Public KeyDB Disc Submissions
megamo
Disc type: UHD
Disc ID: 568C1856A6C217F081C922CC6D4817844D8DF7FB
Disc dump filename: MKB20_v82_RAD_UHD_1916.tgz
Drive: WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1zRBUJ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1C1don ... p=sharing
Drive: WH16NS60
MrPenguin
Fai clic con il pulsante destro del mouse sul file in Google Drive, seleziona "Condividi" e poi modifica l'impostazione "Accesso generale" da "Limitato" a "Chiunque abbia il link".cladefe60 wrote: Tue Jun 09, 2026 1:47 pm Ciao e grazie per la risposta..ok vedo se riesco a rendere pubblico il file su google drive ma poi basta questo o per forza devo inserire id disco..(dove lo Prendo i dati da make mkv o altro?) e poi leggo mb.ro che cosa e' e dove lo prendo?come invio anche..devo mettere tutto?
Il file MKB_RO.inf si trova nella cartella AACS/ del disco. Questo file dovrebbe avere una dimensione di diversi MB e probabilmente dovresti caricarlo anche su Google Drive. E ovviamente, fornisci anche un link pubblico.
xia6909
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v61_The_Bourne_Identity_354B
MKB20_v65_Shutter_Island_949D
*MKB20_v68_Whiplash_4A99
MKB20_v82_A_Knight_of_the_Seven_Kingdoms_-_Season_1_Disc_1_DF72
MKB20_v82_A_Knight_of_the_Seven_Kingdoms_-_Season_1_Disc_2_F76E
Full support for this variant of Rad was added to the public keydb on June 4. Please try to use the latest keydb before posting to this thread.megamo wrote: Tue Jun 09, 2026 7:40 pm Disc type: UHD
Please don't worry about amending your post or resubmitting this variant. It was added to the public keydb on June 1. Follow the steps linked in the opening post of this thread to configure MakeMKV to utilise the public keydb.aerandir92 wrote: Tue Jun 09, 2026 3:24 pm Avatar Fire and Ash
MKB20_v82_Avatar-_Fire_and_Ash_DB6C: ...
Edit: I see now that there is a more detailed template to fill out. I can get around to that tomorrow, my drive is currently busy ripping another disc..
As I told you last week, the public keydb has supported this disc variant since June 1. You haven't configured MakeMKV to utilise the latest public keydb, so you are relying on MakeMKV's native title support.sergio31 wrote: Tue Jun 09, 2026 5:15 pm "Happy" to see that keydb.cfg is unable to decrypt MKB20_v82_Avatar-_Fire_and_Ash_DB6C.
I already sent .tgz file by mail 5 days ago.
Let's wait volume key.
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
cladefe60
FILM : SCARYMOVIE 7 UHD 4K
Informazioni unità
Nome dispositivo SO: D:
Produttore: HL-DT-ST
Prodotto: BD-RE BU40N
Revisione: 1.03
Numero seriale: MOAP7LG1900
Data firmware: 2118-10-24 19:34
Flag criptazione bus: 17
Versione più recente AACS: 82
lINK tgz.:https://drive.google.com/file/d/1cie8ze ... drive_link
LINK mkb_ro: https://drive.google.com/file/d/1rMfHca ... drive_link
Spero questa volta di aver fatto tutto ok.
Grazie
Informazioni unità
Revisione: 1.03
Grazie
keydb_helper
Your disc variant was added to the public keydb on June 8.
keydb_helper
*MKB20_v82_LABYRINTH_2798
*MKB20_v82_THE_DARK_CRYSTAL_03DA
aerandir92
Oh I see, thanks! I did a sync before attempting to rip, but I guess I need to re-check my setup. Or maybe I forgot to restart MakeMKV after the synckeydb_helper wrote: Tue Jun 09, 2026 11:25 pmPlease don't worry about amending your post or resubmitting this variant. It was added to the public keydb on June 1. Follow the steps linked in the opening post of this thread to configure MakeMKV to utilise the public keydb.aerandir92 wrote: Tue Jun 09, 2026 3:24 pm Avatar Fire and Ash
FootFungus07
Slither - Scream Factory 4K UHD TGZ Keyfile
Label: Slither
Dump File: MKB20_v82_Slither_14F4.tgz
Timestamp: 2026-03-30 18:10:15
Protection: AACS2.0/C v82
Data capacity: 67.78 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Did you sync the public keyDB within the last 15 minutes? Yes
Google Drive Link: https://drive.google.com/file/d/1JYDzqx ... drive_link
Label: Slither
Number of layers: 3
Revision: 1.02
eNoize
Yeah, I've done that too, but even after downloading the latest, it still can't decrypt. I'm thinking it might be something I'm not aware of with my provider blocking it.MrPenguin wrote: Thu May 28, 2026 8:37 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKVs data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?eNoize wrote: Thu May 28, 2026 8:17 pm Weird. I still can't rip the disc. I keep receiving the same message that the key is unknown and can't decrypt.
