Public KeyDB Disc Submissions
IdentityTheft
Post by IdentityTheft »
Disc type: UHD
Disc ID: 0a9fd4af0fa2f69d38814f5ff2fa2b730bd79c59
Disc dump filename: MKB20_v72_Top_Gun_071A
Drive: WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.proton.me/urls/ENC6BAKAGR#8EkXkjbQdNVO
Disc dump link: https://drive.proton.me/urls/7DYF299DRM#KeMk8ysVXyW3
keydb_helper
Post by keydb_helper »
cladefe60 wrote: Mon Jun 08, 2026 4:32 am Scream 7. UHD
Lettore: Verbatim 43888
Firmware 1 03
Libre Drive
Link file tgz: ...
Read the first post of this thread. No one can help you if your fucking link isn't publicly available. There is a reason for the submission template.
Public KeyDB Disc Submissions KeyDB Download
MrPenguin
Post by MrPenguin »
Grazie, e potresti anche modificare l'opzione "Condividi" per quel file in modo che tutti possano accedervi? I file su Google Drive sono privati ​​per impostazione predefinita, quindi al momento nessuno può scaricare il tuo file di dump.
FootFungus07
Post by FootFungus07 »
[/quote]
Thanks for the submissions, all four titles have been added to the public keydb.
Almost all of your recent titles were great candidates for SamuriHL's KeyDB Assistant as the media keys were already known to the keydb so the tool would've derived the required disc keys for you. As you use Windows there should be no barrier to running this tool before future submissions. It really is quicker and easier for everyone if we can reduce the number of avoidable posts to this thread.
Obviously if your discs remain unsupported after running the KeyDB Assistant you are welcome to post your disc dump files to this thread.
OH Wild, I didn't know that tool existed - I'll have to give it a whirl - thank you! And thank you for dropping those discs in!
JSA_123
Post by JSA_123 »
Disc type: BD-ROM
Disc ID: TWBS_5486_1
Disc dump filename: MKB_v82_TWBS_5486_1_E6E6
Drive: BD-RE ASUS SBW-06D2X-U 1.10 AFDL221226WLd
Drive firmware: 1.10
LibreDrive status: Possible, not yet enabled
MKB_RO.inf link: https://drive.google.com/file/d/1LdOWmx ... share_link
Disc dump link: https://drive.google.com/file/d/1kZnaxO ... share_link
JSA_123
Post by JSA_123 »
Disc type: BD-ROM
Disc ID: TWBS_5486_2
Disc dump filename: MKB_v82_TWBS_5486_2_6C6C
MKB_RO.inf link: https://drive.google.com/file/d/1HzCXSo ... share_link
Disc dump link: https://drive.google.com/file/d/1i1BVak ... share_link
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v72_Top_Gun_071A
*MKB20_v82_ERASER_1FEE
*MKB20_v82_FIVE_EASY_PIECES_9250
*MKB20_v82_KNIGHT_OF_SEVEN_KINGDOMS_S1_D1_C708
*MKB20_v82_KNIGHT_OF_SEVEN_KINGDOMS_S1_D2_1A80
*MKB20_v82_Mobile_Suit_Gundam_GQuuuuuuX_-Beginning-_UHD_AF62
*MKB20_v82_THE_SUPER_MARIO_GALAXY_MOVIE_D2C8
snl20
Post by snl20 »
-- thanks for adding
My submisson of
Eraser (1996) 4K Steelbook
bought in Norway and delivered pre release date.
Label: ERASER
Disc type: UHD
Disc ID: 0x59725BDD6C38A9EBB2EDF87FF2676A2C1CA89BDD
Disc dump filename: MKB20_v82_ERASER_1BC4
Drive: PIONEER BD-RW BDR-S12U
Drive firmware: 1.01
MKB_RO.inf link: x
Disc dump link: x
-- dvdfab also reads this now :)
keydb_helper
snl20 wrote: Tue Jun 09, 2026 11:58 am My submisson of
Label: ERASER
Disc type: UHD
Thanks for the submission, your disc has been added to the public keydb.
cladefe60
Post by cladefe60 »
MrPenguin wrote: Mon Jun 08, 2026 9:55 am
Ciao e grazie per la risposta..ok vedo se riesco a rendere pubblico il file su google drive ma poi basta questo o per forza devo inserire id disco..(dove lo Prendo i dati da make mkv o altro?) e poi leggo mb.ro che cosa e' e dove lo prendo?come invio anche..devo mettere tutto?
Come prima volta ho letto il primo messaggio e ho cercato di seguirlo ma si danno per scontato passaggi forse da spiegare meglio a chi si avvicina per la prima volta a questo servizio...
Grazie
cladefe60
Post by cladefe60 »
keydb_helper wrote: Mon Jun 08, 2026 6:36 am
Firmware 1 03
Libre Drive
Link file tgz: ...
Ciao e grazie per la risposta..ok vedo se riesco a rendere pubblico il file su google drive(se magari mi si indica come si fa..) ma poi basta questo o per forza devo inserire anche id disco..(dove lo Prendo i dati da make mkv o altro?) e poi leggo da inserire anche il file " mb.ro "che cosa e' e dove lo prendo per pubblicarlo ?devo mettere tutto?
Come prima volta ho letto il tuo primo messaggio e ho cercato di seguirlo ma si danno per scontato passaggi forse da spiegare meglio a chi si avvicina per la prima volta a questo servizio...
Grazie
aerandir92
Post by aerandir92 »
Avatar Fire and Ash
MKB20_v82_Avatar-_Fire_and_Ash_DB6C: https://drive.google.com/file/d/1QA9QWc ... sp=sharing
Edit: I see now that there is a more detailed template to fill out. I can get around to that tomorrow, my drive is currently busy ripping another disc..
aerandir92
A Knight of the Seven Kingdoms
MKB20_v82_A_Knight_of_the_Seven_Kingdoms_-_Season_1_Disc_1_DF72: https://drive.google.com/file/d/1-bNjRh ... sp=sharing
MKB20_v82_A_Knight_of_the_Seven_Kingdoms_-_Season_1_Disc_2_F76E: https://drive.google.com/file/d/1hFpeqo ... sp=sharing
kario
Post by kario »
Disc type: UHD
Disc ID: cc5595adca37607c776940dd8d6bfc22a0004f39
Disc dump filename: MKB20_v65_Shutter_Island_949D
Drive: BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/27GZ6DC75C#gsZxz6xnIG5T
Disc dump link: https://drive.proton.me/urls/MGJ1YA02ZC#siGs6wk1kOWD
Disc type: UHD
Disc ID: f81fc3b02a9a3129019e4c39b8594fe3c1bd6ce2
Disc dump filename: MKB20_v68_Whiplash_4A99
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/ESBPV7514C#qPs79kk3HnhJ
Disc dump link: https://drive.proton.me/urls/0MRQAQHKK8#fPgR9mEmEj6s
sergio31
Post by sergio31 »
aerandir92 wrote: Tue Jun 09, 2026 3:24 pm Avatar Fire and Ash
"Happy" to see that keydb.cfg is unable to decrypt MKB20_v82_Avatar-_Fire_and_Ash_DB6C.
I already sent .tgz file by mail 5 days ago.
Let's wait volume key.
