Public KeyDB Disc Submissions
aerandir92
Post by aerandir92 »
Avatar Fire and Ash
MKB20_v82_Avatar-_Fire_and_Ash_DB6C: https://drive.google.com/file/d/1QA9QWc ... sp=sharing
Edit: I see now that there is a more detailed template to fill out. I can get around to that tomorrow, my drive is currently busy ripping another disc..
aerandir92
A Knight of the Seven Kingdoms
MKB20_v82_A_Knight_of_the_Seven_Kingdoms_-_Season_1_Disc_1_DF72: https://drive.google.com/file/d/1-bNjRh ... sp=sharing
MKB20_v82_A_Knight_of_the_Seven_Kingdoms_-_Season_1_Disc_2_F76E: https://drive.google.com/file/d/1hFpeqo ... sp=sharing
kario
Post by kario »
Disc type: UHD
Disc ID: cc5595adca37607c776940dd8d6bfc22a0004f39
Disc dump filename: MKB20_v65_Shutter_Island_949D
Drive: BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/27GZ6DC75C#gsZxz6xnIG5T
Disc dump link: https://drive.proton.me/urls/MGJ1YA02ZC#siGs6wk1kOWD
Disc type: UHD
Disc ID: f81fc3b02a9a3129019e4c39b8594fe3c1bd6ce2
Disc dump filename: MKB20_v68_Whiplash_4A99
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/ESBPV7514C#qPs79kk3HnhJ
Disc dump link: https://drive.proton.me/urls/0MRQAQHKK8#fPgR9mEmEj6s
sergio31
Post by sergio31 »
aerandir92 wrote: Tue Jun 09, 2026 3:24 pm Avatar Fire and Ash
"Happy" to see that keydb.cfg is unable to decrypt MKB20_v82_Avatar-_Fire_and_Ash_DB6C.
I already sent .tgz file by mail 5 days ago.
Let's wait volume key.
megamo
Post by megamo »
Disc type: UHD
Disc ID: 568C1856A6C217F081C922CC6D4817844D8DF7FB
Disc dump filename: MKB20_v82_RAD_UHD_1916.tgz
Drive: WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.google.com/file/d/1zRBUJ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1C1don ... p=sharing
MrPenguin
Post by MrPenguin »
cladefe60 wrote: Tue Jun 09, 2026 1:47 pm Ciao e grazie per la risposta..ok vedo se riesco a rendere pubblico il file su google drive ma poi basta questo o per forza devo inserire id disco..(dove lo Prendo i dati da make mkv o altro?) e poi leggo mb.ro che cosa e' e dove lo prendo?come invio anche..devo mettere tutto?
Fai clic con il pulsante destro del mouse sul file in Google Drive, seleziona "Condividi" e poi modifica l'impostazione "Accesso generale" da "Limitato" a "Chiunque abbia il link".
Il file MKB_RO.inf si trova nella cartella AACS/ del disco. Questo file dovrebbe avere una dimensione di diversi MB e probabilmente dovresti caricarlo anche su Google Drive. E ovviamente, fornisci anche un link pubblico.
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v61_The_Bourne_Identity_354B
*MKB20_v68_Whiplash_4A99
megamo wrote: Tue Jun 09, 2026 7:40 pm Disc type: UHD
Full support for this variant of Rad was added to the public keydb on June 4. Please try to use the latest keydb before posting to this thread.
MKB20_v82_Avatar-_Fire_and_Ash_DB6C: ...
Please don't worry about amending your post or resubmitting this variant. It was added to the public keydb on June 1. Follow the steps linked in the opening post of this thread to configure MakeMKV to utilise the public keydb.
sergio31 wrote: Tue Jun 09, 2026 5:15 pm "Happy" to see that keydb.cfg is unable to decrypt MKB20_v82_Avatar-_Fire_and_Ash_DB6C.
