Files integrity
mkv-user1
Files integrity
#1 Post by mkv-user1 » Thu May 28, 2026 3:02 am
has anyone noticed that hash checksum for both tar.gz files is different from checksums provided here:
https://www.makemkv.com/download/makemkv-sha-1.18.3.txt
installation files for windows and macos are OK
makemkv-bin-1.18.3.tar.gz - 3883ad40907f737d4dad5a846ec93d2327458da0f48b1090578d0f3afa34ee7e
makemkv-oss-1.18.3.tar.gz - 62b08895d3f439a7553b4874df5fa6e36b484c7d2c22404b6c3f2cae816c4383
is it just mistake and admin forget to update makemkv-sha-1.18.3.txt file or both files are compromised?
tomty89
Re: Files integrity
#2 Post by tomty89 » Thu May 28, 2026 8:23 pm
No, unless the files were for reasons changed very recently without getting a version bump. The checksums in the txt are the same one in https://aur.archlinux.org/cgit/aur.git/ ... 6d7b178478. It has been building fine. Last time I built it was like a couple days ago.
Maybe.
Sayaka
Re: Files integrity
#3 Post by Sayaka » Fri May 29, 2026 10:37 am
The checksums for v1.17.6 and v1.17.7 also appear to differ for Linux (once again, the checksums for Windows and macOS appear to match). I haven't tested the other versions yet.
MrPenguin
Re: Files integrity
#4 Post by MrPenguin » Fri May 29, 2026 2:10 pm
Sayaka wrote: Fri May 29, 2026 10:37 am
Both .tar.gz files for Linux are correct, but mis-packaged. Do the following:
$ wget https://www.makemkv.com/download/makemkv-bin-1.18.3.tar.gz
$ gunzip makemkv-bin-1.18.3.tar.gz
$ mv makemkv-bin-1.18.3.tar makemkv-bin-1.18.3.tgz
$ sha256sum makemkv-bin-1.18.3.tgz
and you should get:
c1ee720ae91b276a7c89be861146c5b934631831e8d6c8f453406435724e92bd
And similarly for makemkv-oss-1.18.3.tar.gz, of course.
tomty89
Re: Files integrity
#5 Post by tomty89 » Fri May 29, 2026 5:04 pm
It's still somewhat strange and suspicious (even though I know this "double-gzip'ing" issue has happend before), especially when it didn't happen when the version was first released but after such a long time.
mkv-user1
Re: Files integrity
#6 Post by mkv-user1 » Sat May 30, 2026 8:06 am
I agree with tomty89, are we really suppose to install on our desktops software with incorrect checksum? maybe it's mis-packge issue, maybe it's malware, who knows.
The whole point of file checksum is trust - if it match, it means that we have original installation file, if not - who knows what happen.
i mean, it's not uncommon, just recently notepad++, very trustworthy software was compromised, same thing happened to handbreak years ago.
we have forum admins, can they correct either linux packges or hash file on makemkv website?
Sayaka
Re: Files integrity
#7 Post by Sayaka » Sun Jun 07, 2026 9:45 pm
MrPenguin wrote: Fri May 29, 2026 2:10 pm Both .tar.gz files for Linux are correct, but mis-packaged. Do the following:
and you should get:
Apologies for being late, but thank you. I can confirm that the same is true for 1.17.6 and 1.17.7 as well.
Unless the .txt hash files themselves were somehow also tampered with (and wouldn't that be unlikely, with the PGP signature being correct ?), the odds that a malware-infected MakeMKV could somehow generate a valid SHA256 hash on an archive file, even a mispackaged one, are basically non-existent. See here : https://condensation.io/notes/hash-collisions/
tomty89
Re: Files integrity
#8 Post by tomty89 » Sun Jun 07, 2026 9:59 pm
The problem with the situation here is not so much that MakeMKV might be tampered. Rather it is that the we have no idea what the "extra layer" might contain, e.g. something that trigger / leverage a loophole or so in gzip or tar. (Of course it is not very likely for it to be malicious or problematic, but it's not like we haven't seen something like a malicious gif either.)
Sayaka
Re: Files integrity
#9 Post by Sayaka » Sun Jun 07, 2026 10:31 pm
That's a good point.
Possible "ultimate paranoia" (I too am cautious when it comes to security) temporary workaround :) :
1) Boot a Linux OS into RAM with a USB drive.
2) Disable kernel access to all writable storage media except for USB drives. Now the live OS shouldn't have access to your SSDs and HDDs anymore. Or if you want to be 100% sure, there shouldn't be anything preventing you from physically removing your SSDs and HDDs before booting the live OS.
3) From the live OS, download MakeMKV for Linux. Unpack the archives with gunzip.
4) Copy these files onto another USB drive (it could even be the same USB drive, if you have a partition for them).
5) Verify the checksums of the "tar" files on the USB drive.
6) Because the checksums will likely be correct, you will know that MakeMKV wasn't tampered with.
7) Shut down your computer.
8 Reboot into your normal Linux OS. (Don't forget to put your SSDs and HDDs back where they belong beforehand if you removed them.)
9) Verify the checksums of the MakeMKV "tar" files on the USB drive again, just to make sure there wasn't some crazy tar/gzip malware that tampered with them when you gave your computer the order to shut down.
10) Finish fully unpacking the archives.
11) Install MakeMKV.
Inconvenient, but that would work, yes?
EDIT : Huh. I tried gunzipping makemkv-bin-1.17.6.tar.gz, and then gzipping the resulting "tar" file back into a "tar.gz" file. The two "tar.gz" files actually differ slightly, and the one from the MakeMKV website is bigger. Is that even more suspicious, or should I research gzip behavior further ? :?:
16442496
Re: Files integrity
#10 Post by 16442496 » Fri Jun 12, 2026 4:00 am
I get these:
sha256sum makemkv-bin-1.18.3.tar.gz && sha256sum makemkv-oss-1.18.3.tar.gz
c1ee720ae91b276a7c89be861146c5b934631831e8d6c8f453406435724e92bd makemkv-bin-1.18.3.tar.gz
bc8bb084ae3aabcd503d5bb93efc273e046e4fd4663d39a9836ce0c047fee823 makemkv-oss-1.18.3.tar.gz
sha256sum makemkv-bin-1.17.7.tar.gz && sha256sum makemkv-oss-1.17.7.tar.gz
8c5bc831bc952b1f873cc8450c64e392db0b2479b626d180f0ffc965668951d0 makemkv-bin-1.17.7.tar.gz
762e552d46f9ec75a7c62dcb7d97c0fd9e6a15120d0ef6f5a080cee291d3a0ef makemkv-oss-1.17.7.tar.gz
sha256sum makemkv-bin-1.17.6.tar.gz && sha256sum makemkv-oss-1.17.6.tar.gz
287646005029f771d366cf0e4fbeb17fcf1033452d955547deae7b0999b4ed1b makemkv-bin-1.17.6.tar.gz
d9db4d772bf4f9061642b7eb22ee5140a48de2c71258ab8b14d949657a710d43 makemkv-oss-1.17.6.tar.gz
Debian
MakeMKV 1.17.6 (Registered)
DVD to MKV only.