The KEYDB file is an optional database that MkeMKV can use, if available. And if you haven't already done so, email that TGZ dump file to svq@makemkv.com so that your key can be added to MakeMKV's own "hashed keys" database as well.
keydb_helper
Thanks for the new disc dump, your disc has been added to the public keydb.
Don't stress about including all of those fields like "Timestamp", "Disc capacity" from MakeMKV. I left them out of the actual submission template intentionally.
Ideally your submission would've looked like this:
Disc type: UHD
Disc ID: 0x18199A7D43F3C72AB8D254305538047ECBE1F160
Disc dump filename: MKB20_v82_Slither_14F4
Drive: BP60NB10
Drive firmware: 1.02MK
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): <Link Redacted>
Disc dump link: <Link Redacted>
As Mr Penguin noted, your disc was added to the public keydb on May 12:eNoize wrote: Thu Jun 11, 2026 12:40 am Yeah, I've done that too, but even after downloading the latest, it still can't decrypt.
0x198969B55E504A0F657EF574A80599809F9E32ED = Terror Train | D | 2026-03-24 | M | 0xA0C0<Redacted> | I | 0xA557<Redacted> | V | 0xA280<Redacted> | U | 1-0x6A08<Redacted> ; MKBv82/BEE - VolumeSize: 77390086144 (UHD)
One of the benefits of the public keydb is that your internet provider can't really block MakeMKV from accessing a file you have already downloaded to your computer...eNoize wrote: Thu Jun 11, 2026 12:40 am I'm thinking it might be something I'm not aware of with my provider blocking it.
kario
Disc type: UHD
Disc ID: 12aa2f504dccccfd9a23bed123e962e292e77260
Disc dump filename: MKB20_v77_Child's_Play_2_0751
Drive: BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/P4M89BW9GR#3cHfwTZjFNm5
Disc dump link: https://drive.proton.me/urls/ERD5YJP16R#u2MBzgxGO1fQ
Disc type: UHD
Disc ID: 1053a94226e6e9b46ce21221e8f771807a310f7e
Disc dump filename: MKB20_v77_Child's_Play_3_7DC3
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/DN8XA7AV68#JTfrKSnFb9Ze
Disc dump link: https://drive.proton.me/urls/9W5NK9726M#lVceMEWUqBLa
Disc type: UHD
Disc ID: 6088d0e72415e55b16d167e2bdb162f77de43b4d
Disc dump filename: MKB20_v76_Full_Metal_Jacket_9A21
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/CFCRTVRVWW#NnRXvGfhxze1
Disc dump link: https://drive.proton.me/urls/7G4T8QBJMC#9MMjh8XzjYIM
Disc type: UHD
Disc ID: 5527404900be3bcc168310834aac064707312e01
Disc dump filename: MKB20_v61_Inception_E9D5
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/G29HB4BEHG#B4Ib2OGntMs5
Disc dump link: https://drive.proton.me/urls/WEXBCHFPFG#51J0YOiH8Vld
Disc type: UHD
Disc ID: ab9bcd39d016787aa1d035bfa5e6b4d332ef3343
Disc dump filename: MKB20_v77_RINGU_-_4K_UHD_E847
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/YR3X8AVTR0#Coi3JmhNayfh
Disc dump link: https://drive.proton.me/urls/WC04AN1DCW#EziJsMGuC2ew
Drive: BU40N
Disc type: UHD
Drive: BU40N
Disc type: UHD
Drive: BU40N
Disc type: UHD
Drive: BU40N
Disc type: UHD
Drive: BU40N
keydb_helper
*MKB20_v77_Child's_Play_2_0751
*MKB20_v77_Child's_Play_3_7DC3
*MKB20_v77_RINGU_-_4K_UHD_E847
*MKB20_v82_EPiC-_Elvis_Presley_in_Concert_5E14
*MKB20_v82_They_Will_Kill_You_1D64
*MKB20_v82_UPHE_UPK1-1135760R0_B288
99gagamel
Disc Type: UHD
Disc ID: 0x15026F090E35FEBA14A7EC75FF708FCE8C1D02AF
Disc Dump Filename: MKB20_v82_ERASER_3BE8,tgz
Drive: BD-RE BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1bLFkXt ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1dwNRLk ... sp=sharing
_________________________________________________________________
keydb_helper
The derived details all seem to be correct, so I'm not too sure what might've happened with this disc.99gagamel wrote: Fri Jun 12, 2026 2:18 pm Disc Type: UHD
KeyDB entry mismatch detected
KeyDB entry updated
KeyDB Status : not found for 15026F090E35FEBA14A7EC75FF708FCE8C1D02AF
KeyDB entry updated
Sync your keydb and try again with the latest updates. I'd also recommend you follow up with SamuriHL just in case there is some quirky edge case here.
BTW Please don't post keys to the forum. The forum moderators and admins have been gracious enough to allow this thread and they really prefer it if keys and key-adjacent material aren't posted here.
