MKB20_v82_Slither_14F4
Drive: BP60NB10
Drive firmware: 1.02MK
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): <Link Redacted>
Disc dump link: <Link Redacted>
eNoize wrote: Thu Jun 11, 2026 12:40 am Yeah, I've done that too, but even after downloading the latest, it still can't decrypt.
As Mr Penguin noted, your disc was added to the public keydb on May 12:
0x198969B55E504A0F657EF574A80599809F9E32ED = Terror Train | D | 2026-03-24 | M | 0xA0C0<Redacted> | I | 0xA557<Redacted> | V | 0xA280<Redacted> | U | 1-0x6A08<Redacted> ; MKBv82/BEE - VolumeSize: 77390086144 (UHD)
If you still can't decrypt the disc it means you've placed the keydb.cfg file in the wrong folder. After you download the zip file and extract the keydb.cfg file, you'll need to place it in the same folder MakeMKV uses to store newly created disc dump files. So if MKB20_v82_Terror_Train_407E.tgz was created in "F:/Bluray/" then you'll need to place the extracted keydb.cfg file in that folder.
eNoize wrote: Thu Jun 11, 2026 12:40 am I'm thinking it might be something I'm not aware of with my provider blocking it.
One of the benefits of the public keydb is that your internet provider can't really block MakeMKV from accessing a file you have already downloaded to your computer...
kario
#2582 Post by kario » Thu Jun 11, 2026 6:42 pm
Disc type: UHD
Disc ID: 12aa2f504dccccfd9a23bed123e962e292e77260
Disc dump filename: MKB20_v77_Child's_Play_2_0751
Drive: BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/P4M89BW9GR#3cHfwTZjFNm5
Disc dump link: https://drive.proton.me/urls/ERD5YJP16R#u2MBzgxGO1fQ
Disc type: UHD
Disc ID: 1053a94226e6e9b46ce21221e8f771807a310f7e
Disc dump filename: MKB20_v77_Child's_Play_3_7DC3
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/DN8XA7AV68#JTfrKSnFb9Ze
Disc dump link: https://drive.proton.me/urls/9W5NK9726M#lVceMEWUqBLa
Disc type: UHD
Disc ID: 6088d0e72415e55b16d167e2bdb162f77de43b4d
Disc dump filename: MKB20_v76_Full_Metal_Jacket_9A21
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/CFCRTVRVWW#NnRXvGfhxze1
Disc dump link: https://drive.proton.me/urls/7G4T8QBJMC#9MMjh8XzjYIM
Disc type: UHD
Disc ID: 5527404900be3bcc168310834aac064707312e01
Disc dump filename: MKB20_v61_Inception_E9D5
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/G29HB4BEHG#B4Ib2OGntMs5
Disc dump link: https://drive.proton.me/urls/WEXBCHFPFG#51J0YOiH8Vld
Disc type: UHD
Disc ID: ab9bcd39d016787aa1d035bfa5e6b4d332ef3343
Disc dump filename: MKB20_v77_RINGU_-_4K_UHD_E847
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/YR3X8AVTR0#Coi3JmhNayfh
Disc dump link: https://drive.proton.me/urls/WC04AN1DCW#EziJsMGuC2ew
keydb_helper
#2583 Post by keydb_helper » Fri Jun 12, 2026 12:26 pm
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_Child's_Play_2_0751
*MKB20_v77_Child's_Play_3_7DC3
*MKB20_v77_RINGU_-_4K_UHD_E847
*MKB20_v82_EPiC-_Elvis_Presley_in_Concert_5E14
*MKB20_v82_They_Will_Kill_You_1D64
*MKB20_v82_UPHE_UPK1-1135760R0_B288
99gagamel
#2584 Post by 99gagamel » Fri Jun 12, 2026 2:18 pm
Disc Type: UHD
Disc ID: 0x15026F090E35FEBA14A7EC75FF708FCE8C1D02AF
Disc Dump Filename: MKB20_v82_ERASER_3BE8,tgz
Drive: BD-RE BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1bLFkXt ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1dwNRLk ... sp=sharing
_________________________________________________________________
keydb_helper
#2585 Post by keydb_helper » Fri Jun 12, 2026 2:33 pm
99gagamel wrote: Fri Jun 12, 2026 2:18 pm Disc Type: UHD
KeyDB entry mismatch detected
KeyDB entry updated
KeyDB Status : not found for 15026F090E35FEBA14A7EC75FF708FCE8C1D02AF
KeyDB entry updated
The derived details all seem to be correct, so I'm not too sure what might've happened with this disc.
Sync your keydb and try again with the latest updates. I'd also recommend you follow up with SamuriHL just in case there is some quirky edge case here.
BTW Please don't post keys to the forum. The forum moderators and admins have been gracious enough to allow this thread and they really prefer it if keys and key-adjacent material aren't posted here.
#2586 Post by SamuriHL » Fri Jun 12, 2026 3:27 pm
I have that title coming today. I'll take a look. That's....odd though. Never really seen that happen. It only does that if the keys don't match up.