As I told you last week, the public keydb has supported this disc variant since June 1. You haven't configured MakeMKV to utilise the latest public keydb, so you are relying on MakeMKV's native title support.
cladefe60
Post by cladefe60 »
FILM : SCARYMOVIE 7 UHD 4K
Informazioni unità
Nome dispositivo SO: D:
Produttore: HL-DT-ST
Prodotto: BD-RE BU40N
Revisione: 1.03
Numero seriale: MOAP7LG1900
Data firmware: 2118-10-24 19:34
Flag criptazione bus: 17
Versione più recente AACS: 82
lINK tgz.:https://drive.google.com/file/d/1cie8ze ... drive_link
LINK mkb_ro: https://drive.google.com/file/d/1rMfHca ... drive_link
Spero questa volta di aver fatto tutto ok.
Grazie
keydb_helper
cladefe60 wrote: Wed Jun 10, 2026 7:19 am FILM : SCARYMOVIE 7 UHD 4K
Your disc variant was added to the public keydb on June 8.
keydb_helper
*MKB20_v82_LABYRINTH_2798
*MKB20_v82_THE_DARK_CRYSTAL_03DA
aerandir92
keydb_helper wrote: Tue Jun 09, 2026 11:25 pm
Oh I see, thanks! I did a sync before attempting to rip, but I guess I need to re-check my setup. Or maybe I forgot to restart MakeMKV after the sync
FootFungus07
Post by FootFungus07 »
Slither - Scream Factory 4K UHD TGZ Keyfile
Label: Slither
Dump File: MKB20_v82_Slither_14F4.tgz
Timestamp: 2026-03-30 18:10:15
Protection: AACS2.0/C v82
Data capacity: 67.78 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Did you sync the public keyDB within the last 15 minutes? Yes
Google Drive Link: https://drive.google.com/file/d/1JYDzqx ... drive_link
eNoize
Post by eNoize »
MrPenguin wrote: Thu May 28, 2026 8:37 pm
eNoize wrote: Thu May 28, 2026 8:17 pm Weird. I still can't rip the disc. I keep receiving the same message that the key is unknown and can't decrypt.
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKVs data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
The KEYDB file is an optional database that MkeMKV can use, if available. And if you haven't already done so, email that TGZ dump file to svq@makemkv.com so that your key can be added to MakeMKV's own "hashed keys" database as well.
Yeah, I've done that too, but even after downloading the latest, it still can't decrypt. I'm thinking it might be something I'm not aware of with my provider blocking it.
keydb_helper
FootFungus07 wrote: Thu Jun 11, 2026 12:26 am Dump File: MKB20_v82_Slither_14F4.tgz
Thanks for the new disc dump, your disc has been added to the public keydb.
Don't stress about including all of those fields like "Timestamp", "Disc capacity" from MakeMKV. I left them out of the actual submission template intentionally.
Ideally your submission would've looked like this:
Disc type: UHD
Disc ID: 0x18199A7D43F3C72AB8D254305538047ECBE1F160
Disc dump filename: MKB20_v82_Slither_14F4
Drive: BP60NB10
Drive firmware: 1.02MK
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): <Link Redacted>
Disc dump link: <Link Redacted>
eNoize wrote: Thu Jun 11, 2026 12:40 am Yeah, I've done that too, but even after downloading the latest, it still can't decrypt.
As Mr Penguin noted, your disc was added to the public keydb on May 12:
0x198969B55E504A0F657EF574A80599809F9E32ED = Terror Train | D | 2026-03-24 | M | 0xA0C0<Redacted> | I | 0xA557<Redacted> | V | 0xA280<Redacted> | U | 1-0x6A08<Redacted> ; MKBv82/BEE - VolumeSize: 77390086144 (UHD)
If you still can't decrypt the disc it means you've placed the keydb.cfg file in the wrong folder. After you download the zip file and extract the keydb.cfg file, you'll need to place it in the same folder MakeMKV uses to store newly created disc dump files. So if MKB20_v82_Terror_Train_407E.tgz was created in "F:/Bluray/" then you'll need to place the extracted keydb.cfg file in that folder.
eNoize wrote: Thu Jun 11, 2026 12:40 am I'm thinking it might be something I'm not aware of with my provider blocking it.
One of the benefits of the public keydb is that your internet provider can't really block MakeMKV from accessing a file you have already downloaded to your computer...
