scream 4 LLSB dumps submitted
swarm87
#1 Post by swarm87 » Mon Jun 08, 2026 8:55 pm
submitted for both the hd and 4k, should mention that they were submitted from the lionsgate limited steelbook, not sure if the standard editions will use the same discs
MrPenguin
Re: scream 4 LLSB dumps submitted
#2 Post by MrPenguin » Mon Jun 08, 2026 10:46 pm
swarm87 wrote: Mon Jun 08, 2026 8:55 pm submitted for both the hd and 4k, should mention that they were submitted from the lionsgate limited steelbook, not sure if the standard editions will use the same discs
If this doesn't work, could you also upload your TGZ dump files into a file host such as OneDrive or Google Drive please, and then reply with public download lniks for them? This would allow people to try adding your disks to the public KEYDB.cfg file as well.
briansemerick
#3 Post by briansemerick » Tue Jun 09, 2026 4:29 pm
MrPenguin wrote: Mon Jun 08, 2026 10:46 pm
this worked for my Scream 4! Thanks!
aimforsilence
#4 Post by aimforsilence » Tue Jun 09, 2026 10:45 pm
I've got the normal non-steelbook edition and it won't load with the latest keydb file.
MrPenguin
#5 Post by MrPenguin » Tue Jun 09, 2026 11:37 pm
aimforsilence wrote: Tue Jun 09, 2026 10:45 pm I've got the normal non-steelbook edition and it won't load with the latest keydb file.
Then can you upload your TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? And also email your dump to svq@makemkv.com, of course.
aimforsilence
#6 Post by aimforsilence » Wed Jun 10, 2026 12:49 pm
MrPenguin wrote: Tue Jun 09, 2026 11:37 pm
What's the process for doing this? I'm newer here and have never done that before.
MrPenguin
#7 Post by MrPenguin » Wed Jun 10, 2026 2:14 pm
aimforsilence wrote: Wed Jun 10, 2026 12:49 pm
MrPenguin wrote: Tue Jun 09, 2026 11:37 pm Then can you upload your TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? And also email your dump to svq@makemkv.com, of course.
Has MakeMKV generated a TGZ dump file for your disk? Because if so, the process is precisely as I have described above.
aimforsilence
#8 Post by aimforsilence » Wed Jun 10, 2026 5:33 pm
MrPenguin wrote: Wed Jun 10, 2026 2:14 pm
Then here is a link to the TGZ dump file
https://1drv.ms/u/c/f78d1e813f837b48/IQ ... o?e=nIrlsl
MrPenguin
#9 Post by MrPenguin » Wed Jun 10, 2026 6:12 pm
aimforsilence wrote: Wed Jun 10, 2026 5:33 pm Then here is a link to the TGZ dump file.
Thanks :). And if you're a Windows user, you may also wish to consider using SamuriHL's KeyDB Assistant utility. This can simplify the process for keeping your local KEYDB.cfg file up-to-date and integrated with MakeMKV. You can even use it to validate an entry in KEYDB.cfg against the UHD disk in your drive.