99gagamel
#2587 Post by 99gagamel » Fri Jun 12, 2026 5:32 pm
keydb_helper wrote: Fri Jun 12, 2026 2:33 pm
Disc ID: ............................
KeyDB entry updated
KeyDB Status : not found for ........
KeyDB entry updated
Oh, sorry, all right. i have deleted this Since the disc is running now.
Many thanks for the help.
Best greets
JoshBurg17
#2588 Post by JoshBurg17 » Fri Jun 12, 2026 10:22 pm
KeyDB Submission for Perfect Blue 4k - first time I'm posting/submitting so I apologize in advance if anything is off. I believe I got it right though!! Thank you to everyone who contributes and all your hard work on this.
Disc type: BD-ROM UHD
Disc ID: 62150ac0c87f701f19c3cb328845bc5ceb65cd31
Disc dump filename: MKB20_v82_Perfect_Blue_400A.tgz
Drive: PIONEER BD-RW BDR-XD08U
Drive firmware: 1.04
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/13V-7br ... share_link
Disc dump link: https://drive.google.com/file/d/1-2sBRX ... share_link
keydb_helper
#2589 Post by keydb_helper » Sat Jun 13, 2026 4:54 am
*MKB20_v82_IT_WAS_JUST_AN_ACCIDENT_0F2A
*MKB20_v82_Perfect_Blue_400A
*MKB20_v82_What_Dreams_May_Come_BBB2
JoshBurg17 wrote: Fri Jun 12, 2026 10:22 pm KeyDB Submission for Perfect Blue 4k - first time I'm posting/submitting so I apologize in advance if anything is off. I believe I got it right though!! Thank you to everyone who contributes and all your hard work on this.
Nice work on the submission, you got it right.
Tromta
#2590 Post by Tromta » Sat Jun 13, 2026 6:05 am
I hope I did this right. Thanks to everyone who keeps this going!
Disc type: UHD
Disc ID: 0x16B7A25D20F8E93BAC3FA576441F3BAC5D1C540A
Disc dump filename: MKB20_v70_4KDASD770_6FC4.zip
Drive: BU40N
MKB_RO.inf: https://drive.google.com/file/d/1cd2LR5 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1jXCL8q ... sp=sharing
bdsucker
#2591 Post by bdsucker » Sat Jun 13, 2026 3:57 pm
Disc type: UHD
Disc ID: 0x4237CB8A19C6C844814D770E7E4B4038CE77EE49
Disc dump filename: MKB20_v82_WHO_AM_I_DISC_1_1376
Drive: BW-16D1HT
Drive firmware: 3.00
MKB_RO.inf link: https://www.mediafire.com/file/oc8n6m1s ... O.inf/file
Disc dump link: https://www.mediafire.com/file/56h9ah2n ... 6.tgz/file
Viros
#2592 Post by Viros » Sun Jun 14, 2026 8:39 pm
Disc type: UHD
Disc ID: Getting volume key is unknown error
Disc dump filename:MKB20_v82_Eraser_B064
Drive:WH16NS60
Drive firmware:1.00
LibreDrive status:Enabled
MKB_RO.inf link:https://drive.google.com/file/d/1dISGfG ... drive_link
Disc dump link:https://drive.google.com/file/d/173VGlJ ... drive_link
ehemmete
#2593 Post by ehemmete » Mon Jun 15, 2026 5:07 pm
Disc type: UHD
Disc dump filename:MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_D465.tgz
Drive:BD-RE WH16NS60
Drive firmware:1.02
MKB_RO.inf link:https://www.dropbox.com/scl/fi/nqop0u37 ... 7g8av&dl=0
Disc dump link:https://www.dropbox.com/scl/fi/s7k6vkoy ... 1409y&dl=0
chucky527c
#2594 Post by chucky527c » Mon Jun 15, 2026 6:50 pm
The Arrival 4K UHD (Lionsgate Limited)
Disc type: UHD
Disc ID: 3c2f3d9ffa3445f0ef584ca613401b11b1acb923
Disc dump filename: MKB20_v82_The_Arrival_ED84.tgz
Drive: LG WH16NS60
MKB_RO.inf link: N/A
Disc dump link: https://drive.google.com/file/d/1QKuo8w ... p=drivesdk
caseablee
#2595 Post by caseablee » Mon Jun 15, 2026 7:55 pm
keydb_helper wrote: Fri Jun 05, 2026 1:38 am
Stryker412 wrote: Fri Jun 05, 2026 1:23 am Dump for Hoppers
Disc Information
Label: HOPPERS
Hey Stryker412, your disc was added to the public keydb on May 25. Please read the first post of this thread for info on how to configure MakeMKV to utilise the public keydb and the actual submission template.
FWIW, my 1B1A version of Hoppers is also not able to be decrypted. I updated my KEYDB.cfg file right before this post with no luck. On MacOS with Pioneer drive.
